Beginner
VXC 2112 usb issue
Hi all,
I have a really silly issue but it is really giving me a hard time.
On a customer we have a 9971 ip phones with 2112 thin clinets. The problem i am facing is that even if i use  a power cube 4 my side usbs dont work. As a result of that i cannot connect printers etc. After some research i found that when the device is connected with a cube 4 then the Full LED ring is lit which doesnt happen on my thin client. I cant really see what it can go wrong when you connect a power cube but can anybody suggest something.
The 9971 phone is connected on a non poe switch and it is booting up properly connecting to the call manager. Also the thin client works fine apart from the side usbs mulfunction
thanks
Everyone's tags (5)
Content for Community-Ad
Software Conformance Survey
