06-01-2004 09:04 AM
We need to connect Alcatel OmniPCX 4400 with board PCM2 R3.2.714.3 with Cisco router 2620 12.2 IOS.
On cisco router is installed VWIC 1MFT-E1 Controller E1.
Some body know is this board is compatible with Cisco router? Any samples of configuration?
Thanks in advance for your help and support.
06-07-2004 08:07 AM
I guess it is. Check this document on the compatibility.
Alcatel
http://www.cisco.com/en/US/products/hw/routers/ps259/prod_troubleshooting_guide09186a008012ed9c.html
06-09-2004 06:53 AM
Have you also installed DSP's into the router? If not you will not be able to process VOICE calls but only DATA calls.
From the perspective of E1 port we also got an 4400 Alcatel PBX and all CISCO E1's are working perfectly.
06-21-2004 07:42 AM
Yes, DSP module are installed on router.
The board that We are connecting is a PCM2 board on Alcaltel PBX.
At this time E1 is up, but We can not get sincronization of channels and no tone is available when We try to make a call.
Thanks for your help and support.
