xmlagent on the UCS switches.
nikhil.kulkarni
Folks,
on a UCS 6100 fabirc extender how do you  verify that the xmlagent is running?
this question is come from one of our developers,...I am not very efficent with 6100 series.
regards,
Nik
Walter Dey
http://192.168.126.147/visore.html
192.168.126.147 = VIP address
Hi Nik,
There is no "xmlagent" per-se.
The *only* way to communicate to the UCS Manager is via the XML/API.
When you run the Java GUI --- even that communication is over the XML/API.
(If you running on Windows 7, you can even examine the GUI log file to see the XML/API calls at
         C:\Documents and Settings\<UserID>\AppData\LocalLow\Sun\Java\Deployment\log\.ucsm
There's no way that UCS Manager can be "working but inaccessible over the XML/API".   Not possible.
Hope this helps,
    -Jeff
Hi Jeff,
through XML API we don't get in depth information the way we get when we make ssh connection to the switch. e.g.  show environment command gives details info of FAN status , Temp, Power supply.
Houvblokf140-A(nxos)# show environment
We want same o/p on XML format for which we are trying to invoke XML interface via SSH
Abhishek
