2650 and 1750-2`s
mcelec
My main router is a 2650, it has a E&M card to connect to telephone system, then, I need to connect two phones at the remote places, can I do that?
Do you have a good example, or a nice white paper in order to install that?
Or maybe a nice training at E-learning connection.
Thanks in advanced
mc
electro22
I'm assuming the 2 phones are analog phones that would need to connect to an FXS port. the easiest way would be to use a VG200. You can place upto 4 FXS ports in a VG200 and install the VG200 at the remote site
ezequiel
Hi, i think that you need connect phones on remote sites, a good solution is to install a vg200 or 1750 or other little router voice capable on the remote sites and configure to make calls through the IP link between sites, the schema is like this:
POP 1(2 fxs ports) Central Site (E&Mard)
Little router with <-----Wan Connection------> 2650 router with IP link
IP link
In this scenario you use voip features to encapsulate your voice calls from your central site to your remote sites. This is a very simple scenario, if you have the voice cards you can do this quickly.
Ezequiel Colombo
[Argentina]
Thanks Ezequiel,
Yes, it is mi configuration, a 2650 to the Telephone system and a 1750 at remote office with a fxs ports.
Do you have some example config like that?.
I do not know the E&M card conf, and if you have a fxs card conf,,,much better.
thanks in advanced
Martin
Martin,
The configurations you need for each FXS will change slightly depending on the type of phone and features expected.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4224/sw_confg/module.htm
I'm assuming you have Dial-peers configured already. If not yo might want to pick up Cisco Press "Cisco Voice over Frame Realy, ATM, and IP" ISBN# 1-57870-227-5. This will answer all of your questions about this type of deployment.
Hope this helps.
Craig
