Caller ID on MGCP FXS Port
courtschuett
I've got a Gold Fax fax server set up to run off of 4 FXS ports on an ICS. I have two small hunt groups set up to handle the inbound calls but I'm having trouble passing the caller id information into the fax lines.
What I would like to do is this:
HP: 7060 -> routes to FaxModem1 on server and passes a predetermined number (it can really be anything) to the fax server.
HP: 7050 -> routes to FaxModem2-4 on server and passes a different predetermined number.
I have almost everything set up. I have both hunt groups set up and working correctly. 7060 is ringing to the correct modem, and 7050 is ringing to all three modems (longest idle) correctly. The only problem is that I can't seem to pass any sort of caller id to the FXS ports. I've hooked up a regular analog phone and it's not getting anything either. The CCM is connected to the FXS ports with MGCP.
CCM: 4.0(1)sr2a
HW: ICS7750-MRP300 (MPC860P)
SW: 12.3(2)XA
Any ideas?
Thanks.
thisisshanky
Level 11
Level 11
Is the fax call coming in on a PRI or analog line (FXO) ?
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
