2650XM dial-peer using Trunks
hlarriuz
I got a customer with a 2650XM IOS vers. 12.4(19b) (c2600-adventerprisek9_ivs-mz.124-19b), I cannot use ports only Trunks and I cannot get the dial-peers to work. I programmed the Controller with the PRI and D-channel with a Trunk label but not voice-port is created.
I had to replace his router with a temporary 2821 and everything is Ok but of course I need to recover the 2821, his router was working before with another solution, not Cisco, so they didn't want to buy a new one and a PRI card.
I am guessing I don't understand the whole TRUNK programming for Dial-Peers, any help will be appreciated, below are the pieces of config and debug relevant to this.
Hiram
CONFIG
trunk group PSTN
description PRI Line to PSTN
controller T1 1/0
framing esf
linecode b8zs
pri-group timeslots 1-24
description PRI T1 for PSTN
interface Serial1/0:23
no ip address
encapsulation hdlc
isdn switch-type primary-dms100
isdn incoming-voice voice
isdn supp-service name calling
trunk-group PSTN
no cdp enable
dial-peer voice 1 pots
incoming called-number .
trunk-group-label source PSTN
direct-inward-dial
dial-peer voice 201 pots
description Primary Outbound Dial Peer for 10 Digits - Local Services
preference 1
destination-pattern 8305[2-9]......
trunk-group-label target PSTN
prefix 305
dial-peer voice 1000 voip
preference 1
destination-pattern 1...
voice-class codec 5
voice-class h323 5
session target ipv4:192.168.204.21
incoming called-number 8T
dtmf-relay h245-alphanumeric
dial-peer voice 1011 voip
preference 1
voice-class codec 5
voice-class h323 5
DEBUG
HQ1VGW1#
*Mar 2 07:57:46.828: //-1/80D9DD911300/DPM/dpAssociateIncomingPeerCore:
Calling Number=1000, Called Number=83059998002, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Peer Info Type=DIALPEER_INFO_SPEECH
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=1000
*Mar 2 07:57:46.832: //-1/80D9DD911300/DPM/dpAssociateIncomingPeerCore:
*Mar 2 07:57:46.848: //-1/80D9DD911300/DPM/dpMatchPeersCore:
Calling Number=, Called Number=83059998002, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=83059998002
No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
*Mar 2 07:57:46.848: //-1/80D9DD911300/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
HQ1VGW1#
paolo bevilacqua
Under DP, it's "trunkgroup".
Note, yout DP 1 doesn't need or use it.
Note if you have no voice-port, likely you're not using the right hardware or do not have enough dsp. Check "show diag" about that
5 Replies 5
paolo bevilacqua
Thanks for responding.
HQ1VGW1#sh diag
Slot 0:
C2650XM 1FE Mainboard Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time 17:09:56 ago
EEPROM contents at hardware discovery:
Hardware Revision : 3.0
PCB Serial Number : FFFF
Part Number : 73-7755-04
RMA History : 00
RMA Number : 0-0-0-0
Board Revision : A0
Deviation Number : 0-0
Product (FRU) Number : C2650XM-1FE
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 6E 41 03 00 C1 0B FF FF FF 46 46 46
0x10: 46 FF FF FF FF 82 49 1E 4B 04 04 00 81 00 00 00
0x20: 00 42 41 30 80 00 00 00 00 FF FF FF FF FF FF FF
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
WIC Slot 0:
FT1 BT8360
Hardware revision 1.3 Board revision E0
Serial number 25639147 Part number 800-03279-04
FRU Part Number WIC-1DSU-T1=
Test history 0x0 RMA number 00-00-00
Connector type Wan Module
EEPROM format version 2
0x20: 02 11 01 03 01 87 38 EB 50 0C CF 04 00 00 00 00
0x30: 70 00 00 00 02 08 27 01 FF FF FF FF FF FF FF FF
Slot 1:
CT1 (CSU) Port adapter, 1 port
Port adapter insertion time 17:09:55 ago
Hardware revision 1.1 Board revision B0
Serial number 29805542 Part number 800-01228-05
FRU Part Number NM-1CT1-CSU=
EEPROM format version 1
0x00: 01 26 01 01 01 C6 CB E6 50 04 CC 05 00 00 00 00
0x10: 58 00 00 00 04 05 08 00 FF FF FF FF FF FF FF FF
0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
HQ1VGW1#
HQ1VGW1#sh isdn status
Global ISDN Switchtype = primary-dms100
ISDN Serial1/0:23 interface
dsl 0, interface ISDN Switchtype = primary-dms100
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x807FFFFF
Number of L2 Discards = 0, L2 Session ID = 2
Total Allocated ISDN CCBs = 0
HQ1VGW1#
Hiram
I made those changes (trunkgroup, DP1) and the dial peers are matching but still not working, please check "ccapi inout".
Thanks is advanced.
New dial-peer
direct-inward-dial
trunkgroup PSTN
preference 1
prefix 305
preference 1
voice-class codec 5
voice-class h323 5
preference 1
voice-class codec 5
voice-class h323 5
Thanks Dear Bevilacqua,
The issue with the dial-peers using trunk was resolved, now that I passed that step, I have another issue in my next step, the connection to the PSTN(T1/PRI), I will open a different post for that.
Thanks again.
You cannot use this router for voice, it has no voice card.
The NM-1CT1 is only for data and modem, not voice.
You need NM-HDV-xxx for voice.
