boosting wireless headsets/mics signal with a wireless access-point
gringotani
Beginner
Beginner
I need to implement wireless headsets/mics to connect with a PC for a warehouse environment.  The PC would be running an MS Access form that would be integrated with speech recognition and text-to-speech, so the warehouse employee can input data into the MS Access form and use voice commands to execute MS Access macros.  How  can I extend the range of a 2.4ghz  wireless headset microphone with a router?
Thank you very much in advance, Nathaniel
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
wrong forum, and routers don't do that. You can try some microphone vendor.
Recognize Your Peers
