04-01-2010 02:10 AM
Hi guys...... i have one more doubt.. Is it easy to get a job in VOIP field?
04-01-2010 02:34 AM
Yep, if you have qualification and experience that are relevant to it... same as any other field really
Aaron
04-01-2010 02:39 AM
Or put another way - if you are in a job where you are doing a little VoIP work, involve yourself as much as possible in all things related to it, work on your CCVP, and then try your luck.
Aaron
04-01-2010 02:41 AM
Thanks dude.....
