I am using dest-pat 9T .By default it waits for 10 sec. So, how can I save/reduce this 10 sec without pressing # for termination ?
Solved! Go to Solution.
For CME put under telephony-service the following command:
timeouts interdigit 3 ! 3 secs interdigit delay
The changes are effective immediately.
Also if it's ISDN to public network, it make sense to add "isdn sending-complete" under ISDN interfaces, so network won't want for overlap sending.
/vnebolsi
Hi, you can change the interdigit timeout by using the timeouts inter-digit command in voice-port configuration mode.
See next url for more information:
Regards.
Please, rate if helpful.
/vnebolsi
Regards.
Thanks for your prompt reply. I will try it tomorrow & inform you.
Ragards
Aziz
