02-02-2011 08:25 PM
Dear all,
I have a sip gateway (AS5400) that is used to connect sip providers to our internal voice network.
Internal gateway (10.1.1.2 LAN) -- SIP trunk -- AS5400 (10.1.1.3 LAN/ 8.23.23.43 WAN) -- SIP trunk -- Internet SIP Provider
We encountered the following problem :
A SIP call from internal gateway to the sip provider could establish but was muted on our side (sip provider could hear us)
On the WAN interface of the AS5400, there is a ACL that filter traffic IN coming from SIP Provider
interface GigabitEthernet0/0
ip address 8.23.23.43 255.255.255.224
ip access-group 101 in
I log the deny on this ACL and I saw some udp packets denied with LAN adresses !
*Mar 3 15:24:44.001: %SEC-6-IPACCESSLOGP: list 101 denied udp 10.1.1.3(0) -> 10.1.1.2 (0), 1 packet
I did not bind anything on the sip config.
When I changed the ACLs, calls went well.
Why do I see LAN packets on the WAN interface ?
02-04-2011 02:45 AM
Can you post the configuration of your AS5400 and the output of the command "debug ccsip message"?
Regards.
02-04-2011 03:14 AM
02-06-2011 06:56 PM
02-07-2011 09:24 AM
Probably your IP packets are generated from interface GigabitEthernet0/1.
Try to specify the output interface using bind command:
voice service voip
sip
bind control source-interface GigabitEthernet0/0
bind media source-interface GigabitEthernet0/0
Regards.
02-07-2011 07:00 PM
Hello Daniele,
But if I do that, I will have the same problem with my lan interface. Is there not a way to bind the sip traffic on both interfaces ?
02-08-2011 02:24 AM
The only way I know to "bind" different interfaces is the command voice-class source interface under dial-peer configuration.
But there is a limitation: this command works only with loopback interface.
So, you should change the configuration of your gateway.
To allow a loopback interface to be associated with a VoIP or VoIPv6 dial-peer profile, use the voice-class source interface command in dial peer configuration mode. To disable this association, use the no form of this command.
voice-class source interface loopback interface-id [ipv4-address | ipv6-address]
no voice-class source interface loopback interface-id [ipv4-address | ipv6-address]
No loopback interface is associated with a VoIPv6 dial-peer profile.
Dial peer configuration (config-dial-peer)
When the voice-class source interface command is configured, the source address of Routing Table Protocol (RTP) generated by the gateway is taken from the address configured under the loopback interface. This command is used for policy-based routing (PBR) of voice packets originated by the gateway. The policy route map is configured under the loopback interface, and then the loopback interface is specified under the VoIP or VoIPv6 dial peer.
The following example associates a loopback interface with a VoIPv6 dial-peer profile:
Router(config)# dial-peer voice 1 voip
Router (config-dial-peer)# voice-class source interface loopback0
02-08-2011 03:01 AM
Very useful info. This will work well to bind the traffic to the interface level. My rating is 5 !
02-08-2011 03:10 AM
I will try this and let you know,
Thank you for your help,
Mathieu
