UC 540 routing/switching/voice
jcajuste
cisco Switching and UC540
i have a layer 3 switch configure with multiple vlans. i have a uc 540 directly connected to a switch port on the L3 switch.
i can ping the uc.
Core#ping 172.16.15.254
Sending 5, 100-byte ICMP Echos to 172.16.15.254, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/8 ms
Core#
however i can't can't traceroute to the uc.
Tracing the route to 172.16.15.254
VRF info: (vrf in name/id, vrf out name/id)
1 * * *
2 * * *
i can traceroute to a device directly in the same vlan as the uc.
Tracing the route to 172.16.15.23
1 172.16.15.23 0 msec 0 msec 8 msec
extended ping works
Core#ping
Protocol [ip]:
Target IP address: 172.16.15.254
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]:
Sweep range of sizes [n]:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/4/9 ms
Core#
extended ping works , extended traceroute does not see below.  any help will be appreciated.
Core#traceroute
Protocol [ip]:
Source address: 172.16.15.1
Numeric display [n]:
Timeout in seconds [3]:
Probe count [3]:
Minimum Time to Live [1]:
Maximum Time to Live [30]:
Port Number [33434]:
Loose, Strict, Record, Timestamp, Verbose[none]:
1 * * *
2 * * *
3 * *
Core#ping
Protocol [ip]:
Repeat count [5]:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/4/17 ms
Core#ping
Protocol [ip]:
Repeat count [5]:
Extended commands [n]: y
Source address or interface: 172.16.15.1
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Packet sent with a source address of 172.16.15.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/5/17 ms
Core#
0 Replies 0
