03-27-2018 12:18 AM - edited 03-01-2019 01:28 PM
Hi Team,
My client is recommending to connect each FI to both SAN switches ?
but my concern is
What is Cisco’s recommendation to connect FI to both SAN ?
Device :- UCS5108
Please guide on it
03-27-2018 04:49 AM
Based on your very limited description and question, here is a design guide for UCS and MDS SAN switches.
03-27-2018 06:04 AM - edited 03-27-2018 06:15 AM
The recommended FC fabric design is; dual physical fabric;
- Fabric-interconnect-A - MDS-A
- Fabric-interconnect-B - MDS-B
No cross FC connections !!
03-27-2018 06:18 AM
03-27-2018 06:20 AM
For network switches, typically customers with connect both FI to both upstream network switches. If using Cisco Nexus, you can configure vPC.
If you are using third party switches you would have to explore their HA options.
SAN switches should only connect to a single Fabric Interconnect, A or B.
03-27-2018 06:26 AM
03-27-2018 08:01 AM
03-31-2018 02:52 AM
03-31-2018 03:13 AM
I'm sure this customer is a Ethernet / IP Person, who doesn't understand FC design.
Think about your VSAN design; in contrast to Ethernet, where each Vlan exists on both fabrics, on FC you would design different VSAN's for fabric A, resp. B. This is how you achieve dual fabric separaration; if there is a issue on a fabric, eg. zoning, the other fabric is still working ok; and think about Firmware upgrade; can be done per fabric, therefore Multipathing FC software on the host will handle this automatically without downtime.
How would you design your VSAN's if the UCS FI would be dual homed to Northbound MDS ? the same VSAN has to exist on both fabrics ? and each vhba can only be in one VSAN; therefore you follow the Ethernet design, where each vhba in fabric A and B is in the same VSAN; your multipathing software will therefore see double the number of paths; Troubleshooting becomes a nightmare.
The claim of the storage vendors: to achieve 99.9.. % availability, you Need a dual FC fabric.
04-18-2018 01:06 AM
04-18-2018 01:22 AM
