AS5300 used for dial-in
mstuckey
I am trying to configure the T1 controller on an AS5300.
I want to set it up to talk to a PBX on an E&M Connection. Basically I will dial in with my PC that will go through a PBX to the AS5300 then connect me up to my internal network. The problem I have is I can not find a sample config on Cisco's site that does this, they all come thru a PRI to the AS5300.
Has anyone ever tried this before? Or have any suggestions?
ibrahim
What type of interface does your PBX have? Which PBX? I assume you don't have a D chanel for PRI config. Try this:
controller T1 1/0
framing esf
linecode b8zs
ds0-group 1 timeslots 1-24 type e&m-wink-start
I have a E&M Immediate Start connection
