VXLAN on UCS: IGMP with Catalyst 3750, Nexus 5548, Nexus 1000V
Hello Team,
My lab consists of Catalyst 3750 with SVI serving as the router, Nexus 5548 in vpc configuration, UCS in End-Host Mode and Nexus 1000V with feature segmentation (VXLAN) enabled.
I have two different VLANs for VXLAN (140, 141) to demonstrate connectivity across L3.
The hosts with VMKernel on VLAN 140 join the multicast group just fine.
The hosts with VMKernel on VLAN 141 do not join the multicast group.  So, VMs on these hosts cannot ping VMs on the VLAN 140 hosts, and they cannot even ping each other.
I turned on debug ip igmp on the L3 Switch, and the output shows a timeout when waiting for a report from VLAN 141:
Oct 15 08:57:34.201: IGMP(0): Send v2 general Query on Vlan140
Oct 15 08:57:34.201: IGMP(0): Set report delay time to 3.6 seconds for 224.0.1.40 on Vlan140
Oct 15 08:57:36.886: IGMP(0): Received v2 Report on Vlan140 from 172.16.66.2 for 239.1.1.1
Oct 15 08:57:36.886: IGMP(0): Received Group record for group 239.1.1.1, mode 2 from 172.16.66.2 for 0 sources
Oct 15 08:57:36.886: IGMP(0): Updating EXCLUDE group timer for 239.1.1.1
Oct 15 08:57:36.886: IGMP(0): MRT Add/Update Vlan140 for (*,239.1.1.1) by 0
Oct 15 08:57:38.270: IGMP(0): Send v2 Report for 224.0.1.40 on Vlan140
Oct 15 08:57:38.270: IGMP(0): Received v2 Report on Vlan140 from 172.16.66.1 for 224.0.1.40
Oct 15 08:57:38.270: IGMP(0): Received Group record for group 224.0.1.40, mode 2 from 172.16.66.1 for 0 sources
Oct 15 08:57:38.270: IGMP(0): Updating EXCLUDE group timer for 224.0.1.40
Oct 15 08:57:38.270: IGMP(0): MRT Add/Update Vlan140 for (*,224.0.1.40) by 0
Oct 15 08:57:51.464: IGMP(0): Send v2 general Query on Vlan141 <----- It just hangs here until timeout and goes back to vlan140
Oct 15 08:58:35.107: IGMP(0): Send v2 general Query on Vlan140
Oct 15 08:58:35.107: IGMP(0): Set report delay time to 0.3 seconds for 224.0.1.40 on Vlan140
Oct 15 08:58:35.686: IGMP(0): Received v2 Report on Vlan140 from 172.16.66.2 for 239.1.1.1
Oct 15 08:58:35.686: IGMP(0): Received Group record for group 239.1.1.1, mode 2 from 172.16.66.2 for 0 sources
Oct 15 08:58:35.686: IGMP(0): Updating EXCLUDE group timer for 239.1.1.1
Oct 15 08:58:35.686: IGMP(0): MRT Add/Update Vlan140 for (*,239.1.1.1) by 0
if I do a show ip igmp interface, I get the report that there are no joins for vlan 141:
Vlan140 is up, line protocol is up
  Internet address is 172.16.66.1/26
  IGMP is enabled on interface
  Current IGMP host version is 2
  Current IGMP router version is 2
  IGMP query interval is 60 seconds
  IGMP configured query interval is 60 seconds
  IGMP querier timeout is 120 seconds
  IGMP configured querier timeout is 120 seconds
  IGMP max query response time is 10 seconds
  Last member query count is 2
  Last member query response interval is 1000 ms
  Inbound IGMP access group is not set
  IGMP activity: 2 joins, 0 leaves
  Multicast routing is enabled on interface
  Multicast TTL threshold is 0
  Multicast designated router (DR) is 172.16.66.1 (this system)
  IGMP querying router is 172.16.66.1 (this system)
  Multicast groups joined by this system (number of users):
      224.0.1.40(1)
Vlan141 is up, line protocol is up
  Internet address is 172.16.66.65/26
  IGMP activity: 0 joins, 0 leaves
  Multicast designated router (DR) is 172.16.66.65 (this system)
  IGMP querying router is 172.16.66.65 (this system)
  No multicast groups joined by this system
Is there a way to verify why the hosts on VLAN 141 are not successfully joining?  port-profile configuration on the 1000V for the vlan 140 and vlan 141 uplinks and vmkernel are identical except for the different vlan numbers.
Trevor
====================================================================================== If my answers have been helpful in any way, please rate accordingly. Check out my blog for useful vSphere & UCS tips: www.vmtrooper.com
2 Accepted Solutions
abbharga
Level 4
Level 4
Hi Trevor,
Once quick thing to check would be the igmp config for both the vlans.
where do you have the querier configure for the vlan 140 and 141?
are there changes of VXLAN transport traversing routers? if so you would need multicast routing enabled as well.
Thanks!
./abhinav
Hello Trevor,
Could you please attach 'sh run's from N1k & 3750?
One a VLAN 141 host collect:
vemcmd show port
vemcmd show port old
vemcmd show vxlan interfaces
Matthew
5 Replies 5
abbharga
Level 4
Level 4
Hi Trevor,
Thanks!
./abhinav
Hello Abhinav,
Querier for both VLANs is configured on the 3750.  I only have one in my setup.  So, i don't have to worry about stackwise configs.
VXLAN traffic is not traversing routers.  I have a single L3 device in my environment.  The VLAN traffic is routed to the 3750.
What is confusing me that the hosts on VLAN 140 respond to queries without any problem.  It's VLAN 141 that hangs until a timeout.
Anything else I can provide for troubleshoot?
Hello Trevor,
vemcmd show port
Matthew
Hello Matthew,
I didn't see a way to attach a file.  so, I'm pasting the requested output:
3750
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.10.15 11:45:05 =~=~=~=~=~=~=~=~=~=~=~=
sh run
Building configuration...
Current configuration : 8989 bytes
! Last configuration change at 04:22:24 EDT Mon Oct 15 2012 by admin
! NVRAM config last updated at 05:51:05 EDT Mon Oct 15 2012 by admin
version 12.2
no service pad
service password-encryption
hostname vb3750stack
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone EST -5
clock summer-time EDT recurring
system mtu routing 1600
ip routing
no ip domain-lookup
ip multicast-routing distributed
license boot level ipservices
spanning-tree mode rapid-pvst
spanning-tree portfast bpduguard default
spanning-tree portfast bpdufilter default
spanning-tree vlan 1-4094 priority 40960
vlan internal allocation policy ascending
--More--         !
interface Port-channel10
description Port_Channel_To_C3750
switchport trunk allowed vlan 151,154,155,160-162
switchport mode trunk
interface Port-channel20
description Port_Channel_To_VNXe_3100_SP-A
switchport access vlan 152
switchport mode access
flowcontrol receive on
interface Port-channel21
description Port_Channel_To_VNXe_3100_SP-B
interface Port-channel37
description Port_Channel_To_Nexus_5Ks
switchport trunk allowed vlan 140,141,155,156,160-162,180
interface FastEthernet0
no ip address
no ip route-cache cef
no ip route-cache
no ip mroute-cache
interface GigabitEthernet0/1
description 6248-A_mgmt0
switchport access vlan 154
interface GigabitEthernet0/2
description 5548-A_mgmt0
switchport access vlan 151
--More--          spanning-tree portfast
interface GigabitEthernet0/3
description 9148-A_mgmt0
interface GigabitEthernet0/4
description Vblock_Storage_Mgmt_A
interface GigabitEthernet0/5
description C200A_CIMC
interface GigabitEthernet0/6
description To_C200A_G1
switchport trunk allowed vlan 151-154,159-162
spanning-tree portfast trunk
interface GigabitEthernet0/7
description To_C200A_G2
interface GigabitEthernet0/8
description VNXe_A
interface GigabitEthernet0/9
description To_VNXe_3100_SP-A
--More--          switchport mode access
channel-group 20 mode active
interface GigabitEthernet0/10
interface GigabitEthernet0/11
description laptop
interface GigabitEthernet0/12
description laptop
interface GigabitEthernet0/13
description 6248-B_mgmt0
interface GigabitEthernet0/14
description 5548-B_mgmt0
interface GigabitEthernet0/15
description 9148-B_mgmt0
--More--         !
interface GigabitEthernet0/16
description Vblock_Storage_Mgmt_B
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
description VNXe_B
interface GigabitEthernet0/21
description To_VNXe_3100_SP-B
channel-group 21 mode active
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
--More--          description UPLINK TO STATIC 1
no switchport
ip address 172.16.0.22 255.255.255.248
interface GigabitEthernet1/1
interface GigabitEthernet1/2
interface GigabitEthernet1/3
interface GigabitEthernet1/4
interface TenGigabitEthernet1/1
description To_5548-A_Port_E1/21
channel-group 37 mode active
interface TenGigabitEthernet1/2
description To_5548-B_Port_E1/21
interface Vlan1
no ip address
interface Vlan140
ip address 172.16.66.1 255.255.255.192
ip pim sparse-dense-mode
interface Vlan141
ip address 172.16.66.65 255.255.255.192
interface Vlan151
description management
--More--          ip address 172.16.64.1 255.255.255.0
interface Vlan152
description C200_ESX_Mgmt
ip address 172.16.65.1 255.255.255.0
interface Vlan154
description ucs_mgmt_&_kvm
ip address 172.16.67.1 255.255.255.0
interface Vlan155
description VBlock ESX Mgt
ip address 172.16.68.1 255.255.255.0
interface Vlan156
description VBlock ESX VMotion
ip address 172.16.69.1 255.255.255.0
interface Vlan159
description VBlock NFS
ip address 172.16.70.1 255.255.255.0
interface Vlan160
description VBlock ESX Build
ip address 172.16.71.1 255.255.255.0
interface Vlan161
description VBlock N1K Packet
ip address 172.16.72.1 255.255.255.0
interface Vlan162
description VBlock N1K Control
ip address 172.16.73.1 255.255.255.0
interface Vlan180
ip address 172.16.80.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.0.21
--More--         !
ip http server
ip http secure-server
ip sla enable reaction-alerts
banner motd ^C
***W A R N I N G***
THIS IS A PRIVATE COMPUTER SYSTEM.
This computer system including all related equipment, network devices,
are provided only for authorized use.
All computer systems may be monitored for all lawful purposes, including
those activities that are authorized for management of the system.
All information including personal information, stored or sent over this
system may be monitored.
Uses of this system, authorized or unauthorized, constitutes consent to
monitoring of this system.
Unauthorized use may subject you to criminal prosecution.
WARNING: Unauthorized access to this system is forbidden and will be
prosecuted by law.
By accessing this system, you agree that your actions may be monitored.
^C
line con 0
login local
line vty 0 4
login local
transport input ssh
transport output ssh
line vty 5 15
login
ntp clock-period 36026474
ntp server 152.1.226.105 prefer
ntp server 152.2.21.1
end
vb3750stack#  sh ip igmp
% Incomplete command.
vb3750stack#sh ip igmp > int
      224.0.1.40(1)
  IGMP activity: 1 joins, 1 leaves
vb3750stack#
n1k
sh ip igmp snooping querier
Vlan  IP Address       Version   Expires     Port
140   172.16.66.1      v2        00:04:11    port-channel1
141   172.16.66.65     v2        00:04:24    port-channel17
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.10.15 11:45:56 =~=~=~=~=~=~=~=~=~=~=~=
!Command: show running-config
!Time: Mon Oct 15 11:32:27 2012
version 4.2(1)SV1(5.1a)
no feature telnet
banner motd #Nexus 1000v Switch#
ip domain-lookup
switchname VSMVblock
vem 3
  host vmware id 4be8cdc6-08d2-11e2-0000-00000000001f
vem 4
  host vmware id 4be8cdc6-08d2-11e2-0000-00000000007e
vem 5
  host vmware id 4be8cdc6-08d2-11e2-0000-00000000006e
vem 6
  host vmware id 4be8cdc6-08d2-11e2-0000-00000000004e
vem 7
  host vmware id 4be8cdc6-08d2-11e2-0000-00000000005e
vem 8
  host vmware id 4be8cdc6-08d2-11e2-0000-00000000001e
vem 9
  host vmware id 4be8cdc6-08d2-11e2-0000-00000000002e
vem 10
  host vmware id 4be8cdc6-08d2-11e2-0000-00000000000e
vem 11
  host vmware id 4be8cdc6-08d2-11e2-0000-00000000003e
vem 12
  host vmware id 4be8cdc6-08d2-11e2-0000-00000000006f
vem 13
  host vmware id 4be8cdc6-08d2-11e2-0000-00000000002f
vem 14
  host vmware id 4be8cdc6-08d2-11e2-0000-00000000007f
--More--
vem 15
  host vmware id 4be8cdc6-08d2-11e2-0000-00000000004f
vem 16
  host vmware id 4be8cdc6-08d2-11e2-0000-00000000005f
vem 17
  host vmware id 4be8cdc6-08d2-11e2-0000-00000000000f
vem 18
  host vmware id 4be8cdc6-08d2-11e2-0000-00000000003f
bridge-domain tenant-tmt
  segment id 5014
  group 239.1.1.1
snmp-server user admin network-admin auth md5 0xf9146e3932193ebe43f5f11c2aa07ba0 priv 0xf9146e3932193ebe43f5f11c2aa07ba0 localizedke
y
snmp-server community alpine group network-operator
vrf context management
  ip route 0.0.0.0/0 172.16.64.1
vlan 1,140-141,151,155-156,160-162,180
vlan 1
vlan 140
  name vxlan-subnet-01
vlan 141
  name vxlan-subnet-02
vlan 151
  name management
vlan 155
  name vblock_esx_mgmt
vlan 156
  name vblock_esx_vmotion
vlan 160
  name vblock_esx_build
vlan 161
  name vblock_n1k_packet
vlan 162
  name vblock_n1k_control
vlan 180
  name vm_network
--More--
port-channel load-balance ethernet source-mac
port-profile default max-ports 32
port-profile type ethernet Unused_Or_Quarantine_Uplink
  vmware port-group
  shutdown
  description Port-group created for Nexus1000V internal usage. Do not use.
  state enabled
port-profile type vethernet Unused_Or_Quarantine_Veth
  vmware port-group
  shutdown
  state enabled
port-profile type ethernet Uplink
  vmware port-group
  switchport trunk allowed vlan 140,151,155-156,160-162,180
  mtu 1600
  channel-group auto mode on mac-pinning
  no shutdown
  system vlan 140,151,155-156,161-162
  state enabled
port-profile type vethernet Network_Management
  vmware port-group
  no shutdown
  system vlan 151
  state enabled
port-profile type vethernet ESXi_Server_Management
  vmware port-group
  switchport access vlan 155
  no shutdown
  system vlan 155
  state enabled
port-profile type vethernet vMotion
  vmware port-group
--More--
  switchport access vlan 156
  no shutdown
  system vlan 156
  state enabled
port-profile type vethernet Packet
  vmware port-group
  switchport access vlan 161
  no shutdown
  system vlan 161
  state enabled
port-profile type vethernet Control
  vmware port-group
  switchport access vlan 162
  no shutdown
  system vlan 162
  state enabled
port-profile type vethernet VM_Network
  vmware port-group
  switchport access vlan 180
  no shutdown
  state enabled
port-profile type ethernet Uplink_vxlan_subnet_02
  vmware port-group
  switchport trunk allowed vlan 141,151,155-156,160-162,180
  mtu 1600
  no shutdown
  system vlan 141,151,155-156,161-162
  state enabled
port-profile type vethernet vxlan-01-vmknic
  vmware port-group
  switchport access vlan 140
  capability vxlan
--More--
  no shutdown
  state enabled
port-profile type vethernet vxlan-02-vmknic
  vmware port-group
  switchport access vlan 141
  capability vxlan
  no shutdown
  state enabled
port-profile type vethernet tenant-tmt-vxlan
  vmware port-group
  switchport access bridge-domain tenant-tmt
  no shutdown
  state enabled
port-profile type vethernet vxlan-03-vmknic
  vmware port-group
  switchport access vlan 160
  capability vxlan
  no shutdown
  state enabled
vdc VSMVblock id 1
  limit-resource vlan minimum 16 maximum 2049
  limit-resource monitor-session minimum 0 maximum 2
  limit-resource vrf minimum 16 maximum 8192
  limit-resource port-channel minimum 0 maximum 768
  limit-resource u4route-mem minimum 1 maximum 1
  limit-resource u6route-mem minimum 1 maximum 1
  limit-resource m4route-mem minimum 58 maximum 58
  limit-resource m6route-mem minimum 8 maximum 8
interface port-channel1
  inherit port-profile Uplink
  vem 3
interface port-channel2
--More--
  vem 4
interface port-channel3
  vem 5
interface port-channel4
  vem 6
interface port-channel5
  vem 7
interface port-channel6
  vem 8
interface port-channel7
  vem 9
interface port-channel8
  vem 10
interface port-channel9
  vem 11
interface port-channel10
  vem 12
interface port-channel11
  vem 13
--More--
interface port-channel12
  vem 14
interface port-channel13
  vem 15
interface port-channel14
  vem 16
interface port-channel15
  vem 17
interface port-channel16
  vem 18
interface port-channel17
  inherit port-profile Uplink_vxlan_subnet_02
  vem 12
interface mgmt0
  ip address 172.16.64.7/24
interface Vethernet1
  inherit port-profile ESXi_Server_Management
  description VMware VMkernel, vmk0
  vmware dvport 64 dvswitch uuid "aa b8 2b 50 f1 2b 7c cc-e9 4c f1 95 b3 ef d2 36"
  vmware vm mac 0025.B5A0.009F
interface Vethernet2
  vmware dvport 66 dvswitch uuid "aa b8 2b 50 f1 2b 7c cc-e9 4c f1 95 b3 ef d2 36"
--More--
  vmware vm mac 0025.B5A0.007F
interface Vethernet3
  vmware dvport 65 dvswitch uuid "aa b8 2b 50 f1 2b 7c cc-e9 4c f1 95 b3 ef d2 36"
  vmware vm mac 0025.B5A0.006F
interface Vethernet4
  vmware dvport 68 dvswitch uuid "aa b8 2b 50 f1 2b 7c cc-e9 4c f1 95 b3 ef d2 36"
  vmware vm mac 0025.B5A0.004F
interface Vethernet5
  vmware dvport 67 dvswitch uuid "aa b8 2b 50 f1 2b 7c cc-e9 4c f1 95 b3 ef d2 36"
  vmware vm mac 0025.B5A0.005F
interface Vethernet6
  vmware dvport 72 dvswitch uuid "aa b8 2b 50 f1 2b 7c cc-e9 4c f1 95 b3 ef d2 36"
  vmware vm mac 0025.B5A0.001F
interface Vethernet7
  vmware dvport 69 dvswitch uuid "aa b8 2b 50 f1 2b 7c cc-e9 4c f1 95 b3 ef d2 36"
  vmware vm mac 0025.B5A0.002F
interface Vethernet8
  vmware dvport 71 dvswitch uuid "aa b8 2b 50 f1 2b 7c cc-e9 4c f1 95 b3 ef d2 36"
  vmware vm mac 0025.B5A0.000F
--More--
interface Vethernet9
  vmware dvport 70 dvswitch uuid "aa b8 2b 50 f1 2b 7c cc-e9 4c f1 95 b3 ef d2 36"
  vmware vm mac 0025.B5A0.003F
interface Vethernet10
  vmware dvport 73 dvswitch uuid "aa b8 2b 50 f1 2b 7c cc-e9 4c f1 95 b3 ef d2 36"
  vmware vm mac 0025.B5A0.01FF
interface Vethernet11
  vmware dvport 77 dvswitch uuid "aa b8 2b 50 f1 2b 7c cc-e9 4c f1 95 b3 ef d2 36"
  vmware vm mac 0025.B5A0.01CF
interface Vethernet12
  vmware dvport 74 dvswitch uuid "aa b8 2b 50 f1 2b 7c cc-e9 4c f1 95 b3 ef d2 36"
  vmware vm mac 0025.B5A0.01DF
interface Vethernet13
  vmware dvport 75 dvswitch uuid "aa b8 2b 50 f1 2b 7c cc-e9 4c f1 95 b3 ef d2 36"
  vmware vm mac 0025.B5A0.01EF
interface Vethernet14
  vmware dvport 76 dvswitch uuid "aa b8 2b 50 f1 2b 7c cc-e9 4c f1 95 b3 ef d2 36"
  vmware vm mac 0025.B5A0.01BF
interface Vethernet15
--More--
  vmware dvport 79 dvswitch uuid "aa b8 2b 50 f1 2b 7c cc-e9 4c f1 95 b3 ef d2 36"
  vmware vm mac 0025.B5A0.008F
interface Vethernet16
  vmware dvport 78 dvswitch uuid "aa b8 2b 50 f1 2b 7c cc-e9 4c f1 95 b3 ef d2 36"
  vmware vm mac 0025.B5A0.01AF
interface Vethernet17
  inherit port-profile tenant-tmt-vxlan
  description Test Server 03, Network Adapter 1
  vmware dvport 803 dvswitch uuid "aa b8 2b 50 f1 2b 7c cc-e9 4c f1 95 b3 ef d2 36"
  vmware vm mac 0050.56AB.2EE9
interface Vethernet18
  description Test Server 01, Network Adapter 1
  vmware dvport 801 dvswitch uuid "aa b8 2b 50 f1 2b 7c cc-e9 4c f1 95 b3 ef d2 36"
  vmware vm mac 0050.56AB.2EEA
interface Vethernet19
  description Test Server 02, Network Adapter 1
  vmware dvport 800 dvswitch uuid "aa b8 2b 50 f1 2b 7c cc-e9 4c f1 95 b3 ef d2 36"
  vmware vm mac 0050.56AB.2EEB
interface Vethernet20
  inherit port-profile vxlan-01-vmknic
  description VMware VMkernel, vmk1
  vmware dvport 736 dvswitch uuid "aa b8 2b 50 f1 2b 7c cc-e9 4c f1 95 b3 ef d2 36"
  vmware vm mac 0050.5671.336A
interface Vethernet21
  inherit port-profile vxlan-02-vmknic
  vmware dvport 769 dvswitch uuid "aa b8 2b 50 f1 2b 7c cc-e9 4c f1 95 b3 ef d2 36"
--More--
  vmware vm mac 0050.5674.9747
interface Vethernet22
  inherit port-profile vMotion
  description VMware VMkernel, vmk2
  vmware dvport 100 dvswitch uuid "aa b8 2b 50 f1 2b 7c cc-e9 4c f1 95 b3 ef d2 36"
  vmware vm mac 0050.5678.52DB
interface Vethernet23
  vmware dvport 101 dvswitch uuid "aa b8 2b 50 f1 2b 7c cc-e9 4c f1 95 b3 ef d2 36"
  vmware vm mac 0050.567D.8886
interface Vethernet24
  vmware dvport 737 dvswitch uuid "aa b8 2b 50 f1 2b 7c cc-e9 4c f1 95 b3 ef d2 36"
  vmware vm mac 0050.567B.653C
interface Vethernet25
  vmware dvport 102 dvswitch uuid "aa b8 2b 50 f1 2b 7c cc-e9 4c f1 95 b3 ef d2 36"
  vmware vm mac 0050.5677.5B29
interface Ethernet3/1
interface Ethernet3/2
interface Ethernet4/1
interface Ethernet4/2
--More--
interface Ethernet5/1
interface Ethernet5/2
interface Ethernet6/1
interface Ethernet6/2
interface Ethernet7/1
interface Ethernet7/2
interface Ethernet8/1
interface Ethernet8/2
interface Ethernet9/1
interface Ethernet9/2
interface Ethernet10/1
interface Ethernet10/2
interface Ethernet11/1
--More--
interface Ethernet11/2
interface Ethernet12/1
interface Ethernet12/2
interface Ethernet13/1
interface Ethernet13/2
interface Ethernet14/1
interface Ethernet14/2
interface Ethernet15/1
interface Ethernet15/2
interface Ethernet16/1
interface Ethernet16/2
interface Ethernet17/1
interface Ethernet17/2
--More--
interface Ethernet18/1
interface Ethernet18/2
interface control0
line console
boot kickstart bootflash:/nexus-1000v-kickstart-mz.4.2.1.SV1.5.1a.bin sup-1
boot system bootflash:/nexus-1000v-mz.4.2.1.SV1.5.1a.bin sup-1
boot kickstart bootflash:/nexus-1000v-kickstart-mz.4.2.1.SV1.5.1a.bin sup-2
boot system bootflash:/nexus-1000v-mz.4.2.1.SV1.5.1a.bin sup-2
svs-domain
  domain id 1
  control vlan 162
  packet vlan 161
  svs mode L2
svs connection VC01
  protocol vmware-vim
  remote ip address 172.16.64.162 port 80
  vmware dvs uuid "aa b8 2b 50 f1 2b 7c cc-e9 4c f1 95 b3 ef d2 36" datacenter-name Vblock
  max-ports 8192
  connect
vsn type vsg global
  tcp state-checks
vnm-policy-agent
  registration-ip 0.0.0.0
  shared-secret **********
  log-level
VEM Commands
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.10.15 11:55:13 =~=~=~=~=~=~=~=~=~=~=~=
[A
~ # vemcmd show port [A
  LTL   VSM Port  Admin Link  State  PC-LTL  SGID  Vem Port  Type
   17    Eth12/1     UP   UP    F/B*    306     0    vmnic0
   18    Eth12/2     UP   UP    F/B*    306     1    vmnic1
   49     Veth10     UP   UP    FWD       0     1      vmk0
   50     Veth17   DOWN   UP    BLK       0        Test Server 03 ethernet0
   51     Veth19   DOWN   UP    BLK       0        Test Server 02 ethernet0
   52     Veth21     UP   UP    FWD       0     0      vmk1  VXLAN
   53     Veth22     UP   UP    FWD       0     0      vmk2
  306       Po17     UP   UP    F/B*      0
* F/B: Port is BLOCKED on some of the vlans.
Please run "vemcmd show port vlans" to see the details.
~ # vemcmd show port old
~ # vmcmd    emcmd show vxlan interfaces
LTL           IP       Seconds since Last
                       IGMP Query Received
(* Interface on which IGMP Joins are sent)
52    172.16.66.67        10         *
Hello Matthew and Abhinav,
Thank you for your attention to my question.
The problem appears to be specific to one of my servers.
I verified by adding another server to the vxlan uplink and vmk portgroups that i created just for the second vlan 141
The VMs can communicate between 140 and 141 while being on the same segment id without any problem.
I have seen mysterious gremlins like this in the past with 1000V, and usually completely removing the host from the DVS and removing the VEM for a fresh add resolves the problem.
I will attempt to do so with this problematic system.Hopefully, that will clear up the problem.
I am running version 4.2(1)SV1(5.1a).  I know there are newer versions released, but I am required to stick with this version as of now.
Best Regards,
Trevor
