04-06-2018 12:20 AM - edited 03-01-2019 01:30 PM
Need one help. We have CIsco UCS with 6248 FI, 11 Chassis with 8 M3 B200 Blades, 2204XP IOM modules, 1240 VIC cards on blades for network and storage communication. VMware ESxi 5.1 is running on all the UCS blades. Four Ports on Each FI-A and FI-B are configured as FC port to communicate with storage arrays.
Now I would like to find out which host (HBA WWPN) is using what FC port to communicate with storage. How to find it out? Please help.
Solved! Go to Solution.
04-06-2018 04:41 AM
Greetings.
Login to each FI's cli
#connect nxos
nxos#show npv flogi-table
The output will show the vFC # that represents a blades vHBA, and the pinned to external FC interface.
Also, you can look at a service profile's vif paths tab, and see the external FC interface the vFCs are pinned to.
Kirk...
04-06-2018 04:41 AM
Greetings.
#connect nxos
Kirk...
04-06-2018 04:56 AM
