11-04-2019 08:44 AM
is there a location in UCS where i can see which OS is installed on the blades? I must not be looking in the correct location .
Solved! Go to Solution.
11-04-2019 09:08 AM
You can pull this information via Intersight, but not UCSM.
11-04-2019 08:47 AM
This would have to be user defined. UCS does not have any knowledge into the underlying OS that is running on it.
11-04-2019 08:48 AM
11-04-2019 08:56 AM
You can use the "User Label" feature in UCSM to assign OS name to service profiles so you can remember what is installed.
11-04-2019 08:58 AM - edited 11-04-2019 08:59 AM
Isn't the CIMC able to determine underlying OS ? I would think that would translate into UCSM ?
11-04-2019 09:06 AM - edited 11-04-2019 09:07 AM
Not that I am aware of, but if you have any reference documentation I will take a look. UCS is stateless in nature, so we don't typically care what is running underneath.
11-04-2019 09:08 AM
11-04-2019 11:02 AM
