AS5300 is reloading instantly on "pri-group timeslots 1-31" settings
netopvoxx
On AS5300 when any of the 4 E1 ports is connected and the "pri-group timeslots" are enabled the gateway instantly reloads, I can't see any error message. I have tried the following tests on my Cisco AS5300
1. software loopback on the ports - it does not restart (on     "pri-group timeslot" setting).
2. tried to disconnect one port from a functional gateway ( Cisco AS 5300, with same configuration)     and connect it to a port of new Cisco - it restarts (on "pri group     timeslot" setting)
3. with all cables disconnected and "pri-group timeslot" setting it     is working without restart, after the cable is plugged in, it     restarts
4. hardware         loopback on any of the ports and "pri-group timeslots" - it         restarts
5.
Power off , plug out the module         boards (E1 and DSP boards), plug in the boards and power on -         doesn't help it keeps to restart on the "pri group timeslot"         setting
What could cause this issue?
Thank You,
Szabolcs Szasz
What is the IOS version of your AS5300?
In "show ver" information, what is the reboot cause? Is it a crash?
Probably the command "pri group timeslot" creates an unexpected condition that causes the crash.
In my experience an IOS upgrade solves this issues.
