Configure SPA112 using 2 lines with the same account, but only one should accept the call
xMRi
I have a SPA112. I need to connect a modem and a fax to the device.
Both lines should use the same SIP account for outbound, but only one should be used for inbound.
In the thousands of parameters in the setup I miss the one to configure that inbound calls should not be accepted.
Thanks for a hint.
0 Replies 0
