SPA500S Sidecar Losing Transfers
FaithC
I have an odd question. My phone is a SPA514G and has a SPA500S sidecar attachment with 25 transfer lines programmed into it, so when I want to transfer a call I just hit the button belonging to whichever phone the call should go to and then hang up my phone. Most of the time, these transfers work fine, but probably 5-10% of calls get "lost". I'll hit the button on the sidecar to transfer them, and then... nothing. They don't get transferred but I can't get back on the line with them. It opens up my second line as if the caller is on hold on the other but I can't get back to them. My coworkers have this happen to them occasionally but as I do most of the transfers it's much more noticeable on my phone. Is there any way to fix this, or is this an issue that's known to happen with these models?
Dan Lukes
Phone (with sidecar) doesn't do the transfer. It just requests it. First you need:
  1. catch and analyze logs from SPA514G
  2. catch and analyze SIP messages exchanged between SPA514G and the call control device
  3. catch and analyze log of call control device the SPA514G is connected to
