Cisco CallManager Installation
shakeelahmadch
As new in Voice Networks, I have a question ! Is Cisco CallManager Solution must be installed on designated / cisco recomended hardware. I want to try it before going a head with buying stuff. Can i install it on my server machines with Windows 2000 Server ??
If any one was successfull please let me know.
thanks,
Shakeel
mheusinger
Level 10
Level 10
this is a somewhat delicate question as it touches to my understanding some legal aspects as well. There are however some sites in the internet which are helpful with all kind of Cisco Callmanager issues.
One I would consider especially helpful is http://www.ccmstuff.org
Hope this helps! Please rate all posts.
Regards, Martin
8 Replies 8
mheusinger
Level 10
Level 10
Regards, Martin
This is how to get CallManager 4.1.3 running on non-MCS server.
1. Install Windows 2000 server (15 gig partition). Make all passwords the same, including WIN2K account. (I used " cisco" )
2. Keep all the default installation components,
just add DHCP under ‘Network Services’,
and SNMP under ‘Management and Monitoring tools’.
3. Assign a static IP.
4. If installing in VMware, install VMware tools (under the main VM tab ) .
5. Install SP3 (at-least). (or make an win200 boot CD yourself with slipstream( google: XP slipstream)
6. Setup DHCP scope and options, don't forget to add the CISCO TFTP option 150
7. Copy the text below into a text file and name it with a .reg extension,
double click this file to make the changes to the registry.
7a) ccmreg1.reg
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Cisco Systems\Model]
"Hardware"="MCS7825H02"
"Speed"="2268"
"Memory"="2048"
[HKEY_LOCAL_MACHINE\SOFTWARE\Spirian\System Info\OS Image]
"Version"="2000.2.6"
[HKEY_LOCAL_MACHINE\SOFTWARE\Spirian\System Info\OS Service Release]
"Version"="2000.2.6sr5"
7b) install win-OS-Upgrade-K9.2000-2-7.exe
7c) ccmreg2.reg
"Speed"="2268"
"Memory"="2048"
[HKEY_LOCAL_MACHINE\SOFTWARE\Cisco Systems\Spirian]
"ProductKey"="BTOOVQESCCJUIEBI"
"Deployed"="0000000000000000"
8. copy c:\program\cisco\updates\2000 2.7sr5\shutdown.exe naar c:\utils
9. Install CallManager 4.1(3)
ccmsetup.exe
10. Go to Start >> Programs >> CCM 4 >> CallManager Administration and IE will open.
11. Go To Menu >> Application >> CCM Serviceability >> Tools >> Service Activation.
>>Click> on server u want to configure on left hand side.
>>Click> "Cisco RIS Data Collector" and press update.
>>Click> on all the services one by one and press update.
12. You should now have CallManager 4.1(3) running.
13. Upgrade OS and CCM with all patches if needed.
14 you can use P2V to make an copy of an working CM to a VMware machine
two q:
1. one partition or two partitions with 15GB both?
2. please explain nuber 8 in your post...
many thanks
Hi Niraj!
I am also install CCM 4.1.3 on not approved server and CCM work ok, but i can not install BARS on same machine with CCM. If you you have solution about how make BARS work on that server please report in this thread.
Thank you
Did you ever find a solution tot he BARS installation problems. I am facing the same issue.
Thanks for the post!
I actually went ahead and tried BARS 4.0(9) and it installed without issue. Now I just have to get the others up to level.
I run a WINDOWS server 2003 and want to know if its the same process to install Call manager...thsnks.
