Cisco FXO auto disconnected while talking
domanhtien
I am configuring the CISCO2901/K9:
Cisco CISCO2901/K9 (revision 1.0) with 483328K/40960K bytes of memory.
Processor board ID FGL1737248D
2 Gigabit Ethernet interfaces
1 terminal line
4 Voice FXO interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
After I finish FXO configuration and make phone calls from SIP phone CP-3905 to PSTN through FXO ports. The problem is while 02 parties are talking about 2 to 3 minutes, and the call is disconnect suddenly.
Attached file is my running configuration. How can I fix this problem?
Tnks
dsobrinho
Level 9
Level 9
Hi guys,
Try configure the  with
Example:
voice-port 0/0/0
trunk-group LINE_FXO_outgoing  -> This is a trunkgroup for outgoing calls.
supervisory disconnect dualtone mid-call
cptone BR
timeouts call-disconnect 1
timeouts wait-release 3
connection plar 372428
description --[NUMBER-ANALOG-LINE]
Best regards,
Daniel Sobrinho
Daniel Sobrinho
5 Replies 5
domanhtien
Hi all,
I am a newbie in Cisco Voice, anyone have any ideas about this problem ??
dsobrinho
Level 9
Level 9
Hi guys,
Example:
voice-port 0/0/0
cptone BR
Best regards,
Daniel Sobrinho
Daniel Sobrinho
Hi Sobrinho,
I configured base on your advice and it's fixed now.
Thank you.
Tiendm
Good approach Sobrinho!!!!! (+5 Stars)
@domanhtien
Please remember to rate helpful  responses and identify helpful or correct answers.
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
Hi Domanhtien,
I am very happy for everything is working now.
Thank you for your feedback.
Thank you Bruno for your feedback as well.
Best regards,
Daniel Sobrinho
Daniel Sobrinho
