How do I change the network speed on a SPA502G
Seer81
Currently our Cisco SPA502G phone handsets are only running at 100Mb and so causing a bottleneck as it means the connected device is also only running at 100Mb instead of the 1Gb the switch is running at.
So how do I change the phones to run at the higher speed? I have used a browser and connected to them individually; but cannot see where to change the setting?
Any help would be much appreciated.
balaji.bandi
The  model have onlu - Two Ethernet ports with integrated Ethernet switch: 10/100BASE-T RJ-45
check below datasheet as per model you mentioned:
https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/small-business-spa500-series-ip-phones/data_sheet_c78-548561.html
BB
