Calling Line Restricted Problem
teodor.dobrev
Beginner
Beginner
Hi to all,
in the following scenario ccme interconnected to Panasonic KX-TD-816-232 PBX through ISDN BRI, can't see calling line ID on incoming(for ccme) calls.
In voip ccapi debug i see Presentation=Restricted on the incoming dial-peer 10. Tried to override this field with no success. Please help with this. Will atach debug and running config.
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Indeed the PBX is placing the call with presentation restricted:
Calling Party Number i = 0x01A1, '114' <-- BIT 5 is set !
Hence IOS is dutifully restricting CLID.
Please check PBX configuration to allow CLID presentation.
