Can't get to Cisco ASR 1002-X prompt or to ROMmon mode
shakib.osman81
I am trying to fix a problem with Cisco ASR 1002-X. The client is not giving me proper feedback and I had to find it by myself. When I turn on the Router it gives me some errors and messages, I tried to to go to ROMmon mode by pressing Ctrl + Break but it prompts me to Factory Reset and even the factory reset does not work saying it could not boot the image. I am using console cable to directly access the router. here is the text from putty
System Bootstrap, Version 16.3(2r), RELEASE SOFTWARE
Copyright (c) 1994-2016 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: LocalSoft
SPI Flash 4KB Descriptor Area Checksum = 0x6f5a0db2
ASR1002-X platform with 4194304 Kbytes of main memory
PASSWORD RECOVERY FUNCTIONALITY IS DISABLED
........no valid BOOT image found
Final autoboot attempt from default boot device...
File size is 0x00000000
Located tracelogs.570
Image size 0 inode num 13, bks cnt 0 blk size 8*512
Boot image size = 0 (0x0) bytes
File size is 0x0000001e
Located throughput_monitor_params
Image size 30 inode num 14, bks cnt 1 blk size 8*512
Boot image size = 30 (0x1e) bytes
Unsigned package found, aborting package loading...
Failed to Free memory block at address 0x000000009f5da000
boot: cannot determine first file name on device "bootflash:/"
autoboot: boot failed, restarting...
Initializing Hardware ...
System integrity status: 00000610
THE MESSAGE FROM HERE IS REPEATED
Error: nv_flash magic number 0xffffffff does not match 0xcafefeed
Correcting the primary nv_flash
Last reset cause: PowerOn
I USE THE CTRL + BREAK HERE BUT IT GIVES ME ERROR TOO!
PASSWORD RECOVERY IS DISABLED.
Do you want to reset the router to the factory default
configuration and proceed [y/n] ?y
Router rebooting with factory default configuration
THANKS IN ADVANCE FOR YOUR HELP
6 Replies 6
Leo Laohoo
Contact Cisco TAC and get the router RMA-ed.
my supervisor told me we may not be able to replace it. I searched on google a lot and couldn't find any solution. I have years of experience in using simulations but am new to physical devices. even a clue to where I may be able to find a solution is greatly appreciated
Pop the lid.
Clean the Flash and DRAM.
Make sure they are secured in their cradle.
umarshaik42940
me to same problem what can i do
please HELP me
Create a new thread.
Post the entire boot-up process of the router.
NOTE:  DO NOT post screenshots.
