04-22-2015 01:02 PM
i have incorrect time on my cisco ip phone 7942.
My cisco 7940 has a correct time of my CCME.
my actions to solve this issue:
- set calendar
- set clock
- set clock time zone
- set time-zone in telephony-service
- upgrade firmware of cisco 7942 type
Always incorrect time (-1hours on the CCME clock)
Thanks you for your help.
Solved! Go to Solution.
04-28-2015 09:43 AM
04-22-2015 06:09 PM
What is the CME version?
What is the 7942 firmware?
Is the incorrect time, actually GMT?
Are all 7942 phones affected?
04-23-2015 05:19 AM
- CME version
CONFIG (Version=7.0(0))
Version 7.0(0)
Cisco Unified Communications Manager Express
- 7942 firmware
i have use two firmwares types:
load 7960-7940 P00308000400
load 7942 SCCP42.8-3-4SR1S
- Yes GMT it's correct because time on CME is Ok and also on cisco ip phone 7940
- Cisco 7941,7942, 7975 are affected
04-23-2015 05:53 AM
Browse to an ip phone, that you have been troubleshooting, and go to the console logs.
Copy and paste them within a post, if you don't mind. Looking for an error related to time zone, permission denied, deletion of file. Anything that might be related to time/ntp failing.
What is your time zone?
Thanks.
04-23-2015 09:38 AM
How to look the console logs?
i have disable the ntp config because i need that the cisco ip phone take the hour on CME.
The ntp config will be apply after.
I have disabled the time-zone on telephony-service, Africa isn't inside.
Thank you
04-23-2015 10:31 AM
If I understand you correctly, the time-zone command has been disabled?
According to Cisco documentation, the time-zone command is required for the 7942.
Has the time stamp ever been correct on the 7942 phones?
I would also verify that the IOS on the router is compaible with the phone firmware.
Phones Display Incorrect Time Stamp
The incorrect time stamp can appear on Cisco IP phones registered in Cisco Unified CME for one of the following reasons:
•Clock or time stamp parameters configured for the Cisco router are incorrect.
•***********The time-zone command which is required for certain Cisco Unified IP phones, such as the Cisco Unified IP Phone 7906G, 7911G, 7941G/GE, 7942, 7945, 7961G/GE, 7962, 7965, 7970G, and 7971G/GE, is incorrect or not configured.**********************
•The firmware version for certain phones must be upgraded. To identify phone firmware filenames associated to specific Cisco Unified IP phone types and compatible with the Cisco IOS release on the Cisco Unified CME router, see the appropriate Cisco Unified CME Supported Firmware, Platforms, Memory, and Voice Products.
Below is the link to troubleshooting incorrect time stamps on ip phones.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/troubleshooting/guide/ts_time.html
To obtain console logs,
-> Open a browser
-> Enter the ip address of the phone
-> After the page opens, click on console logs, which will be on the left.
-> Console logs should be displayed.
04-27-2015 08:02 AM
Hi Charles,
below the console logs
|=== Syslogd === Thu Feb 28 22:33:40 2008
NOT 04:33:39.997383 init: Mounting /dev/fd0a...
INF 04:33:40.175009 init: Mount succeeded.
NOT 04:33:40.212239 init: Mounting /dev/fd1a...
INF 04:33:40.228261 init: Mount succeeded.
NOT 04:33:40.231303 init: Starting espd...
NOT 04:33:40.248205 ESP: pid = 5
NOT 04:33:40.532342 init: Loading drivers from '/etc/sysdvrs.def'.
NOT 04:33:40.642535 init: Loading drivers from '/usr/local/etc/drivers.def'.
DBG 04:33:40.667913 pwr: maxPower = 6300 mwatts, alloc power = 6300
DBG 04:33:40.750422 LCDSWInit: LCD initialized
DBG 04:33:40.768743 audev: driver INSTALLED
DBG 04:33:40.812590 dsp: dirver installed, version 1A0
DBG 04:33:40.813753 LED DRIVER: Model is: 7942
NOT 04:33:40.911618 init: Extracting loadID's into environment...
NOT 04:33:40.913339 init: Starting applications from /etc/init.tab
NOT 04:33:40.915681 init: Sending termination signals to apps for pending restart.
DBG 04:33:40.985353 lcd_open: return success!
DBG 04:33:41.993052 lcd_close: return success!
NOT 04:33:41.994259 init: Starting /bin/cvw
NOT 04:33:41.996590 init: /bin/cvw started as pid=8
NOT 04:33:42.015131 SYSMSG: pid 8 (/bin/cvw) Normal Exit, status = 1
INF 04:33:42.015171 runtime = 0.020 secs
INF 04:33:42.015190 user cpu = 0.000557130 secs
INF 04:33:42.015210 system cpu = 0.014984070 secs
INF 04:33:42.015225 child user cpu = 0.000000000 secs
INF 04:33:42.015250 child sys cpu = 0.000000000 secs
INF 04:33:42.015270 sys interrupts = 0.000147080 secs for 4 interrupts
INF 04:33:42.015292 total cpu = 0.015541200 secs ( 50% utilization )
ERR 04:33:42.018303 SYSMSG: pid 9 ( /bin/cvw) Terminated by Signal->Hangup
INF 04:33:42.018339 runtime = 0.000 secs
INF 04:33:42.018357 user cpu = 0.000000000 secs
INF 04:33:42.018373 system cpu = 0.000000000 secs
INF 04:33:42.018388 child user cpu = 0.000000000 secs
INF 04:33:42.018404 child sys cpu = 0.000000000 secs
INF 04:33:42.018423 sys interrupts = 0.000000000 secs for 0 interrupts
INF 04:33:42.018443 total cpu = 0.000000000 secs ( 0% utilization )
NOT 04:33:42.021394 init: Starting /sbin/inetd
NOT 04:33:42.023708 init: /sbin/inetd started as pid=10
NOT 04:33:42.029155 INETD: pid = 10
NOT 04:33:42.046267 CDP-D: pid = 11
NOT 04:33:42.049623 PAE: pid = 12
NOT 04:33:42.051026 PAE: phone is not single port
NOT 04:33:42.053081 PAE: /tmp/pae.stat does not exist
WRN 04:33:42.054137 PAE: paeReadPCStatus: empty file
NOT 04:33:42.054611 PAE: link-0 is UP
NOT 04:33:42.055030 PAE: starting supplicant
NOT 04:33:42.055452 PAE: EV_DISABLED, ST_DISCONNECTED->ST_DISABLED
NOT 04:33:42.055884 PAE: supplicant is disabled
NOT 04:33:42.056277 PAE: paeSetLastSupStatus: LastSupStatus 0
NOT 04:33:43.040280 CDP-D: Starting CFG_COMMAND_SMSme...365051904
NOT 04:33:44.037276 DHCP: pid = 13
NOT 04:33:44.062699 CDP-D: NA power detected, max power = 6300 milliwatts
NOT 04:33:44.064509 CDP-D: Enable values LLDP:3 CDP:3
NOT 04:33:44.078626 CDP-D: PHY 0 --> 100 MB LINK IS UP
NOT 04:33:44.087550 CDP-D: vvlan changed --> New:4096 old:4096 4096
NOT 04:33:44.097536 CDP-D: vlan Configured --> New:4096 old:4096 :4096
NOT 04:33:44.098655 CDP-D: Sent SIGNINFO & SIGIPCFG
ERR 04:33:44.099310 CDP-D: ----lldpProtoInfo[0].enableState 1
NOT 04:33:44.100570 CDP-D: PHY 1 --> LINK IS DOWN
WRN 04:33:44.100924 CDP-D: PC port down sending to cdpMsgQue
NOT 04:33:44.101457 DHCP: COLDBOOT - wait 5 seconds...
NOT 04:33:44.103623 PAE: SIGIPCFG received...
NOT 04:33:44.106171 init: Starting /sbin/imgauthd
NOT 04:33:44.108223 init: /sbin/imgauthd started as pid=15
NOT 04:33:44.108430 init: Starting /sbin/image
NOT 04:33:44.110494 init: /sbin/image started as pid=16
NOT 04:33:44.111164 INETD: inetdSSH tid 42
NOT 04:33:44.112476 PAE: SIGIPCFG received...
NOT 04:33:44.115902 DNS: pid = 14
WRN 04:33:44.124325 ESP: espInfoUpdate() dropped
WRN 04:33:44.124546 ESP: espInfoUpdate() dropped
NOT 04:33:44.125156 CDP-D: catchipcfg getdhcpinfo IP: 0 Chng:0
NOT 04:33:44.129581 IMG_AUTH: Version: 3.6(1.0): TNP REL
NOT 04:33:44.129840 IMG_AUTH: model: CP-7942G, check for built-in key
NOT 04:33:44.129989 IMG_AUTH: built-in platform RELEASE key is present
NOT 04:33:44.130157 IMG_AUTH: built-in common RELEASE key is present
NOT 04:33:44.130279 IMG_AUTH: TNP, built-in keys : Platform (curr), Common (curr)
NOT 04:33:44.133107 image: [16] ver 2.0 (0.1)
NOT 04:33:44.133916 image: **Legacy TFTP Mode Specified**
NOT 04:33:44.134260 image: $.img_main.c.onNotify-IST_START
NOT 04:33:44.134455 image: $.img_main.c.onNotify-IST_CHK_JRNL
NOT 04:33:44.134565 image: $.img_main.c.parseJournalToLoad
NOT 04:33:44.135035 image: $.img_main.c.onNotify-IST_CHK_HIST
NOT 04:33:44.135456 image: $.img_main.c.checkHistToLoad
NOT 04:33:44.136771 image: $.img_archive.c.changeModeOwner
NOT 04:33:44.137361 image: Performing checksum of software load...
NOT 04:33:47.124097 image: Software load SCCP42.8-3-4SR1S.loads validated.
NOT 04:33:47.124332 image: $.img_main.c.onNotify-IST_GET_LOAD
NOT 04:33:47.124514 image: $.img_main.c.onNotify-IST_DONE
NOT 04:33:47.124819 image: Image Run Complete: status=21
NOT 04:33:47.125517 SYSMSG: pid 16 (/sbin/image) Normal Exit, status = 21
INF 04:33:47.125541 runtime = 3.020 secs
INF 04:33:47.125561 user cpu = 0.462905910 secs
NOT 04:33:47.127376 init: Starting /bin/tftpClient
NOT 04:33:47.129411 init: /bin/tftpClient started as pid=17
NOT 04:33:47.129653 init: Starting /bin/secd
NOT 04:33:47.131636 init: /bin/secd started as pid=18
NOT 04:33:47.131828 init: Starting /bin/ntp
NOT 04:33:47.133828 init: /bin/ntp started as pid=19
NOT 04:33:47.134072 init: Starting /ubin/vieo
NOT 04:33:47.136080 init: /ubin/vieo started as pid=20
NOT 04:33:47.136273 init: Starting /ubin/dsp
NOT 04:33:47.138229 init: /ubin/dsp started as pid=21
NOT 04:33:47.138470 init: Starting /bin/mkdir
NOT 04:33:47.140507 init: /bin/mkdir started as pid=22
NOT 04:33:47.582516 tftpClient: pid = 17
NOT 04:33:47.126154 CDP-D: catchipcfg getdhcpinfo IP: 0 Chng:0
NOT 04:33:47.575975 CDP-D: catchipcfg getdhcpinfo IP: 0 Chng:0
NOT 04:33:47.589413 SECD: main: Starting... Ver: 1.4(1.2) [Feb 28 2008, 22:29:46]
NOT 04:33:47.593376 NTP: [19] ver 3.0 (0.3)
NOT 04:33:47.596241 vieo: main() initializing
NOT 04:33:47.603570 DSP: Version: DSPHOST = 8.3(14.15)PSYL - enable audio output at teh end
NOT 04:33:47.603736 DSP: Version: KFactor = 0.95
WRN 04:33:47.608288 DSP: Table Substitution /ubin/dspCoefs, checksum is disabled, actual checksum = 40646
WRN 04:33:47.612564 DSP: Table Substitution /ubin/dspParms, checksum is disabled, actual checksum = 29442
WRN 04:33:47.614713 DSP: Table Substitution /ubin/dspVols, checksum is disabled, actual checksum = 51837
WRN 04:33:47.616173 DSP: Table Substitution /ubin/dspCosts, checksum is disabled, actual checksum = 215
NOT 04:33:47.677031 vieo: msg queue MQ_MT_VIEO started
NOT 04:33:47.677793 SECD: secCreateDir: dir created </usr/tmp/sec>
NOT 04:33:47.679953 SECD: initSecMode: initializing to sec mode UNKNOWN (default)
WRN 04:33:47.687598 SECD: WARN:loadCert: phone has no LSC cert
NOT 04:33:47.688178 SECD: initResources: have cert+pkey: MIC only, no LSC
NOT 04:33:47.689061 SECD: ctlInit: No CTL file: /flash0/sec/ctl/CTLFile.tlv
NOT 04:33:47.689848 SECD: initCTL: finished CTL initialization
WRN 04:33:47.690376 SECD: WARN:initCTL: ** phone has NO CTL **
WRN 04:33:47.690911 SECD: WARN:resetSecMode: ** WARN ** resetting sec mode to NONE (non-secure)
NOT 04:33:47.691976 SECD: clearCapfList: CAPF table cleared
NOT 04:33:47.692696 SECD: initCapfClnt: CAPF clnt initialized
NOT 04:33:47.705611 SECD: main: starting service...
NOT 04:33:47.709845 init: Starting /bin/mount
NOT 04:33:47.712261 init: /bin/mount started as pid=23
NOT 04:33:47.729131 init: Starting /ubin/zrun
NOT 04:33:47.731871 init: /ubin/zrun started as pid=25
NOT 04:33:47.732410 init: Starting /bin/sleep
NOT 04:33:47.734763 init: /bin/sleep started as pid=26
NOT 04:33:47.754626 zrun: Starting...
NOT 04:33:47.755665 zrun: loadCompressedFileandExecute...
INF 04:33:51.440597 zrun: execv(/tmp/sunvm.unzip/sunvm.cnu, argv)
ALT 04:33:51.669133 ESP: PC Port is not responding. Assuming link down...
ESPD still running but may be degraded...
NOT 04:33:51.670067 ESP: sending startup trigger
NOT 04:33:51.673701 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
WRN 04:33:52.317934 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 04:33:52.323212 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 04:33:52.337456 tftpClient: request server 0 ---> 192.168.3.1
NOT 04:33:52.375258 tftpClient: request server 1 --->
NOT 04:33:53.573882 SECD: setSecMode: sec mode set to NONE (was NONE)
WRN 04:33:53.606972 JVM: Setting LCD Contrast/View Angle to 16 before R2D init
WRN 04:33:53.608162 JVM: Setting LCD Contrast/View Angle to 16 before R2D init
NOT 04:33:53.743602 init: Starting /bin/umount
NOT 04:33:53.746009 init: /bin/umount started as pid=27
ERR 04:33:54.905511 JVM: Startup Module Loader|SystemManager:n/a - Encountered Property Exception while getting: device.system.targetmodules
DBG 04:33:54.977235 lcd_open: return success!
NOT 04:33:55.069066 init: Starting /bin/rmdir
NOT 04:33:55.071591 init: /bin/rmdir started as pid=28
NOT 04:33:55.078362 init: Starting /bin/settmask
NOT 04:33:55.080839 init: /bin/settmask started as pid=29
NOT 04:33:55.205233 init: Starting /bin/login
NOT 04:33:55.207645 init: /bin/login started as pid=3
NOT 04:34:01.188745 JVM: libMT:start SignOn()
NOT 04:34:01.190947 JVM: *** VIEO should already be running. NO? Start "/ubin/vieo &" now ***
NOT 04:34:01.191816 JVM: libMT: send _MTStart...
NOT 04:34:01.195356 JVM: LibMT (vieoProcess.c): registered VIEO callbacks
DBG 04:34:02.190526 audev: audioHwInit,,,
DBG 04:34:02.190892 audev: audioHwInit.
NOT 04:34:02.265292 DSP: _dspdvrStart ok, DSP bootup completed successfully
NOT 04:34:02.268757 DSP: DSP Tone/Ring DSP initialization completed successfully
NOT 04:34:02.271366 DSP: dspdvrinitEnableAudioOutput enabled = 1
NOT 04:34:02.271909 DSP: DSP INIT-*** DSP_STATE_READY***
NOT 04:34:02.273366 JVM: LibMT: MediaTerminationStart OK!
NOT 04:34:02.331775 JVM: Startup Module Loader|ComponentController:? - Initializing MVC comp module's trace mechanism
WRN 04:34:02.819091 SECD: WARN:getCertInfo: ** phone has no LSC
NOT 04:34:03.531286 DSP: configurationNumber 1, enabled 0
NOT 04:34:03.538158 DSP: mtSetDeviceBandwidth: Wideband Headset - deviceWideband=0
NOT 04:34:03.540809 DSP: mtSetDeviceBandwidth: Wideband Handset - deviceWideband=2
NOT 04:34:03.542790 DSP: mtSetG722Codec: g722enable=0
NOT 04:34:03.561075 DSP: configurationNumber 0, enabled 0
NOT 04:34:04.090393 CDP-D: configSelectVLAN: 3 OP_USE_CDP:2 oper:4 cdp:4 lldp:4096 admin:4096 mac:0:23:5e:32:f6:83
NOT 04:34:04.091002 CDP-D: CDP OP: clear cross ref
NOT 04:34:04.091421 CDP-D: getCdpExtaInfo: OP:2 Cos:0 Trust:0 lldp.idxOfInterest:-1
WRN 04:34:04.091925 CDP-D: cdpSetCos T:0 C:0
NOT 04:34:04.092360 CDP-D: CosTrust: 0 0
NOT 04:34:04.104181 CDP-D: vvlan changed --> New:4 old:4096 4
NOT 04:34:04.114149 CDP-D: vlan Configured --> New:3 old:4096 :3
NOT 04:34:04.115350 CDP-D: Sent SIGNINFO & SIGIPCFG
NOT 04:34:04.115953 CDP-D: cdpSetDhcpEnableFlg: SIGNINFO
NOT 04:34:04.226925 JVM: Startup Module Loader|cip.midp.midlet.MIDletManager:? - Initializing MIDletManager ...
NOT 04:34:04.228164 JVM: Startup Module Loader|cip.midp.midlet.MIDletManager:? - Initializing PushRegistry ...
NOT 04:34:04.731388 JVM: Startup Module Loader|cip.midp.pushregistry.e:? - Starting MIDP PushRegistry ...
NOT 04:34:04.738611 JVM: Startup Module Loader|cip.midp.pushregistry.e:? - MIDP PushRegistry started successfully.
NOT 04:34:04.739937 JVM: Startup Module Loader|cip.midp.midlet.MIDletManager:? - Initializing MIDP MemberFilter ...
NOT 04:34:04.741209 JVM: Startup Module Loader|cip.midp.midlet.MIDletManager:? - MIDletManager initialized.
NOT 04:34:04.846451 CDP-D: catchipcfg getdhcpinfo IP: 0 Chng:0
NOT 04:34:04.848746 PAE: SIGIPCFG received...
WRN 04:34:04.936453 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 04:34:04.940450 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 04:34:04.947057 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 04:34:04.950268 DHCP: DHCP enabled...
NOT 04:34:04.953362 CDP-D: catchipcfg getdhcpinfo IP: 0 Chng:0
NOT 04:34:04.954305 CDP-D: catchipcfg getdhcpinfo IP: 0 Chng:0
NOT 04:34:04.973080 DHCP: dhcpSendReq: status 0x12300000
NOT 04:34:04.973615 DHCP: Sending Request...
NOT 04:34:04.974652 PAE: SIGIPCFG received...
NOT 04:34:04.975704 DHCP: Enable
NOT 04:34:04.990413 DHCP: dhcpSendReq: status 0x12300000
NOT 04:34:04.990943 DHCP: Sending Request...
NOT 04:34:04.995798 tftpClient: request server 0 ---> 192.168.3.1
NOT 04:34:04.997027 DHCP: ACK received
NOT 04:34:04.997538 DHCP: Succeeded
NOT 04:34:05.012266 DHCP: IP Address -- 192.168.3.61
NOT 04:34:05.012792 DHCP: Subnet Mask - 255.255.255.0
NOT 04:34:05.013236 DHCP: Default Gwy - 192.168.3.1
NOT 04:34:05.013979 INETD: inetdDnsRetCmd Sending : queNum=367394816
WRN 04:34:05.014680 JVM: HTTP JNI| DNS lookup failed for proxy server:<brasyde.ringo-group.com>
NOT 04:34:05.018147 INETD: inetdDnsRetCmd finished : rc=0
NOT 04:34:05.021111 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 04:34:05.038455 PAE: SIGIPCFG received...
NOT 04:34:05.056537 tftpClient: request server 1 --->
NOT 04:34:05.147391 tftpClient: request server 0 ---> 192.168.3.1
NOT 04:34:05.168836 SECD: updateCTL: starting CTL update
NOT 04:34:05.171006 SECD: ctlRequestFile: Socket 7 connected to /usr/tmp/tftpClientSock
NOT 04:34:05.171778 SECD: ctlRequestFile: Request CTLSEPF47F353D4794.tlv
NOT 04:34:05.173995 ESP: server 0 = 192.168.3.1
NOT 04:34:05.174888 tftpClient: tftp request rcv'd from /usr/tmp/ctlSock, srcFile = CTLSEPF47F353D4794.tlv, dstFile = /usr/tmp/CTLFile.tlv
NOT 04:34:05.176196 tftpClient: auth server - tftpList[0] = 192.168.3.1
NOT 04:34:05.176710 tftpClient: look up server - 0
WRN 04:34:05.178358 SECD: WARN:lookupCTL: CTL update in progress, no old CTL, assume TFTP 192.168.3.1 NONSECURE
NOT 04:34:05.188921 tftpClient: secVal = 0xa
NOT 04:34:05.189443 tftpClient: 192.168.3.1 is a NONsecure server
NOT 04:34:05.189897 tftpClient: temp retval = SRVR_NONSECURE, keep looking
NOT 04:34:05.190378 tftpClient: retval = 10
NOT 04:34:05.190814 tftpClient: Non secure file requested
NOT 04:34:05.198140 TFTP: [4]:Requesting CTLSEPF47F353D4794.tlv from 192.168.3.1
NOT 04:34:05.202213 TFTP: [4]:Error --> No such file
NOT 04:34:05.204330 SYSMSG: pid 4 (/sbin/tftpd) Normal Exit, status = 2
INF 04:34:05.204368 runtime = 0.010 secs
INF 04:34:05.204389 user cpu = 0.000925170 secs
INF 04:34:05.204409 system cpu = 0.003299080 secs
INF 04:34:05.204425 child user cpu = 0.000000000 secs
INF 04:34:05.204441 child sys cpu = 0.000000000 secs
INF 04:34:05.204463 sys interrupts = 0.000456540 secs for 6 interrupts
INF 04:34:05.204487 total cpu = 0.004224250 secs ( 0% utilization )
NOT 04:34:05.206738 SECD: ctlRequestFile: tftp Status 2 rcv'd
NOT 04:34:05.207493 SECD: updateCTL: finished CTL update
ERR 04:34:05.208058 SECD: EROR:updateCTL: ** had NO CTL and CTL tftp FAILED** tftp-err 2
NOT 04:34:05.210552 tftpClient: request server 1 --->
NOT 04:34:05.211228 ESP: server 1 =
NOT 04:34:05.213423 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 04:34:05.218854 tftpClient: request server 0 ---> 192.168.3.1
NOT 04:34:05.219539 ESP: server 0 = 192.168.3.1
WRN 04:34:05.238117 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 04:34:05.246912 tftpClient: tftp request rcv'd from /usr/tmp/tftp, srcFile = SEPF47F353D4794.cnf.xml, dstFile = /usr/cache/SEPF47F353D4794.cnf.xml
NOT 04:34:05.248255 tftpClient: auth server - tftpList[0] = 192.168.3.1
NOT 04:34:05.248765 tftpClient: look up server - 0
WRN 04:34:05.250445 SECD: WARN:lookupCTL: ** no CTL, assume TFTP 192.168.3.1 NONSECURE
NOT 04:34:05.252375 tftpClient: secVal = 0xa
NOT 04:34:05.252873 tftpClient: 192.168.3.1 is a NONsecure server
NOT 04:34:05.253331 tftpClient: temp retval = SRVR_NONSECURE, keep looking
NOT 04:34:05.253815 tftpClient: retval = 10
NOT 04:34:05.254252 tftpClient: Secure file requested
NOT 04:34:05.254657 tftpClient: Non secure file approved -- SEPF47F353D4794.cnf.xml
NOT 04:34:05.261784 TFTP: [7]:Requesting SEPF47F353D4794.cnf.xml from 192.168.3.1
NOT 04:34:05.269721 TFTP: [7]:Finished --> rcvd 1128 bytes
WRN 04:34:05.272710 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 04:34:05.276824 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 04:34:05.450668 SECD: clearTFTPList: cleared all TFTP entries
ERR 04:34:05.681685 JVM: Startup Module Loader|cip.cfg.r:? - Delete of sshUserInfo file failed
ERR 04:34:05.683088 JVM: Startup Module Loader|cip.setg.ScreenSaveProperty:? - Config file field <displayOnTime> is incorrectly formatted. Defaulting.
ERR 04:34:05.684736 JVM: Startup Module Loader|cip.setg.ScreenSaveProperty:? - Config file field <displayIdleTimeout> is incorrectly formatted. Defaulting.
NOT 04:34:05.689857 SECD: setSecMode: sec mode set to NONE (was NONE)
NOT 04:34:05.874798 SECD: clearSRSTList: cleared all SRST entries
WRN 04:34:05.964836 SECD: WARN:cancelCapfOp: CAPF not in use, user cancel ignored
NOT 04:34:05.965412 SECD: clearCapfList: CAPF table cleared
ERR 04:34:05.967486 JVM: GETHOSTBYNAME: Empty Parameter
ERR 04:34:05.969371 SECD: EROR:addCapfEntry: phone has no CTL, can't use CAPF
NOT 04:34:06.000624 SECD: setSecMode: sec mode set to NONE (was NONE)
NOT 04:34:06.089357 JVM: Startup Module Loader|cip.cfg.r:? - DELETE ConfigFile:(scratchpad/SEPF47F353D4794.cnf.xml)WAS SUCCESSFUL
NOT 04:34:06.091403 CDP-D: cdpSetRepeater 11
NOT 04:34:06.092161 CDP-D: set pc vvlan access --> 26
NOT 04:34:06.116033 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 04:34:06.133323 DNS: SIGHUP received...
NOT 04:34:06.135695 PAE: SIGIPCFG received...
NOT 04:34:06.139927 tftpClient: request server 1 --->
NOT 04:34:06.145600 ESP: server 1 =
NOT 04:34:06.147534 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 04:34:06.152584 tftpClient: request server 0 ---> 192.168.3.1
NOT 04:34:06.153238 tftpClient: tftp request rcv'd from /usr/tmp/tftp, srcFile = English_United_States/mk-sccp.jar, dstFile = /usr/ram/L10N507694455
NOT 04:34:06.155375 tftpClient: auth server - tftpList[0] = 192.168.3.1
NOT 04:34:06.155890 tftpClient: look up server - 0
WRN 04:34:06.157517 SECD: WARN:lookupCTL: ** no CTL, assume TFTP 192.168.3.1 NONSECURE
NOT 04:34:06.159527 tftpClient: secVal = 0xa
NOT 04:34:06.160444 tftpClient: 192.168.3.1 is a NONsecure server
NOT 04:34:06.160946 tftpClient: temp retval = SRVR_NONSECURE, keep looking
NOT 04:34:06.161404 tftpClient: retval = 10
NOT 04:34:06.161832 tftpClient: Secure file requested
NOT 04:34:06.162236 tftpClient: Non secure file approved -- English_United_States/mk-sccp.jar
NOT 04:34:06.171298 TFTP: [8]:Requesting English_United_States/mk-sccp.jar from 192.168.3.1
NOT 04:34:06.175370 TFTP: [8]:Error --> No such file
NOT 04:34:06.177480 SYSMSG: pid 8 (/sbin/tftpd) Normal Exit, status = 2
INF 04:34:06.177518 runtime = 0.010 secs
INF 04:34:06.177538 user cpu = 0.000925150 secs
INF 04:34:06.177557 system cpu = 0.003032140 secs
INF 04:34:06.177572 child user cpu = 0.000000000 secs
INF 04:34:06.177588 child sys cpu = 0.000000000 secs
INF 04:34:06.177610 sys interrupts = 0.000466040 secs for 7 interrupts
INF 04:34:06.177633 total cpu = 0.003957290 secs ( 0% utilization )
WRN 04:34:06.268256 JVM: Startup Module Loader|cip.l10n.UserLocaleProperty:? - Unable to process LocaleProperty 'device.settings.config.localization.userlocale'
NOT 04:34:06.293630 tftpClient: request server 1 --->
NOT 04:34:06.324025 tftpClient: request server 0 ---> 192.168.3.1
NOT 04:34:06.324625 tftpClient: tftp request rcv'd from /usr/tmp/tftp, srcFile = United_States/g3-tones.xml, dstFile = /usr/ram/L10N421284252
NOT 04:34:06.325659 ESP: server 0 = 192.168.3.1
WRN 04:34:06.344547 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 04:34:06.348579 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 04:34:06.354949 tftpClient: auth server - tftpList[0] = 192.168.3.1
NOT 04:34:06.355506 tftpClient: look up server - 0
WRN 04:34:06.357152 SECD: WARN:lookupCTL: ** no CTL, assume TFTP 192.168.3.1 NONSECURE
NOT 04:34:06.359088 tftpClient: secVal = 0xa
NOT 04:34:06.359605 tftpClient: 192.168.3.1 is a NONsecure server
NOT 04:34:06.360474 tftpClient: temp retval = SRVR_NONSECURE, keep looking
|=== Syslogd === Fri Feb 29 04:34:06 2008
NOT 04:34:06.361927 tftpClient: retval = 10
NOT 04:34:06.362383 tftpClient: Secure file requested
NOT 04:34:06.362777 tftpClient: Non secure file approved -- United_States/g3-tones.xml
NOT 04:34:06.369635 TFTP: [9]:Requesting United_States/g3-tones.xml from 192.168.3.1
NOT 04:34:06.373610 TFTP: [9]:Error --> No such file
NOT 04:34:06.375722 SYSMSG: pid 9 (/sbin/tftpd) Normal Exit, status = 2
INF 04:34:06.375760 runtime = 0.010 secs
INF 04:34:06.375780 user cpu = 0.000927180 secs
INF 04:34:06.375799 system cpu = 0.003994820 secs
INF 04:34:06.375815 child user cpu = 0.000000000 secs
INF 04:34:06.375832 child sys cpu = 0.000000000 secs
INF 04:34:06.375853 sys interrupts = 0.000437110 secs for 6 interrupts
INF 04:34:06.375876 total cpu = 0.004922000 secs ( 0% utilization )
WRN 04:34:06.468681 JVM: Startup Module Loader|cip.l10n.NetworkLocaleProperty:? - Unable to process LocaleProperty 'device.settings.config.localization.networklocale'
WRN 04:34:06.533211 SECD: WARN:lookupCTL: ** no CTL, assume CCM 192.168.3.1 NONSECURE
NOT 04:34:06.611377 tftpClient: request server 1 --->
NOT 04:34:06.612659 ESP: server 1 =
NOT 04:34:06.633584 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 04:34:06.638945 tftpClient: request server 0 ---> 192.168.3.1
NOT 04:34:06.654619 tftpClient: request server 1 --->
NOT 04:34:06.655617 INETD: inetdDnsRetCmd Sending : queNum=367394816
NOT 04:34:06.656587 INETD: inetdDnsRetCmd finished : rc=0
NOT 04:34:06.697116 tftpClient: request server 0 ---> 192.168.3.1
NOT 04:34:06.705256 ESP: server 0 = 192.168.3.1
NOT 04:34:06.706839 INETD: inetdDnsRetCmd Sending : queNum=367394816
NOT 04:34:06.707796 INETD: inetdDnsRetCmd finished : rc=0
NOT 04:34:06.709763 tftpClient: request server 1 --->
NOT 04:34:06.710666 ESP: server 1 =
NOT 04:34:06.713066 INETD: inetdDnsRetCmd Sending : queNum=367394816
NOT 04:34:06.716067 INETD: inetdDnsRetCmd finished : rc=0
WRN 04:34:07.511924 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventServicesTxStop
WRN 04:34:07.512966 NTP: Now using non-NTP clock reference.
WRN 16:38:40.033167 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateHandsetOffHook Event = EventSetSpeakerMode
ERR 16:38:41.509720 DSP: wcTrans*** Invalid response 5
ERR 16:38:41.510534 DSP: Tone*** Connect/disconnect fails: -1
ERR 16:38:41.629712 DSP: wcTrans*** Invalid response 5
ERR 16:38:41.630462 DSP: Tone*** Connect/disconnect fails: -1
ERR 16:38:41.849733 DSP: wcTrans*** Invalid response 5
ERR 16:38:41.850863 DSP: Tone*** Connect/disconnect fails: -1
ERR 16:38:42.339664 DSP: wcTrans*** Invalid response 5
ERR 16:38:42.340431 DSP: Tone*** Connect/disconnect fails: -1
NOT 16:38:47.053485 DSP: ====== A phone call starts ....
NOT 16:38:47.054031 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 210, 259, 20; tx = 131, 4
NOT 16:38:47.054587 DSP: MIB2- ipInDelivers= 303, udpInDG= 7, udpOutDG= 9, udpNoPort= 93, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 16:38:47.055119 DSP: STREAM- OpenEgressChan- ChanType 1, local (multicast host 0, port 0), MedType 12, Period 20, stream (102, 889) mix (1, 3)
NOT 16:38:47.055726 DSP: STREAM- OpenEgressChan --> local port x0, reserved port x0, --> Chan 0
NOT 16:38:47.057017 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:100
NOT 16:38:47.059392 DSP: TRSTREAM, isrEgressReqDiscardpreStreaming 0
NOT 16:38:47.095430 DSP: STREAM- OpenIngressChan- ChanType 1, Remote (host c0a80301, port 7d0), medType 12, Period 20, VAD 0, TOS b8, stream (102, 889) --> chan 0
NOT 16:38:47.096061 DSP: STREAM- OpenIngressChan- mix (1, 3), dtmfpayloadtype 0
NOT 16:38:47.096718 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:84
ERR 16:38:47.104730 DSP: wcTrans*** Invalid response 5
ERR 16:38:47.105427 DSP: Tone*** Connect/disconnect fails: -1
NOT 16:43:57.878610 DSP: STREAM- CloseEgressChan- ChanType 1, stream (102, 889) --> Chan 0
NOT 16:43:57.882538 DSP: Added back for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:59
NOT 16:43:57.883710 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 15905, 306, 25; tx = 15813, 4
NOT 16:43:57.884346 DSP: MIB2- ipInDelivers= 16032, udpInDG= 15500, udpOutDG= 15548, udpNoPort= 127, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 16:43:57.892624 DSP: STREAM- CloseIngressChan- ChanType 1, stream (102, 889) --> Chan 0
NOT 16:43:57.896041 DSP: Added back for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:75
WRN 16:43:58.245752 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventSetSpeakerModeOff
WRN 16:43:58.247026 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventEndcall
NOT 16:47:12.337663 DSP: ====== A phone call starts ....
NOT 16:47:12.338629 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 15955, 327, 28; tx = 15841, 4
NOT 16:47:12.339197 DSP: MIB2- ipInDelivers= 16103, udpInDG= 15500, udpOutDG= 15549, udpNoPort= 148, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 16:47:12.339753 DSP: STREAM- OpenEgressChan- ChanType 1, local (multicast host 0, port 0), MedType 12, Period 20, stream (102, 890) mix (1, 3)
NOT 16:47:12.340409 DSP: STREAM- OpenEgressChan --> local port x0, reserved port x0, --> Chan 0
NOT 16:47:12.341708 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:100
NOT 16:47:12.346769 DSP: TRSTREAM, isrEgressReqDiscardpreStreaming 0
NOT 16:47:12.365969 DSP: ***MediaTerminationStopTone ignored, nonmatched call reference- new 890, current tone 889
NOT 16:47:12.373519 DSP: STREAM- OpenIngressChan- ChanType 1, Remote (host c0a80301, port 7d0), medType 12, Period 20, VAD 0, TOS b8, stream (102, 890) --> chan 0
NOT 16:47:12.374188 DSP: STREAM- OpenIngressChan- mix (1, 3), dtmfpayloadtype 0
NOT 16:47:12.374816 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:84
WRN 16:47:12.703870 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateHandsetOffHook Event = EventSetSpeakerMode
NOT 16:49:38.652767 DSP: STREAM- CloseEgressChan- ChanType 1, stream (102, 890) --> Chan 0
NOT 16:49:38.658016 DSP: Added back for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:59
NOT 16:49:38.658815 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 23296, 348, 31; tx = 23227, 4
NOT 16:49:38.659054 DSP: MIB2- ipInDelivers= 23463, udpInDG= 22736, udpOutDG= 22863, udpNoPort= 167, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 16:49:38.666407 DSP: STREAM- CloseIngressChan- ChanType 1, stream (102, 890) --> Chan 0
NOT 16:49:38.668071 DSP: Added back for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:75
NOT 16:49:38.702531 DSP: ***MediaTerminationStopTone ignored, nonmatched call reference- new 890, current tone 889
WRN 16:49:38.993265 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventSetSpeakerModeOff
WRN 16:49:38.994169 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventEndcall
ERR 17:00:00.000248 NTP: Fri Apr 24 17:00:00 2015
ERR 18:00:00.000259 NTP: Fri Apr 24 18:00:00 2015
NOT 18:05:51.015857 PAE: SIGIPCFG received...
NOT 18:05:51.017486 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
WRN 18:05:51.052478 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:05:51.056595 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:05:51.063739 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 18:05:51.098703 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 18:05:51.103702 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:05:51.118072 tftpClient: request server 1 --->
NOT 18:05:51.129840 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:05:51.131772 ESP: server 0 = 192.168.3.1
NOT 18:05:51.143723 tftpClient: request server 1 --->
NOT 18:05:51.145620 ESP: server 1 =
WRN 18:05:51.175866 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:05:51.179808 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:05:51.189740 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:05:51.205837 tftpClient: request server 1 --->
NOT 18:05:52.013985 CDP-D: PHY 1 --> 100 MB LINK IS UP
ERR 18:05:52.014629 CDP-D: ----lldpProtoInfo[1].enableState 1
NOT 18:05:52.019059 PAE: SIGIPCFG received...
NOT 18:05:52.021058 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:05:52.022198 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 18:05:52.026662 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:05:52.030622 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:05:52.037177 PAE: SIGIPCFG received...
NOT 18:05:52.039506 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 18:05:52.041106 PAE: link-1: DOWN-->UP
NOT 18:05:52.045446 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:05:52.062052 tftpClient: request server 1 --->
NOT 18:05:52.073894 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:05:52.075803 ESP: server 0 = 192.168.3.1
NOT 18:05:52.087418 tftpClient: request server 1 --->
NOT 18:05:52.089357 ESP: server 1 =
NOT 18:05:52.091101 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:05:52.123982 tftpClient: request server 0 ---> 192.168.3.1
WRN 18:05:52.126841 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:05:52.130844 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:05:52.137042 ESP: server 0 = 192.168.3.1
NOT 18:05:52.142015 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:05:52.143710 tftpClient: request server 1 --->
NOT 18:05:52.144609 ESP: server 1 =
NOT 18:05:52.161602 tftpClient: request server 1 --->
NOT 18:05:53.024467 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 18:05:54.022642 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 18:05:55.021937 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 18:20:40.011680 CDP-D: PHY 1 --> LINK IS DOWN
NOT 18:20:40.016008 PAE: SIGIPCFG received...
NOT 18:20:40.017641 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:20:40.018742 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 18:20:40.056692 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:20:40.060700 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:20:40.067382 PAE: SIGIPCFG received...
NOT 18:20:40.100111 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 18:20:40.101167 PAE: link-1: UP-->DOWN
NOT 18:20:40.101765 PAE: paeWritePCStatus: type 0
NOT 18:20:40.106048 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:20:40.120971 tftpClient: request server 1 --->
NOT 18:20:40.132847 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:20:40.134775 ESP: server 0 = 192.168.3.1
NOT 18:20:40.148513 tftpClient: request server 1 --->
NOT 18:20:40.152560 ESP: server 1 =
NOT 18:20:40.154271 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:20:40.184068 tftpClient: request server 0 ---> 192.168.3.1
WRN 18:20:40.186896 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:20:40.190896 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:20:40.197283 ESP: server 0 = 192.168.3.1
NOT 18:20:40.201801 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:20:40.203482 tftpClient: request server 1 --->
NOT 18:20:40.204391 ESP: server 1 =
NOT 18:20:40.219333 tftpClient: request server 1 --->
NOT 18:23:53.011737 CDP-D: PHY 1 --> 100 MB LINK IS UP
ERR 18:23:53.012806 CDP-D: ----lldpProtoInfo[1].enableState 1
NOT 18:23:53.016970 PAE: SIGIPCFG received...
NOT 18:23:53.018540 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:23:53.019647 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 18:23:53.026680 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:23:53.030684 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:23:53.037647 PAE: SIGIPCFG received...
NOT 18:23:53.039995 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 18:23:53.041015 PAE: link-1: DOWN-->UP
NOT 18:23:53.045347 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:23:53.062100 tftpClient: request server 1 --->
NOT 18:23:53.074236 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:23:53.076130 ESP: server 0 = 192.168.3.1
NOT 18:23:53.087443 tftpClient: request server 1 --->
NOT 18:23:53.089357 ESP: server 1 =
NOT 18:23:53.091485 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:23:53.123849 tftpClient: request server 0 ---> 192.168.3.1
WRN 18:23:53.126643 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:23:53.130637 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:23:53.137104 ESP: server 0 = 192.168.3.1
NOT 18:23:53.141559 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:23:53.143257 tftpClient: request server 1 --->
NOT 18:23:53.144163 ESP: server 1 =
NOT 18:23:53.161138 tftpClient: request server 1 --->
NOT 18:23:54.021596 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 18:23:55.021509 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 18:23:56.021495 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 18:24:46.011333 CDP-D: PHY 1 --> LINK IS DOWN
NOT 18:24:46.015205 PAE: SIGIPCFG received...
NOT 18:24:46.016839 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:24:46.017940 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 18:24:46.056026 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:24:46.060070 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:24:46.067041 PAE: SIGIPCFG received...
NOT 18:24:46.099292 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 18:24:46.100837 PAE: link-1: UP-->DOWN
NOT 18:24:46.101450 PAE: paeWritePCStatus: type 0
NOT 18:24:46.105836 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:24:46.120662 tftpClient: request server 1 --->
NOT 18:24:46.132152 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:24:46.134116 ESP: server 0 = 192.168.3.1
NOT 18:24:46.145923 tftpClient: request server 1 --->
NOT 18:24:46.147839 ESP: server 1 =
NOT 18:24:46.149526 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:24:46.184359 tftpClient: request server 0 ---> 192.168.3.1
WRN 18:24:46.187173 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:24:46.191191 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:24:46.197312 ESP: server 0 = 192.168.3.1
NOT 18:24:46.202251 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:24:46.203945 tftpClient: request server 1 --->
NOT 18:24:46.204889 ESP: server 1 =
NOT 18:24:46.219394 tftpClient: request server 1 --->
NOT 18:26:38.011394 CDP-D: PHY 1 --> 100 MB LINK IS UP
ERR 18:26:38.012463 CDP-D: ----lldpProtoInfo[1].enableState 1
NOT 18:26:38.016647 PAE: SIGIPCFG received...
NOT 18:26:38.018210 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:26:38.019311 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 18:26:38.026653 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:26:38.030639 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:26:38.037307 PAE: SIGIPCFG received...
NOT 18:26:38.039604 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 18:26:38.041053 PAE: link-1: DOWN-->UP
NOT 18:26:38.045398 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:26:38.062240 tftpClient: request server 1 --->
NOT 18:26:38.073909 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:26:38.075841 ESP: server 0 = 192.168.3.1
NOT 18:26:38.087586 tftpClient: request server 1 --->
NOT 18:26:38.089492 ESP: server 1 =
NOT 18:26:38.091331 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:26:38.123904 tftpClient: request server 0 ---> 192.168.3.1
WRN 18:26:38.126707 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:26:38.130740 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:26:38.136891 ESP: server 0 = 192.168.3.1
NOT 18:26:38.141849 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:26:38.143525 tftpClient: request server 1 --->
NOT 18:26:38.144434 ESP: server 1 =
NOT 18:26:38.161684 tftpClient: request server 1 --->
NOT 18:26:39.011642 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 18:26:40.012378 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 18:26:41.011650 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 18:35:29.011325 CDP-D: PHY 1 --> LINK IS DOWN
NOT 18:35:29.015632 PAE: SIGIPCFG received...
NOT 18:35:29.017274 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:35:29.018374 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 18:35:29.054142 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:35:29.058089 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:35:29.065122 PAE: SIGIPCFG received...
NOT 18:35:29.099975 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 18:35:29.101394 PAE: link-1: UP-->DOWN
NOT 18:35:29.102003 PAE: paeWritePCStatus: type 0
NOT 18:35:29.106363 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:35:29.121401 tftpClient: request server 1 --->
NOT 18:35:29.132924 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:35:29.134901 ESP: server 0 = 192.168.3.1
NOT 18:35:29.146587 tftpClient: request server 1 --->
NOT 18:35:29.148493 ESP: server 1 =
NOT 18:35:29.152047 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:35:29.184773 tftpClient: request server 0 ---> 192.168.3.1
WRN 18:35:29.187598 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:35:29.191611 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:35:29.197715 ESP: server 0 = 192.168.3.1
NOT 18:35:29.202609 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:35:29.204346 tftpClient: request server 1 --->
NOT 18:35:29.205241 ESP: server 1 =
NOT 18:35:29.219737 tftpClient: request server 1 --->
NOT 18:37:31.011437 CDP-D: PHY 1 --> 100 MB LINK IS UP
ERR 18:37:31.012513 CDP-D: ----lldpProtoInfo[1].enableState 1
NOT 18:37:31.016703 PAE: SIGIPCFG received...
NOT 18:37:31.018267 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:37:31.019372 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 18:37:31.024264 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:37:31.028257 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:37:31.034915 PAE: SIGIPCFG received...
NOT 18:37:31.037184 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 18:37:31.038246 PAE: link-1: DOWN-->UP
NOT 18:37:31.042971 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:37:31.059246 tftpClient: request server 1 --->
NOT 18:37:31.073902 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:37:31.075828 ESP: server 0 = 192.168.3.1
NOT 18:37:31.087507 tftpClient: request server 1 --->
NOT 18:37:31.089427 ESP: server 1 =
NOT 18:37:31.091184 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:37:31.137149 tftpClient: request server 0 ---> 192.168.3.1
WRN 18:37:31.139931 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:37:31.144211 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:37:31.151897 ESP: server 0 = 192.168.3.1
NOT 18:37:31.156316 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:37:31.158004 tftpClient: request server 1 --->
NOT 18:37:31.158963 ESP: server 1 =
NOT 18:37:31.176496 tftpClient: request server 1 --->
NOT 18:37:32.011650 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 18:37:33.012372 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 18:37:34.011696 CDP-D: Set timer to 1 sec to send a Trigger Response.
ERR 19:00:00.000262 NTP: Fri Apr 24 19:00:00 2015
NOT 19:40:36.011326 CDP-D: PHY 1 --> LINK IS DOWN
NOT 19:40:36.015615 PAE: SIGIPCFG received...
NOT 19:40:36.017263 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 19:40:36.018406 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 19:40:36.056428 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 19:40:36.060404 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 19:40:36.067251 PAE: SIGIPCFG received...
NOT 19:40:36.098524 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 19:40:36.099592 PAE: link-1: UP-->DOWN
NOT 19:40:36.100651 PAE: paeWritePCStatus: type 0
NOT 19:40:36.105057 tftpClient: request server 0 ---> 192.168.3.1
NOT 19:40:36.119116 tftpClient: request server 1 --->
NOT 19:40:36.133721 tftpClient: request server 0 ---> 192.168.3.1
NOT 19:40:36.135610 ESP: server 0 = 192.168.3.1
NOT 19:40:36.147038 tftpClient: request server 1 --->
NOT 19:40:36.148939 ESP: server 1 =
NOT 19:40:36.152806 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
|=== Syslogd === Fri Apr 24 19:40:36 2015
NOT 19:40:36.183491 tftpClient: request server 0 ---> 192.168.3.1
WRN 19:40:36.186308 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 19:40:36.190315 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 19:40:36.196380 ESP: server 0 = 192.168.3.1
NOT 19:40:36.201283 tftpClient: request server 0 ---> 192.168.3.1
NOT 19:40:36.202962 tftpClient: request server 1 --->
NOT 19:40:36.203862 ESP: server 1 =
NOT 19:40:36.217965 tftpClient: request server 1 --->
ERR 20:00:00.000618 NTP: Fri Apr 24 20:00:00 2015
ERR 21:00:00.003098 NTP: Fri Apr 24 21:00:00 2015
ERR 22:00:00.000553 NTP: Fri Apr 24 22:00:00 2015
ERR 23:00:00.000302 NTP: Fri Apr 24 23:00:00 2015
ERR 00:00:00.000261 NTP: Sat Apr 25 00:00:00 2015
ERR 01:00:00.000255 NTP: Sat Apr 25 01:00:00 2015
ERR 02:00:00.000303 NTP: Sat Apr 25 02:00:00 2015
ERR 03:00:00.000253 NTP: Sat Apr 25 03:00:00 2015
ERR 04:00:00.000607 NTP: Sat Apr 25 04:00:00 2015
ERR 05:00:00.000559 NTP: Sat Apr 25 05:00:00 2015
ERR 06:00:00.002748 NTP: Sat Apr 25 06:00:00 2015
ERR 07:00:00.000258 NTP: Sat Apr 25 07:00:00 2015
ERR 08:00:00.000262 NTP: Sat Apr 25 08:00:00 2015
ERR 09:00:00.000300 NTP: Sat Apr 25 09:00:00 2015
ERR 10:00:00.000257 NTP: Sat Apr 25 10:00:00 2015
ERR 11:00:00.000559 NTP: Sat Apr 25 11:00:00 2015
ERR 12:00:00.000299 NTP: Sat Apr 25 12:00:00 2015
ERR 13:00:00.000257 NTP: Sat Apr 25 13:00:00 2015
ERR 14:00:00.000300 NTP: Sat Apr 25 14:00:00 2015
ERR 15:00:00.000306 NTP: Sat Apr 25 15:00:00 2015
ERR 16:00:00.000564 NTP: Sat Apr 25 16:00:00 2015
ERR 17:00:00.000265 NTP: Sat Apr 25 17:00:00 2015
ERR 18:00:00.000550 NTP: Sat Apr 25 18:00:00 2015
ERR 19:00:00.000564 NTP: Sat Apr 25 19:00:00 2015
ERR 20:00:00.002789 NTP: Sat Apr 25 20:00:00 2015
ERR 21:00:00.000255 NTP: Sat Apr 25 21:00:00 2015
ERR 22:00:00.000591 NTP: Sat Apr 25 22:00:00 2015
ERR 23:00:00.000555 NTP: Sat Apr 25 23:00:00 2015
ERR 00:00:00.000556 NTP: Sun Apr 26 00:00:00 2015
ERR 01:00:00.003074 NTP: Sun Apr 26 01:00:00 2015
ERR 02:00:00.000553 NTP: Sun Apr 26 02:00:00 2015
ERR 03:00:00.003050 NTP: Sun Apr 26 03:00:00 2015
ERR 04:00:00.000305 NTP: Sun Apr 26 04:00:00 2015
ERR 05:00:00.000247 NTP: Sun Apr 26 05:00:00 2015
ERR 06:00:00.000381 NTP: Sun Apr 26 06:00:00 2015
ERR 07:00:00.000299 NTP: Sun Apr 26 07:00:00 2015
ERR 08:00:00.000255 NTP: Sun Apr 26 08:00:00 2015
ERR 09:00:00.000551 NTP: Sun Apr 26 09:00:00 2015
ERR 10:00:00.000304 NTP: Sun Apr 26 10:00:00 2015
ERR 11:00:00.000604 NTP: Sun Apr 26 11:00:00 2015
ERR 12:00:00.000298 NTP: Sun Apr 26 12:00:00 2015
ERR 13:00:00.000265 NTP: Sun Apr 26 13:00:00 2015
ERR 14:00:00.000631 NTP: Sun Apr 26 14:00:00 2015
ERR 15:00:00.000554 NTP: Sun Apr 26 15:00:00 2015
ERR 16:00:00.000268 NTP: Sun Apr 26 16:00:00 2015
ERR 17:00:00.000262 NTP: Sun Apr 26 17:00:00 2015
ERR 18:00:00.000561 NTP: Sun Apr 26 18:00:00 2015
ERR 19:00:00.000542 NTP: Sun Apr 26 19:00:00 2015
ERR 20:00:00.000610 NTP: Sun Apr 26 20:00:00 2015
ERR 21:00:00.000259 NTP: Sun Apr 26 21:00:00 2015
ERR 22:00:00.000310 NTP: Sun Apr 26 22:00:00 2015
ERR 23:00:00.000549 NTP: Sun Apr 26 23:00:00 2015
ERR 00:00:00.000296 NTP: Mon Apr 27 00:00:00 2015
ERR 01:00:00.000254 NTP: Mon Apr 27 01:00:00 2015
ERR 02:00:00.003044 NTP: Mon Apr 27 02:00:00 2015
ERR 03:00:00.000550 NTP: Mon Apr 27 03:00:00 2015
ERR 04:00:00.000252 NTP: Mon Apr 27 04:00:00 2015
ERR 05:00:00.000547 NTP: Mon Apr 27 05:00:00 2015
ERR 06:00:00.000558 NTP: Mon Apr 27 06:00:00 2015
ERR 07:00:00.000562 NTP: Mon Apr 27 07:00:00 2015
WRN 07:01:24.880461 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateSpeakerOffHook Event = EventSetSpeakerMode
ERR 07:01:27.075754 DSP: wcTrans*** Invalid response 5
ERR 07:01:27.076535 DSP: Tone*** Connect/disconnect fails: -1
WRN 07:01:27.304039 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventSetSpeakerModeOff
WRN 07:01:27.305343 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventEndcall
NOT 07:02:34.011721 CDP-D: PHY 1 --> 100 MB LINK IS UP
ERR 07:02:34.012787 CDP-D: ----lldpProtoInfo[1].enableState 1
NOT 07:02:34.017093 PAE: SIGIPCFG received...
NOT 07:02:34.018657 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 07:02:34.019753 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 07:02:34.024268 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 07:02:34.028193 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 07:02:34.035154 PAE: SIGIPCFG received...
NOT 07:02:34.037455 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 07:02:34.038505 PAE: link-1: DOWN-->UP
NOT 07:02:34.042912 tftpClient: request server 0 ---> 192.168.3.1
NOT 07:02:34.059635 tftpClient: request server 1 --->
NOT 07:02:34.071814 tftpClient: request server 0 ---> 192.168.3.1
NOT 07:02:34.073802 ESP: server 0 = 192.168.3.1
NOT 07:02:34.087692 tftpClient: request server 1 --->
NOT 07:02:34.089608 ESP: server 1 =
NOT 07:02:34.091693 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 07:02:34.121500 tftpClient: request server 0 ---> 192.168.3.1
WRN 07:02:34.124319 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 07:02:34.128304 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 07:02:34.134901 ESP: server 0 = 192.168.3.1
NOT 07:02:34.139326 tftpClient: request server 0 ---> 192.168.3.1
NOT 07:02:34.141116 tftpClient: request server 1 --->
NOT 07:02:34.142033 ESP: server 1 =
NOT 07:02:34.159080 tftpClient: request server 1 --->
NOT 07:02:35.021563 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 07:02:36.021519 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 07:02:37.021496 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 07:04:36.897784 DSP: ====== A phone call starts ....
NOT 07:04:36.898742 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 60773, 32442, 3759; tx = 46258, 4
NOT 07:04:36.899352 DSP: MIB2- ipInDelivers= 85446, udpInDG= 22736, udpOutDG= 22863, udpNoPort= 24687, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 07:04:36.899897 DSP: STREAM- OpenEgressChan- ChanType 1, local (multicast host 0, port 0), MedType 12, Period 20, stream (102, 954) mix (1, 3)
NOT 07:04:36.900505 DSP: STREAM- OpenEgressChan --> local port x0, reserved port x0, --> Chan 0
NOT 07:04:36.901787 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:100
NOT 07:04:36.906200 DSP: TRSTREAM, isrEgressReqDiscardpreStreaming 0
NOT 07:04:36.913640 DSP: ***MediaTerminationStopTone ignored, nonmatched call reference- new 954, current tone 952
NOT 07:04:36.920422 DSP: STREAM- OpenIngressChan- ChanType 1, Remote (host c0a80301, port 7d0), medType 12, Period 20, VAD 0, TOS b8, stream (102, 954) --> chan 0
NOT 07:04:36.921536 DSP: STREAM- OpenIngressChan- mix (1, 3), dtmfpayloadtype 0
NOT 07:04:36.922206 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:84
WRN 07:04:37.249223 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateHandsetOffHook Event = EventSetSpeakerMode
NOT 07:46:51.747422 DSP: STREAM- CloseEgressChan- ChanType 1, stream (102, 954) --> Chan 0
NOT 07:46:51.754521 DSP: Added back for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:59
NOT 07:46:51.755688 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 188905, 32792, 3802; tx = 174003, 4
NOT 07:46:51.756312 DSP: MIB2- ipInDelivers= 213856, udpInDG= 149416, udpOutDG= 149607, udpNoPort= 24965, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 07:46:51.765178 DSP: STREAM- CloseIngressChan- ChanType 1, stream (102, 954) --> Chan 0
NOT 07:46:51.769037 DSP: Added back for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:75
NOT 07:46:51.836183 DSP: ***MediaTerminationStopTone ignored, nonmatched call reference- new 954, current tone 952
NOT 07:51:22.849354 DSP: ====== A phone call starts ....
NOT 07:51:22.849883 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 188969, 32826, 3806; tx = 174038, 4
NOT 07:51:22.850333 DSP: MIB2- ipInDelivers= 213948, udpInDG= 149416, udpOutDG= 149608, udpNoPort= 24993, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 07:51:22.850541 DSP: STREAM- OpenEgressChan- ChanType 1, local (multicast host 0, port 0), MedType 12, Period 20, stream (102, 981) mix (1, 3)
NOT 07:51:22.850726 DSP: STREAM- OpenEgressChan --> local port x0, reserved port x0, --> Chan 0
NOT 07:51:22.851644 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:100
NOT 07:51:22.854347 DSP: TRSTREAM, isrEgressReqDiscardpreStreaming 0
NOT 07:51:22.861525 DSP: ***MediaTerminationStopTone ignored, nonmatched call reference- new 981, current tone 952
NOT 07:51:22.867677 DSP: STREAM- OpenIngressChan- ChanType 1, Remote (host c0a80301, port 7d0), medType 12, Period 20, VAD 0, TOS b8, stream (102, 981) --> chan 0
NOT 07:51:22.867954 DSP: STREAM- OpenIngressChan- mix (1, 3), dtmfpayloadtype 0
NOT 07:51:22.868188 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:84
WRN 07:51:23.134597 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateHandsetOffHook Event = EventSetSpeakerMode
NOT 07:57:16.021218 DSP: STREAM- CloseEgressChan- ChanType 1, stream (102, 981) --> Chan 0
NOT 07:57:16.025786 DSP: Added back for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:59
NOT 07:57:16.026601 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 206763, 32885, 3812; tx = 191819, 4
NOT 07:57:16.026848 DSP: MIB2- ipInDelivers= 231784, udpInDG= 166992, udpOutDG= 167266, udpNoPort= 25035, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 07:57:16.033397 DSP: STREAM- CloseIngressChan- ChanType 1, stream (102, 981) --> Chan 0
NOT 07:57:16.035196 DSP: Added back for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:75
NOT 07:57:16.079280 DSP: ***MediaTerminationStopTone ignored, nonmatched call reference- new 981, current tone 952
WRN 07:57:16.348662 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateHandsetOffHook Event = EventSetSpeakerModeOff
ERR 08:00:00.000551 NTP: Mon Apr 27 08:00:00 2015
NOT 08:08:29.088320 DSP: ====== A phone call starts ....
NOT 08:08:29.088852 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 206900, 32981, 3823; tx = 191897, 4
NOT 08:08:29.089108 DSP: MIB2- ipInDelivers= 231992, udpInDG= 166992, udpOutDG= 167266, udpNoPort= 25106, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 08:08:29.089288 DSP: STREAM- OpenEgressChan- ChanType 1, local (multicast host 0, port 0), MedType 12, Period 20, stream (102, 1002) mix (1, 3)
NOT 08:08:29.089479 DSP: STREAM- OpenEgressChan --> local port x0, reserved port x0, --> Chan 0
NOT 08:08:29.090461 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:100
NOT 08:08:29.092180 DSP: TRSTREAM, isrEgressReqDiscardpreStreaming 0
NOT 08:08:29.119488 DSP: ***MediaTerminationStopTone ignored, nonmatched call reference- new 1002, current tone 952
NOT 08:08:29.125614 DSP: STREAM- OpenIngressChan- ChanType 1, Remote (host c0a80301, port 7d0), medType 12, Period 20, VAD 0, TOS b8, stream (102, 1002) --> chan 0
NOT 08:08:29.125894 DSP: STREAM- OpenIngressChan- mix (1, 3), dtmfpayloadtype 0
NOT 08:08:29.126128 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:84
WRN 08:08:29.385421 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateSpeakerOffHook Event = EventSetSpeakerMode
ERR 08:11:13.357583 DSP: wcTrans*** Invalid response 5
ERR 08:11:13.359053 DSP: Tone*** Connect/disconnect fails: -1
ERR 08:11:14.528223 DSP: wcTrans*** Invalid response 5
ERR 08:11:14.528996 DSP: Tone*** Connect/disconnect fails: -1
NOT 08:17:26.863577 DSP: STREAM- CloseEgressChan- ChanType 1, stream (102, 1002) --> Chan 0
NOT 08:17:26.866951 DSP: Added back for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:59
NOT 08:17:26.867761 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 234026, 33094, 3832; tx = 218994, 4
NOT 08:17:26.868007 DSP: MIB2- ipInDelivers= 259180, udpInDG= 193796, udpOutDG= 194153, udpNoPort= 25168, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 08:17:26.877760 DSP: STREAM- CloseIngressChan- ChanType 1, stream (102, 1002) --> Chan 0
NOT 08:17:26.880875 DSP: Added back for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:75
NOT 08:17:26.916874 DSP: ***MediaTerminationStopTone ignored, nonmatched call reference- new 1002, current tone 952
WRN 08:17:27.182874 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventSetSpeakerModeOff
WRN 08:17:27.183765 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventEndcall
WRN 08:17:30.694439 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateSpeakerOffHook Event = EventSetSpeakerMode
ERR 08:17:30.810327 DSP: wcTrans*** Invalid response 5
ERR 08:17:30.811148 DSP: Tone*** Connect/disconnect fails: -1
ERR 08:17:30.835311 DSP: wcTrans*** Invalid response 5
ERR 08:17:30.836087 DSP: Tone*** Connect/disconnect fails: -1
ERR 08:17:30.981952 DSP: wcTrans*** Invalid response 5
ERR 08:17:30.982735 DSP: Tone*** Connect/disconnect fails: -1
ERR 08:17:31.145062 DSP: wcTrans*** Invalid response 5
ERR 08:17:31.145840 DSP: Tone*** Connect/disconnect fails: -1
NOT 08:17:36.505616 DSP: ====== A phone call starts ....
NOT 08:17:36.506201 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 234057, 33094, 3832; tx = 219011, 4
NOT 08:17:36.506763 DSP: MIB2- ipInDelivers= 259211, udpInDG= 193796, udpOutDG= 194154, udpNoPort= 25168, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 08:17:36.507311 DSP: STREAM- OpenEgressChan- ChanType 1, local (multicast host 0, port 0), MedType 12, Period 20, stream (102, 1008) mix (1, 3)
NOT 08:17:36.507874 DSP: STREAM- OpenEgressChan --> local port x0, reserved port x0, --> Chan 0
NOT 08:17:36.509186 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:100
NOT 08:17:36.511911 DSP: TRSTREAM, isrEgressReqDiscardpreStreaming 0
NOT 08:17:36.543174 DSP: STREAM- OpenIngressChan- ChanType 1, Remote (host c0a80301, port 7d0), medType 12, Period 20, VAD 0, TOS b8, stream (102, 1008) --> chan 0
NOT 08:17:36.543808 DSP: STREAM- OpenIngressChan- mix (1, 3), dtmfpayloadtype 0
WRN 08:17:36.544395 DSP: bad ARP Add, -126
NOT 08:17:36.544890 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:84
ERR 08:17:36.555225 DSP: wcTrans*** Invalid response 5
ERR 08:17:36.556001 DSP: Tone*** Connect/disconnect fails: -1
NOT 08:36:57.274255 DSP: STREAM- CloseEgressChan- ChanType 1, stream (102, 1008) --> Chan 0
NOT 08:36:57.277425 DSP: Added back for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:59
NOT 08:36:57.278601 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 290597, 33268, 3852; tx = 277522, 4
NOT 08:36:57.279194 DSP: MIB2- ipInDelivers= 315876, udpInDG= 249649, udpOutDG= 252192, udpNoPort= 25294, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 08:36:57.287244 DSP: STREAM- CloseIngressChan- ChanType 1, stream (102, 1008) --> Chan 0
NOT 08:36:57.291079 DSP: Added back for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:75
WRN 08:36:57.615840 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventSetSpeakerModeOff
WRN 08:36:57.617087 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventEndcall
WRN 08:37:02.996608 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateSpeakerOffHook Event = EventSetSpeakerMode
ERR 08:37:03.110379 DSP: wcTrans*** Invalid response 5
ERR 08:37:03.111160 DSP: Tone*** Connect/disconnect fails: -1
ERR 08:37:03.135915 DSP: wcTrans*** Invalid response 5
ERR 08:37:03.136690 DSP: Tone*** Connect/disconnect fails: -1
ERR 08:37:03.275895 DSP: wcTrans*** Invalid response 5
ERR 08:37:03.276964 DSP: Tone*** Connect/disconnect fails: -1
ERR 08:37:03.445888 DSP: wcTrans*** Invalid response 5
ERR 08:37:03.446667 DSP: Tone*** Connect/disconnect fails: -1
NOT 08:37:06.042789 DSP: ====== A phone call starts ....
NOT 08:37:06.043334 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 290635, 33268, 3852; tx = 277539, 5
NOT 08:37:06.043896 DSP: MIB2- ipInDelivers= 315913, udpInDG= 249649, udpOutDG= 252192, udpNoPort= 25294, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 08:37:06.044476 DSP: STREAM- OpenEgressChan- ChanType 1, local (multicast host 0, port 0), MedType 12, Period 20, stream (102, 1041) mix (1, 3)
NOT 08:37:06.045032 DSP: STREAM- OpenEgressChan --> local port x0, reserved port x0, --> Chan 0
NOT 08:37:06.046320 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:100
NOT 08:37:06.048788 DSP: TRSTREAM, isrEgressReqDiscardpreStreaming 0
ERR 08:37:06.090597 DSP: wcTrans*** Invalid response 5
ERR 08:37:06.091376 DSP: Tone*** Connect/disconnect fails: -1
NOT 08:37:06.123405 DSP: STREAM- OpenIngressChan- ChanType 1, Remote (host c0a80301, port 7d0), medType 12, Period 20, VAD 0, TOS b8, stream (102, 1041) --> chan 0
NOT 08:37:06.124043 DSP: STREAM- OpenIngressChan- mix (1, 3), dtmfpayloadtype 0
NOT 08:37:06.124661 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:84
NOT 08:37:20.448882 DSP: STREAM- CloseEgressChan- ChanType 1, stream (102, 1041) --> Chan 0
NOT 08:37:20.451780 DSP: Added back for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:59
NOT 08:37:20.452983 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 290663, 33271, 3852; tx = 278266, 5
NOT 08:37:20.453579 DSP: MIB2- ipInDelivers= 315943, udpInDG= 249658, udpOutDG= 252908, udpNoPort= 25296, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 08:37:20.460855 DSP: STREAM- CloseIngressChan- ChanType 1, stream (102, 1041) --> Chan 0
NOT 08:37:20.464166 DSP: Added back for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:75
NOT 08:37:22.301417 DSP: ====== A phone call starts ....
NOT 08:37:22.301967 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 290677, 33271, 3852; tx = 278270, 6
NOT 08:37:22.302544 DSP: MIB2- ipInDelivers= 315956, udpInDG= 249658, udpOutDG= 252908, udpNoPort= 25296, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 08:37:22.303109 DSP: STREAM- OpenEgressChan- ChanType 1, local (multicast host 0, port 0), MedType 12, Period 20, stream (102, 1041) mix (1, 3)
NOT 08:37:22.303683 DSP: STREAM- OpenEgressChan --> local port x0, reserved port x0, --> Chan 0
NOT 08:37:22.305008 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:100
NOT 08:37:22.308162 DSP: TRSTREAM, isrEgressReqDiscardpreStreaming 0
NOT 08:37:22.343300 DSP: STREAM- OpenIngressChan- ChanType 1, Remote (host c0a80301, port 7d0), medType 12, Period 20, VAD 0, TOS b8, stream (102, 1041) --> chan 0
NOT 08:37:22.343938 DSP: STREAM- OpenIngressChan- mix (1, 3), dtmfpayloadtype 0
NOT 08:37:22.344551 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:84
NOT 08:37:28.815420 DSP: STREAM- CloseEgressChan- ChanType 1, stream (102, 1041) --> Chan 0
NOT 08:37:28.820765 DSP: Added back for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:59
NOT 08:37:28.821927 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 290819, 33273, 3852; tx = 278600, 6
NOT 08:37:28.822529 DSP: MIB2- ipInDelivers= 316100, udpInDG= 249774, udpOutDG= 253231, udpNoPort= 25298, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 08:37:28.829360 DSP: STREAM- CloseIngressChan- ChanType 1, stream (102, 1041) --> Chan 0
NOT 08:37:28.831867 DSP: Added back for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:75
WRN 08:37:29.157389 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventEndcall
NOT 08:37:33.137068 DSP: ====== A phone call starts ....
NOT 08:37:33.137611 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 290839, 33275, 3852; tx = 278607, 7
NOT 08:37:33.138140 DSP: MIB2- ipInDelivers= 316121, udpInDG= 249774, udpOutDG= 253232, udpNoPort= 25300, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 08:37:33.138378 DSP: STREAM- OpenEgressChan- ChanType 1, local (multicast host 0, port 0), MedType 12, Period 20, stream (102, 1046) mix (1, 3)
|=== Syslogd === Mon Apr 27 08:37:33 2015
NOT 08:37:33.138561 DSP: STREAM- OpenEgressChan --> local port x0, reserved port x0, --> Chan 0
NOT 08:37:33.139461 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:100
NOT 08:37:33.141764 DSP: TRSTREAM, isrEgressReqDiscardpreStreaming 0
NOT 08:37:33.148954 DSP: ***MediaTerminationStopTone ignored, nonmatched call reference- new 1046, current tone 1041
NOT 08:37:33.160644 DSP: STREAM- OpenIngressChan- ChanType 1, Remote (host c0a80301, port 7d0), medType 12, Period 20, VAD 0, TOS b8, stream (102, 1046) --> chan 0
NOT 08:37:33.160922 DSP: STREAM- OpenIngressChan- mix (1, 3), dtmfpayloadtype 0
NOT 08:37:33.161155 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:84
WRN 08:37:33.454878 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateSpeakerOffHook Event = EventSetSpeakerMode
NOT 08:46:27.123883 DSP: STREAM- CloseEgressChan- ChanType 1, stream (102, 1046) --> Chan 0
NOT 08:46:27.130529 DSP: Added back for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:59
NOT 08:46:27.132341 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 315755, 33352, 3861; tx = 305521, 7
NOT 08:46:27.132922 DSP: MIB2- ipInDelivers= 341094, udpInDG= 274364, udpOutDG= 279931, udpNoPort= 25357, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 08:46:27.140943 DSP: STREAM- CloseIngressChan- ChanType 1, stream (102, 1046) --> Chan 0
NOT 08:46:27.143912 DSP: Added back for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:75
NOT 08:46:27.180658 DSP: ***MediaTerminationStopTone ignored, nonmatched call reference- new 1046, current tone 1041
WRN 08:46:27.464344 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventSetSpeakerModeOff
WRN 08:46:27.465205 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventEndcall
NOT 08:49:54.266180 DSP: ***MediaTerminationStopTone ignored, nonmatched call reference- new 1068, current tone 1041
ERR 09:00:00.000305 NTP: Mon Apr 27 09:00:00 2015
WRN 09:08:25.781762 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateSpeakerOffHook Event = EventSetSpeakerMode
ERR 09:08:25.897964 DSP: wcTrans*** Invalid response 5
ERR 09:08:25.898746 DSP: Tone*** Connect/disconnect fails: -1
ERR 09:08:25.921343 DSP: wcTrans*** Invalid response 5
ERR 09:08:25.922366 DSP: Tone*** Connect/disconnect fails: -1
ERR 09:08:26.051021 DSP: wcTrans*** Invalid response 5
ERR 09:08:26.051799 DSP: Tone*** Connect/disconnect fails: -1
ERR 09:08:26.225545 DSP: wcTrans*** Invalid response 5
ERR 09:08:26.226323 DSP: Tone*** Connect/disconnect fails: -1
ERR 09:09:03.794868 DSP: wcTrans*** Invalid response 5
ERR 09:09:03.795688 DSP: Tone*** Connect/disconnect fails: -1
WRN 09:09:04.045064 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventSetSpeakerModeOff
WRN 09:09:04.046341 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventEndcall
NOT 09:41:15.011332 CDP-D: PHY 1 --> LINK IS DOWN
NOT 09:41:15.015638 PAE: SIGIPCFG received...
NOT 09:41:15.017271 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 09:41:15.018422 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 09:41:15.053583 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 09:41:15.057665 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 09:41:15.065978 PAE: SIGIPCFG received...
NOT 09:41:15.100496 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 09:41:15.101556 PAE: link-1: UP-->DOWN
NOT 09:41:15.102156 PAE: paeWritePCStatus: type 0
NOT 09:41:15.106495 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:41:15.121581 tftpClient: request server 1 --->
NOT 09:41:15.133223 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:41:15.135127 ESP: server 0 = 192.168.3.1
NOT 09:41:15.146979 tftpClient: request server 1 --->
NOT 09:41:15.148922 ESP: server 1 =
NOT 09:41:15.150909 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 09:41:15.185258 tftpClient: request server 0 ---> 192.168.3.1
WRN 09:41:15.188071 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 09:41:15.192062 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 09:41:15.198293 ESP: server 0 = 192.168.3.1
NOT 09:41:15.203144 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:41:15.204823 tftpClient: request server 1 --->
NOT 09:41:15.205734 ESP: server 1 =
NOT 09:41:15.220605 tftpClient: request server 1 --->
NOT 09:41:18.011377 CDP-D: PHY 1 --> 100 MB LINK IS UP
ERR 09:41:18.012028 CDP-D: ----lldpProtoInfo[1].enableState 1
NOT 09:41:18.015885 PAE: SIGIPCFG received...
NOT 09:41:18.017001 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 09:41:18.018142 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 09:41:18.026697 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 09:41:18.030665 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 09:41:18.037187 PAE: SIGIPCFG received...
NOT 09:41:18.038370 PAE: link-1: DOWN-->UP
NOT 09:41:18.040644 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 09:41:18.045352 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:41:18.059555 tftpClient: request server 1 --->
NOT 09:41:18.072006 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:41:18.073938 ESP: server 0 = 192.168.3.1
NOT 09:41:18.084453 tftpClient: request server 1 --->
NOT 09:41:18.087429 ESP: server 1 =
NOT 09:41:18.089122 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 09:41:18.118758 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:41:18.123824 ESP: server 0 = 192.168.3.1
WRN 09:41:18.127251 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 09:41:18.131261 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 09:41:18.138161 tftpClient: request server 1 --->
NOT 09:41:18.139070 ESP: server 1 =
NOT 09:41:18.144665 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:41:18.158227 tftpClient: request server 1 --->
NOT 09:48:35.011629 CDP-D: PHY 1 --> LINK IS DOWN
NOT 09:48:35.015875 PAE: SIGIPCFG received...
NOT 09:48:35.016992 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 09:48:35.018107 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 09:48:35.056269 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 09:48:35.061316 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 09:48:35.067886 PAE: SIGIPCFG received...
NOT 09:48:35.069152 PAE: link-1: UP-->DOWN
NOT 09:48:35.069764 PAE: paeWritePCStatus: type 0
NOT 09:48:35.101194 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 09:48:35.105960 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:48:35.120824 tftpClient: request server 1 --->
NOT 09:48:35.131281 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:48:35.133204 ESP: server 0 = 192.168.3.1
NOT 09:48:35.145929 tftpClient: request server 1 --->
NOT 09:48:35.148915 ESP: server 1 =
NOT 09:48:35.151052 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 09:48:35.182573 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:48:35.184671 ESP: server 0 = 192.168.3.1
WRN 09:48:35.188059 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 09:48:35.192413 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 09:48:35.199267 tftpClient: request server 1 --->
NOT 09:48:35.200248 ESP: server 1 =
NOT 09:48:35.205407 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:48:35.219424 tftpClient: request server 1 --->
NOT 09:48:42.014240 CDP-D: PHY 1 --> 100 MB LINK IS UP
ERR 09:48:42.014898 CDP-D: ----lldpProtoInfo[1].enableState 1
NOT 09:48:42.019313 PAE: SIGIPCFG received...
NOT 09:48:42.020973 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 09:48:42.022071 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 09:48:42.026564 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 09:48:42.030586 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 09:48:42.037489 PAE: SIGIPCFG received...
NOT 09:48:42.039806 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 09:48:42.040903 PAE: link-1: DOWN-->UP
NOT 09:48:42.045213 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:48:42.061832 tftpClient: request server 1 --->
NOT 09:48:42.073856 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:48:42.075787 ESP: server 0 = 192.168.3.1
NOT 09:48:42.087103 tftpClient: request server 1 --->
NOT 09:48:42.089208 ESP: server 1 =
NOT 09:48:42.091348 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 09:48:42.123738 tftpClient: request server 0 ---> 192.168.3.1
WRN 09:48:42.126573 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 09:48:42.130570 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 09:48:42.136984 ESP: server 0 = 192.168.3.1
NOT 09:48:42.141552 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:48:42.143276 tftpClient: request server 1 --->
NOT 09:48:42.144186 ESP: server 1 =
NOT 09:48:42.159034 tftpClient: request server 1 --->
NOT 09:48:43.024181 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 09:48:44.022364 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 09:48:45.021666 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 09:49:21.011342 CDP-D: PHY 1 --> LINK IS DOWN
NOT 09:49:21.015263 PAE: SIGIPCFG received...
NOT 09:49:21.016906 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 09:49:21.018017 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 09:49:21.052724 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 09:49:21.056707 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 09:49:21.064924 PAE: SIGIPCFG received...
NOT 09:49:21.099015 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 09:49:21.099964 PAE: link-1: UP-->DOWN
NOT 09:49:21.101006 PAE: paeWritePCStatus: type 0
NOT 09:49:21.105522 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:49:21.119953 tftpClient: request server 1 --->
NOT 09:49:21.131747 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:49:21.133726 ESP: server 0 = 192.168.3.1
NOT 09:49:21.145460 tftpClient: request server 1 --->
NOT 09:49:21.147383 ESP: server 1 =
NOT 09:49:21.149057 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 09:49:21.183325 tftpClient: request server 0 ---> 192.168.3.1
WRN 09:49:21.186123 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 09:49:21.190122 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 09:49:21.196247 ESP: server 0 = 192.168.3.1
NOT 09:49:21.201085 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:49:21.202825 tftpClient: request server 1 --->
NOT 09:49:21.203734 ESP: server 1 =
NOT 09:49:21.218285 tftpClient: request server 1 --->
NOT 09:49:24.013915 CDP-D: PHY 1 --> 100 MB LINK IS UP
ERR 09:49:24.014574 CDP-D: ----lldpProtoInfo[1].enableState 1
NOT 09:49:24.018425 PAE: SIGIPCFG received...
NOT 09:49:24.019555 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 09:49:24.021079 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 09:49:24.026792 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 09:49:24.030827 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 09:49:24.037330 PAE: SIGIPCFG received...
NOT 09:49:24.038514 PAE: link-1: DOWN-->UP
NOT 09:49:24.040850 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 09:49:24.045516 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:49:24.059742 tftpClient: request server 1 --->
NOT 09:49:24.072136 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:49:24.074040 ESP: server 0 = 192.168.3.1
NOT 09:49:24.084565 tftpClient: request server 1 --->
NOT 09:49:24.087535 ESP: server 1 =
NOT 09:49:24.089207 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 09:49:24.122102 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:49:24.124213 ESP: server 0 = 192.168.3.1
WRN 09:49:24.127633 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 09:49:24.131636 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 09:49:24.138519 tftpClient: request server 1 --->
NOT 09:49:24.139434 ESP: server 1 =
NOT 09:49:24.145096 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:49:24.158555 tftpClient: request server 1 --->
ERR 10:00:00.000616 NTP: Mon Apr 27 10:00:00 2015
ERR 11:00:00.000614 NTP: Mon Apr 27 11:00:00 2015
ERR 12:00:00.000548 NTP: Mon Apr 27 12:00:00 2015
ERR 13:00:00.000552 NTP: Mon Apr 27 13:00:00 2015
WRN 13:44:57.872720 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateHandsetOffHook Event = EventSetSpeakerMode
ERR 13:44:57.959165 DSP: wcTrans*** Invalid response 5
ERR 13:44:57.959992 DSP: Tone*** Connect/disconnect fails: -1
ERR 13:44:57.984145 DSP: wcTrans*** Invalid response 5
ERR 13:44:57.984938 DSP: Tone*** Connect/disconnect fails: -1
ERR 13:44:58.134231 DSP: wcTrans*** Invalid response 5
ERR 13:44:58.135022 DSP: Tone*** Connect/disconnect fails: -1
ERR 13:44:58.289918 DSP: wcTrans*** Invalid response 5
ERR 13:44:58.290737 DSP: Tone*** Connect/disconnect fails: -1
NOT 13:45:01.406877 DSP: ====== A phone call starts ....
NOT 13:45:01.407419 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 318838, 37087, 4159; tx = 307418, 15
NOT 13:45:01.408009 DSP: MIB2- ipInDelivers= 346129, udpInDG= 274364, udpOutDG= 279931, udpNoPort= 27317, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 13:45:01.408556 DSP: STREAM- OpenEgressChan- ChanType 1, local (multicast host 0, port 0), MedType 12, Period 20, stream (102, 1260) mix (1, 3)
NOT 13:45:01.409102 DSP: STREAM- OpenEgressChan --> local port x0, reserved port x0, --> Chan 0
NOT 13:45:01.410458 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:100
NOT 13:45:01.413883 DSP: TRSTREAM, isrEgressReqDiscardpreStreaming 0
NOT 13:45:01.429275 DSP: STREAM- OpenIngressChan- ChanType 1, Remote (host c0a80301, port 7d0), medType 12, Period 20, VAD 0, TOS b8, stream (102, 1260) --> chan 0
NOT 13:45:01.429917 DSP: STREAM- OpenIngressChan- mix (1, 3), dtmfpayloadtype 0
NOT 13:45:01.430577 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:84
ERR 13:45:01.438458 DSP: wcTrans*** Invalid response 5
ERR 13:45:01.439235 DSP: Tone*** Connect/disconnect fails: -1
NOT 13:45:40.321863 DSP: STREAM- CloseEgressChan- ChanType 1, stream (102, 1260) --> Chan 0
NOT 13:45:40.327200 DSP: Added back for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:59
NOT 13:45:40.328351 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 320545, 37095, 4160; tx = 309389, 15
NOT 13:45:40.328941 DSP: MIB2- ipInDelivers= 347838, udpInDG= 276019, udpOutDG= 281875, udpNoPort= 27319, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 13:45:40.338746 DSP: STREAM- CloseIngressChan- ChanType 1, stream (102, 1260) --> Chan 0
NOT 13:45:40.344004 DSP: Added back for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:75
WRN 13:45:40.668977 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventSetSpeakerModeOff
WRN 13:45:40.670746 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventEndcall
ERR 14:00:00.000612 NTP: Mon Apr 27 14:00:00 2015
I will check the time-zone, but i don't know which it will be used for Africa.
Thanks you for your support
04-27-2015 08:57 AM
Since the time-zone command is required for the 7942, I suspect it will resolve your trouble.
Here is a link that points to Africa's time zone. Depends on what part of Africa, but it should get you started.
http://www.timeanddate.com/time/zones/wat
Hope this helps.
04-27-2015 08:59 AM
My last posting was duplicated.
04-28-2015 01:16 AM
Hi Charles,
i have configure the timezone.
clock timezone WAT +1
below the result
YDE-LKIE-Voice-R#sh clock
09:14:28.414 WAT Tue Apr 28 2015
But the 7942 don't synchronize.
04-28-2015 09:38 AM
Hi Charles,
i have configured the ntp and the time on cisco 7942 and 7941 is ok but under observation until the end of this week.
Thanks.
04-28-2015 09:43 AM
Good to hear.
Thanks for the update.
05-04-2015 02:59 AM
After observation during 01 week, it's ok.
We can close this case.
Charles,
thank you for your support and i have appreciate your availability.
Alfred.
07-08-2015 01:58 AM
the same problem since yesterday.
i have checked the config but not change.
04-27-2015 08:05 AM
Hi Charles,
below the console logs
|=== Syslogd === Thu Feb 28 22:33:40 2008
NOT 04:33:39.997383 init: Mounting /dev/fd0a...
INF 04:33:40.175009 init: Mount succeeded.
NOT 04:33:40.212239 init: Mounting /dev/fd1a...
INF 04:33:40.228261 init: Mount succeeded.
NOT 04:33:40.231303 init: Starting espd...
NOT 04:33:40.248205 ESP: pid = 5
NOT 04:33:40.532342 init: Loading drivers from '/etc/sysdvrs.def'.
NOT 04:33:40.642535 init: Loading drivers from '/usr/local/etc/drivers.def'.
DBG 04:33:40.667913 pwr: maxPower = 6300 mwatts, alloc power = 6300
DBG 04:33:40.750422 LCDSWInit: LCD initialized
DBG 04:33:40.768743 audev: driver INSTALLED
DBG 04:33:40.812590 dsp: dirver installed, version 1A0
DBG 04:33:40.813753 LED DRIVER: Model is: 7942
NOT 04:33:40.911618 init: Extracting loadID's into environment...
NOT 04:33:40.913339 init: Starting applications from /etc/init.tab
NOT 04:33:40.915681 init: Sending termination signals to apps for pending restart.
DBG 04:33:40.985353 lcd_open: return success!
DBG 04:33:41.993052 lcd_close: return success!
NOT 04:33:41.994259 init: Starting /bin/cvw
NOT 04:33:41.996590 init: /bin/cvw started as pid=8
NOT 04:33:42.015131 SYSMSG: pid 8 (/bin/cvw) Normal Exit, status = 1
INF 04:33:42.015171 runtime = 0.020 secs
INF 04:33:42.015190 user cpu = 0.000557130 secs
INF 04:33:42.015210 system cpu = 0.014984070 secs
INF 04:33:42.015225 child user cpu = 0.000000000 secs
INF 04:33:42.015250 child sys cpu = 0.000000000 secs
INF 04:33:42.015270 sys interrupts = 0.000147080 secs for 4 interrupts
INF 04:33:42.015292 total cpu = 0.015541200 secs ( 50% utilization )
ERR 04:33:42.018303 SYSMSG: pid 9 ( /bin/cvw) Terminated by Signal->Hangup
INF 04:33:42.018339 runtime = 0.000 secs
INF 04:33:42.018357 user cpu = 0.000000000 secs
INF 04:33:42.018373 system cpu = 0.000000000 secs
INF 04:33:42.018388 child user cpu = 0.000000000 secs
INF 04:33:42.018404 child sys cpu = 0.000000000 secs
INF 04:33:42.018423 sys interrupts = 0.000000000 secs for 0 interrupts
INF 04:33:42.018443 total cpu = 0.000000000 secs ( 0% utilization )
NOT 04:33:42.021394 init: Starting /sbin/inetd
NOT 04:33:42.023708 init: /sbin/inetd started as pid=10
NOT 04:33:42.029155 INETD: pid = 10
NOT 04:33:42.046267 CDP-D: pid = 11
NOT 04:33:42.049623 PAE: pid = 12
NOT 04:33:42.051026 PAE: phone is not single port
NOT 04:33:42.053081 PAE: /tmp/pae.stat does not exist
WRN 04:33:42.054137 PAE: paeReadPCStatus: empty file
NOT 04:33:42.054611 PAE: link-0 is UP
NOT 04:33:42.055030 PAE: starting supplicant
NOT 04:33:42.055452 PAE: EV_DISABLED, ST_DISCONNECTED->ST_DISABLED
NOT 04:33:42.055884 PAE: supplicant is disabled
NOT 04:33:42.056277 PAE: paeSetLastSupStatus: LastSupStatus 0
NOT 04:33:43.040280 CDP-D: Starting CFG_COMMAND_SMSme...365051904
NOT 04:33:44.037276 DHCP: pid = 13
NOT 04:33:44.062699 CDP-D: NA power detected, max power = 6300 milliwatts
NOT 04:33:44.064509 CDP-D: Enable values LLDP:3 CDP:3
NOT 04:33:44.078626 CDP-D: PHY 0 --> 100 MB LINK IS UP
NOT 04:33:44.087550 CDP-D: vvlan changed --> New:4096 old:4096 4096
NOT 04:33:44.097536 CDP-D: vlan Configured --> New:4096 old:4096 :4096
NOT 04:33:44.098655 CDP-D: Sent SIGNINFO & SIGIPCFG
ERR 04:33:44.099310 CDP-D: ----lldpProtoInfo[0].enableState 1
NOT 04:33:44.100570 CDP-D: PHY 1 --> LINK IS DOWN
WRN 04:33:44.100924 CDP-D: PC port down sending to cdpMsgQue
NOT 04:33:44.101457 DHCP: COLDBOOT - wait 5 seconds...
NOT 04:33:44.103623 PAE: SIGIPCFG received...
NOT 04:33:44.106171 init: Starting /sbin/imgauthd
NOT 04:33:44.108223 init: /sbin/imgauthd started as pid=15
NOT 04:33:44.108430 init: Starting /sbin/image
NOT 04:33:44.110494 init: /sbin/image started as pid=16
NOT 04:33:44.111164 INETD: inetdSSH tid 42
NOT 04:33:44.112476 PAE: SIGIPCFG received...
NOT 04:33:44.115902 DNS: pid = 14
WRN 04:33:44.124325 ESP: espInfoUpdate() dropped
WRN 04:33:44.124546 ESP: espInfoUpdate() dropped
NOT 04:33:44.125156 CDP-D: catchipcfg getdhcpinfo IP: 0 Chng:0
NOT 04:33:44.129581 IMG_AUTH: Version: 3.6(1.0): TNP REL
NOT 04:33:44.129840 IMG_AUTH: model: CP-7942G, check for built-in key
NOT 04:33:44.129989 IMG_AUTH: built-in platform RELEASE key is present
NOT 04:33:44.130157 IMG_AUTH: built-in common RELEASE key is present
NOT 04:33:44.130279 IMG_AUTH: TNP, built-in keys : Platform (curr), Common (curr)
NOT 04:33:44.133107 image: [16] ver 2.0 (0.1)
NOT 04:33:44.133916 image: **Legacy TFTP Mode Specified**
NOT 04:33:44.134260 image: $.img_main.c.onNotify-IST_START
NOT 04:33:44.134455 image: $.img_main.c.onNotify-IST_CHK_JRNL
NOT 04:33:44.134565 image: $.img_main.c.parseJournalToLoad
NOT 04:33:44.135035 image: $.img_main.c.onNotify-IST_CHK_HIST
NOT 04:33:44.135456 image: $.img_main.c.checkHistToLoad
NOT 04:33:44.136771 image: $.img_archive.c.changeModeOwner
NOT 04:33:44.137361 image: Performing checksum of software load...
NOT 04:33:47.124097 image: Software load SCCP42.8-3-4SR1S.loads validated.
NOT 04:33:47.124332 image: $.img_main.c.onNotify-IST_GET_LOAD
NOT 04:33:47.124514 image: $.img_main.c.onNotify-IST_DONE
NOT 04:33:47.124819 image: Image Run Complete: status=21
NOT 04:33:47.125517 SYSMSG: pid 16 (/sbin/image) Normal Exit, status = 21
INF 04:33:47.125541 runtime = 3.020 secs
INF 04:33:47.125561 user cpu = 0.462905910 secs
NOT 04:33:47.127376 init: Starting /bin/tftpClient
NOT 04:33:47.129411 init: /bin/tftpClient started as pid=17
NOT 04:33:47.129653 init: Starting /bin/secd
NOT 04:33:47.131636 init: /bin/secd started as pid=18
NOT 04:33:47.131828 init: Starting /bin/ntp
NOT 04:33:47.133828 init: /bin/ntp started as pid=19
NOT 04:33:47.134072 init: Starting /ubin/vieo
NOT 04:33:47.136080 init: /ubin/vieo started as pid=20
NOT 04:33:47.136273 init: Starting /ubin/dsp
NOT 04:33:47.138229 init: /ubin/dsp started as pid=21
NOT 04:33:47.138470 init: Starting /bin/mkdir
NOT 04:33:47.140507 init: /bin/mkdir started as pid=22
NOT 04:33:47.582516 tftpClient: pid = 17
NOT 04:33:47.126154 CDP-D: catchipcfg getdhcpinfo IP: 0 Chng:0
NOT 04:33:47.575975 CDP-D: catchipcfg getdhcpinfo IP: 0 Chng:0
NOT 04:33:47.589413 SECD: main: Starting... Ver: 1.4(1.2) [Feb 28 2008, 22:29:46]
NOT 04:33:47.593376 NTP: [19] ver 3.0 (0.3)
NOT 04:33:47.596241 vieo: main() initializing
NOT 04:33:47.603570 DSP: Version: DSPHOST = 8.3(14.15)PSYL - enable audio output at teh end
NOT 04:33:47.603736 DSP: Version: KFactor = 0.95
WRN 04:33:47.608288 DSP: Table Substitution /ubin/dspCoefs, checksum is disabled, actual checksum = 40646
WRN 04:33:47.612564 DSP: Table Substitution /ubin/dspParms, checksum is disabled, actual checksum = 29442
WRN 04:33:47.614713 DSP: Table Substitution /ubin/dspVols, checksum is disabled, actual checksum = 51837
WRN 04:33:47.616173 DSP: Table Substitution /ubin/dspCosts, checksum is disabled, actual checksum = 215
NOT 04:33:47.677031 vieo: msg queue MQ_MT_VIEO started
NOT 04:33:47.677793 SECD: secCreateDir: dir created </usr/tmp/sec>
NOT 04:33:47.679953 SECD: initSecMode: initializing to sec mode UNKNOWN (default)
WRN 04:33:47.687598 SECD: WARN:loadCert: phone has no LSC cert
NOT 04:33:47.688178 SECD: initResources: have cert+pkey: MIC only, no LSC
NOT 04:33:47.689061 SECD: ctlInit: No CTL file: /flash0/sec/ctl/CTLFile.tlv
NOT 04:33:47.689848 SECD: initCTL: finished CTL initialization
WRN 04:33:47.690376 SECD: WARN:initCTL: ** phone has NO CTL **
WRN 04:33:47.690911 SECD: WARN:resetSecMode: ** WARN ** resetting sec mode to NONE (non-secure)
NOT 04:33:47.691976 SECD: clearCapfList: CAPF table cleared
NOT 04:33:47.692696 SECD: initCapfClnt: CAPF clnt initialized
NOT 04:33:47.705611 SECD: main: starting service...
NOT 04:33:47.709845 init: Starting /bin/mount
NOT 04:33:47.712261 init: /bin/mount started as pid=23
NOT 04:33:47.729131 init: Starting /ubin/zrun
NOT 04:33:47.731871 init: /ubin/zrun started as pid=25
NOT 04:33:47.732410 init: Starting /bin/sleep
NOT 04:33:47.734763 init: /bin/sleep started as pid=26
NOT 04:33:47.754626 zrun: Starting...
NOT 04:33:47.755665 zrun: loadCompressedFileandExecute...
INF 04:33:51.440597 zrun: execv(/tmp/sunvm.unzip/sunvm.cnu, argv)
ALT 04:33:51.669133 ESP: PC Port is not responding. Assuming link down...
ESPD still running but may be degraded...
NOT 04:33:51.670067 ESP: sending startup trigger
NOT 04:33:51.673701 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
WRN 04:33:52.317934 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 04:33:52.323212 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 04:33:52.337456 tftpClient: request server 0 ---> 192.168.3.1
NOT 04:33:52.375258 tftpClient: request server 1 --->
NOT 04:33:53.573882 SECD: setSecMode: sec mode set to NONE (was NONE)
WRN 04:33:53.606972 JVM: Setting LCD Contrast/View Angle to 16 before R2D init
WRN 04:33:53.608162 JVM: Setting LCD Contrast/View Angle to 16 before R2D init
NOT 04:33:53.743602 init: Starting /bin/umount
NOT 04:33:53.746009 init: /bin/umount started as pid=27
ERR 04:33:54.905511 JVM: Startup Module Loader|SystemManager:n/a - Encountered Property Exception while getting: device.system.targetmodules
DBG 04:33:54.977235 lcd_open: return success!
NOT 04:33:55.069066 init: Starting /bin/rmdir
NOT 04:33:55.071591 init: /bin/rmdir started as pid=28
NOT 04:33:55.078362 init: Starting /bin/settmask
NOT 04:33:55.080839 init: /bin/settmask started as pid=29
NOT 04:33:55.205233 init: Starting /bin/login
NOT 04:33:55.207645 init: /bin/login started as pid=3
NOT 04:34:01.188745 JVM: libMT:start SignOn()
NOT 04:34:01.190947 JVM: *** VIEO should already be running. NO? Start "/ubin/vieo &" now ***
NOT 04:34:01.191816 JVM: libMT: send _MTStart...
NOT 04:34:01.195356 JVM: LibMT (vieoProcess.c): registered VIEO callbacks
DBG 04:34:02.190526 audev: audioHwInit,,,
DBG 04:34:02.190892 audev: audioHwInit.
NOT 04:34:02.265292 DSP: _dspdvrStart ok, DSP bootup completed successfully
NOT 04:34:02.268757 DSP: DSP Tone/Ring DSP initialization completed successfully
NOT 04:34:02.271366 DSP: dspdvrinitEnableAudioOutput enabled = 1
NOT 04:34:02.271909 DSP: DSP INIT-*** DSP_STATE_READY***
NOT 04:34:02.273366 JVM: LibMT: MediaTerminationStart OK!
NOT 04:34:02.331775 JVM: Startup Module Loader|ComponentController:? - Initializing MVC comp module's trace mechanism
WRN 04:34:02.819091 SECD: WARN:getCertInfo: ** phone has no LSC
NOT 04:34:03.531286 DSP: configurationNumber 1, enabled 0
NOT 04:34:03.538158 DSP: mtSetDeviceBandwidth: Wideband Headset - deviceWideband=0
NOT 04:34:03.540809 DSP: mtSetDeviceBandwidth: Wideband Handset - deviceWideband=2
NOT 04:34:03.542790 DSP: mtSetG722Codec: g722enable=0
NOT 04:34:03.561075 DSP: configurationNumber 0, enabled 0
NOT 04:34:04.090393 CDP-D: configSelectVLAN: 3 OP_USE_CDP:2 oper:4 cdp:4 lldp:4096 admin:4096 mac:0:23:5e:32:f6:83
NOT 04:34:04.091002 CDP-D: CDP OP: clear cross ref
NOT 04:34:04.091421 CDP-D: getCdpExtaInfo: OP:2 Cos:0 Trust:0 lldp.idxOfInterest:-1
WRN 04:34:04.091925 CDP-D: cdpSetCos T:0 C:0
NOT 04:34:04.092360 CDP-D: CosTrust: 0 0
NOT 04:34:04.104181 CDP-D: vvlan changed --> New:4 old:4096 4
NOT 04:34:04.114149 CDP-D: vlan Configured --> New:3 old:4096 :3
NOT 04:34:04.115350 CDP-D: Sent SIGNINFO & SIGIPCFG
NOT 04:34:04.115953 CDP-D: cdpSetDhcpEnableFlg: SIGNINFO
NOT 04:34:04.226925 JVM: Startup Module Loader|cip.midp.midlet.MIDletManager:? - Initializing MIDletManager ...
NOT 04:34:04.228164 JVM: Startup Module Loader|cip.midp.midlet.MIDletManager:? - Initializing PushRegistry ...
NOT 04:34:04.731388 JVM: Startup Module Loader|cip.midp.pushregistry.e:? - Starting MIDP PushRegistry ...
NOT 04:34:04.738611 JVM: Startup Module Loader|cip.midp.pushregistry.e:? - MIDP PushRegistry started successfully.
NOT 04:34:04.739937 JVM: Startup Module Loader|cip.midp.midlet.MIDletManager:? - Initializing MIDP MemberFilter ...
NOT 04:34:04.741209 JVM: Startup Module Loader|cip.midp.midlet.MIDletManager:? - MIDletManager initialized.
NOT 04:34:04.846451 CDP-D: catchipcfg getdhcpinfo IP: 0 Chng:0
NOT 04:34:04.848746 PAE: SIGIPCFG received...
WRN 04:34:04.936453 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 04:34:04.940450 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 04:34:04.947057 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 04:34:04.950268 DHCP: DHCP enabled...
NOT 04:34:04.953362 CDP-D: catchipcfg getdhcpinfo IP: 0 Chng:0
NOT 04:34:04.954305 CDP-D: catchipcfg getdhcpinfo IP: 0 Chng:0
NOT 04:34:04.973080 DHCP: dhcpSendReq: status 0x12300000
NOT 04:34:04.973615 DHCP: Sending Request...
NOT 04:34:04.974652 PAE: SIGIPCFG received...
NOT 04:34:04.975704 DHCP: Enable
NOT 04:34:04.990413 DHCP: dhcpSendReq: status 0x12300000
NOT 04:34:04.990943 DHCP: Sending Request...
NOT 04:34:04.995798 tftpClient: request server 0 ---> 192.168.3.1
NOT 04:34:04.997027 DHCP: ACK received
NOT 04:34:04.997538 DHCP: Succeeded
NOT 04:34:05.012266 DHCP: IP Address -- 192.168.3.61
NOT 04:34:05.012792 DHCP: Subnet Mask - 255.255.255.0
NOT 04:34:05.013236 DHCP: Default Gwy - 192.168.3.1
NOT 04:34:05.013979 INETD: inetdDnsRetCmd Sending : queNum=367394816
WRN 04:34:05.014680 JVM: HTTP JNI| DNS lookup failed for proxy server:<brasyde.ringo-group.com>
NOT 04:34:05.018147 INETD: inetdDnsRetCmd finished : rc=0
NOT 04:34:05.021111 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 04:34:05.038455 PAE: SIGIPCFG received...
NOT 04:34:05.056537 tftpClient: request server 1 --->
NOT 04:34:05.147391 tftpClient: request server 0 ---> 192.168.3.1
NOT 04:34:05.168836 SECD: updateCTL: starting CTL update
NOT 04:34:05.171006 SECD: ctlRequestFile: Socket 7 connected to /usr/tmp/tftpClientSock
NOT 04:34:05.171778 SECD: ctlRequestFile: Request CTLSEPF47F353D4794.tlv
NOT 04:34:05.173995 ESP: server 0 = 192.168.3.1
NOT 04:34:05.174888 tftpClient: tftp request rcv'd from /usr/tmp/ctlSock, srcFile = CTLSEPF47F353D4794.tlv, dstFile = /usr/tmp/CTLFile.tlv
NOT 04:34:05.176196 tftpClient: auth server - tftpList[0] = 192.168.3.1
NOT 04:34:05.176710 tftpClient: look up server - 0
WRN 04:34:05.178358 SECD: WARN:lookupCTL: CTL update in progress, no old CTL, assume TFTP 192.168.3.1 NONSECURE
NOT 04:34:05.188921 tftpClient: secVal = 0xa
NOT 04:34:05.189443 tftpClient: 192.168.3.1 is a NONsecure server
NOT 04:34:05.189897 tftpClient: temp retval = SRVR_NONSECURE, keep looking
NOT 04:34:05.190378 tftpClient: retval = 10
NOT 04:34:05.190814 tftpClient: Non secure file requested
NOT 04:34:05.198140 TFTP: [4]:Requesting CTLSEPF47F353D4794.tlv from 192.168.3.1
NOT 04:34:05.202213 TFTP: [4]:Error --> No such file
NOT 04:34:05.204330 SYSMSG: pid 4 (/sbin/tftpd) Normal Exit, status = 2
INF 04:34:05.204368 runtime = 0.010 secs
INF 04:34:05.204389 user cpu = 0.000925170 secs
INF 04:34:05.204409 system cpu = 0.003299080 secs
INF 04:34:05.204425 child user cpu = 0.000000000 secs
INF 04:34:05.204441 child sys cpu = 0.000000000 secs
INF 04:34:05.204463 sys interrupts = 0.000456540 secs for 6 interrupts
INF 04:34:05.204487 total cpu = 0.004224250 secs ( 0% utilization )
NOT 04:34:05.206738 SECD: ctlRequestFile: tftp Status 2 rcv'd
NOT 04:34:05.207493 SECD: updateCTL: finished CTL update
ERR 04:34:05.208058 SECD: EROR:updateCTL: ** had NO CTL and CTL tftp FAILED** tftp-err 2
NOT 04:34:05.210552 tftpClient: request server 1 --->
NOT 04:34:05.211228 ESP: server 1 =
NOT 04:34:05.213423 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 04:34:05.218854 tftpClient: request server 0 ---> 192.168.3.1
NOT 04:34:05.219539 ESP: server 0 = 192.168.3.1
WRN 04:34:05.238117 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 04:34:05.246912 tftpClient: tftp request rcv'd from /usr/tmp/tftp, srcFile = SEPF47F353D4794.cnf.xml, dstFile = /usr/cache/SEPF47F353D4794.cnf.xml
NOT 04:34:05.248255 tftpClient: auth server - tftpList[0] = 192.168.3.1
NOT 04:34:05.248765 tftpClient: look up server - 0
WRN 04:34:05.250445 SECD: WARN:lookupCTL: ** no CTL, assume TFTP 192.168.3.1 NONSECURE
NOT 04:34:05.252375 tftpClient: secVal = 0xa
NOT 04:34:05.252873 tftpClient: 192.168.3.1 is a NONsecure server
NOT 04:34:05.253331 tftpClient: temp retval = SRVR_NONSECURE, keep looking
NOT 04:34:05.253815 tftpClient: retval = 10
NOT 04:34:05.254252 tftpClient: Secure file requested
NOT 04:34:05.254657 tftpClient: Non secure file approved -- SEPF47F353D4794.cnf.xml
NOT 04:34:05.261784 TFTP: [7]:Requesting SEPF47F353D4794.cnf.xml from 192.168.3.1
NOT 04:34:05.269721 TFTP: [7]:Finished --> rcvd 1128 bytes
WRN 04:34:05.272710 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 04:34:05.276824 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 04:34:05.450668 SECD: clearTFTPList: cleared all TFTP entries
ERR 04:34:05.681685 JVM: Startup Module Loader|cip.cfg.r:? - Delete of sshUserInfo file failed
ERR 04:34:05.683088 JVM: Startup Module Loader|cip.setg.ScreenSaveProperty:? - Config file field <displayOnTime> is incorrectly formatted. Defaulting.
ERR 04:34:05.684736 JVM: Startup Module Loader|cip.setg.ScreenSaveProperty:? - Config file field <displayIdleTimeout> is incorrectly formatted. Defaulting.
NOT 04:34:05.689857 SECD: setSecMode: sec mode set to NONE (was NONE)
NOT 04:34:05.874798 SECD: clearSRSTList: cleared all SRST entries
WRN 04:34:05.964836 SECD: WARN:cancelCapfOp: CAPF not in use, user cancel ignored
NOT 04:34:05.965412 SECD: clearCapfList: CAPF table cleared
ERR 04:34:05.967486 JVM: GETHOSTBYNAME: Empty Parameter
ERR 04:34:05.969371 SECD: EROR:addCapfEntry: phone has no CTL, can't use CAPF
NOT 04:34:06.000624 SECD: setSecMode: sec mode set to NONE (was NONE)
NOT 04:34:06.089357 JVM: Startup Module Loader|cip.cfg.r:? - DELETE ConfigFile:(scratchpad/SEPF47F353D4794.cnf.xml)WAS SUCCESSFUL
NOT 04:34:06.091403 CDP-D: cdpSetRepeater 11
NOT 04:34:06.092161 CDP-D: set pc vvlan access --> 26
NOT 04:34:06.116033 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 04:34:06.133323 DNS: SIGHUP received...
NOT 04:34:06.135695 PAE: SIGIPCFG received...
NOT 04:34:06.139927 tftpClient: request server 1 --->
NOT 04:34:06.145600 ESP: server 1 =
NOT 04:34:06.147534 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 04:34:06.152584 tftpClient: request server 0 ---> 192.168.3.1
NOT 04:34:06.153238 tftpClient: tftp request rcv'd from /usr/tmp/tftp, srcFile = English_United_States/mk-sccp.jar, dstFile = /usr/ram/L10N507694455
NOT 04:34:06.155375 tftpClient: auth server - tftpList[0] = 192.168.3.1
NOT 04:34:06.155890 tftpClient: look up server - 0
WRN 04:34:06.157517 SECD: WARN:lookupCTL: ** no CTL, assume TFTP 192.168.3.1 NONSECURE
NOT 04:34:06.159527 tftpClient: secVal = 0xa
NOT 04:34:06.160444 tftpClient: 192.168.3.1 is a NONsecure server
NOT 04:34:06.160946 tftpClient: temp retval = SRVR_NONSECURE, keep looking
NOT 04:34:06.161404 tftpClient: retval = 10
NOT 04:34:06.161832 tftpClient: Secure file requested
NOT 04:34:06.162236 tftpClient: Non secure file approved -- English_United_States/mk-sccp.jar
NOT 04:34:06.171298 TFTP: [8]:Requesting English_United_States/mk-sccp.jar from 192.168.3.1
NOT 04:34:06.175370 TFTP: [8]:Error --> No such file
NOT 04:34:06.177480 SYSMSG: pid 8 (/sbin/tftpd) Normal Exit, status = 2
INF 04:34:06.177518 runtime = 0.010 secs
INF 04:34:06.177538 user cpu = 0.000925150 secs
INF 04:34:06.177557 system cpu = 0.003032140 secs
INF 04:34:06.177572 child user cpu = 0.000000000 secs
INF 04:34:06.177588 child sys cpu = 0.000000000 secs
INF 04:34:06.177610 sys interrupts = 0.000466040 secs for 7 interrupts
INF 04:34:06.177633 total cpu = 0.003957290 secs ( 0% utilization )
WRN 04:34:06.268256 JVM: Startup Module Loader|cip.l10n.UserLocaleProperty:? - Unable to process LocaleProperty 'device.settings.config.localization.userlocale'
NOT 04:34:06.293630 tftpClient: request server 1 --->
NOT 04:34:06.324025 tftpClient: request server 0 ---> 192.168.3.1
NOT 04:34:06.324625 tftpClient: tftp request rcv'd from /usr/tmp/tftp, srcFile = United_States/g3-tones.xml, dstFile = /usr/ram/L10N421284252
NOT 04:34:06.325659 ESP: server 0 = 192.168.3.1
WRN 04:34:06.344547 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 04:34:06.348579 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 04:34:06.354949 tftpClient: auth server - tftpList[0] = 192.168.3.1
NOT 04:34:06.355506 tftpClient: look up server - 0
WRN 04:34:06.357152 SECD: WARN:lookupCTL: ** no CTL, assume TFTP 192.168.3.1 NONSECURE
NOT 04:34:06.359088 tftpClient: secVal = 0xa
NOT 04:34:06.359605 tftpClient: 192.168.3.1 is a NONsecure server
NOT 04:34:06.360474 tftpClient: temp retval = SRVR_NONSECURE, keep looking
|=== Syslogd === Fri Feb 29 04:34:06 2008
NOT 04:34:06.361927 tftpClient: retval = 10
NOT 04:34:06.362383 tftpClient: Secure file requested
NOT 04:34:06.362777 tftpClient: Non secure file approved -- United_States/g3-tones.xml
NOT 04:34:06.369635 TFTP: [9]:Requesting United_States/g3-tones.xml from 192.168.3.1
NOT 04:34:06.373610 TFTP: [9]:Error --> No such file
NOT 04:34:06.375722 SYSMSG: pid 9 (/sbin/tftpd) Normal Exit, status = 2
INF 04:34:06.375760 runtime = 0.010 secs
INF 04:34:06.375780 user cpu = 0.000927180 secs
INF 04:34:06.375799 system cpu = 0.003994820 secs
INF 04:34:06.375815 child user cpu = 0.000000000 secs
INF 04:34:06.375832 child sys cpu = 0.000000000 secs
INF 04:34:06.375853 sys interrupts = 0.000437110 secs for 6 interrupts
INF 04:34:06.375876 total cpu = 0.004922000 secs ( 0% utilization )
WRN 04:34:06.468681 JVM: Startup Module Loader|cip.l10n.NetworkLocaleProperty:? - Unable to process LocaleProperty 'device.settings.config.localization.networklocale'
WRN 04:34:06.533211 SECD: WARN:lookupCTL: ** no CTL, assume CCM 192.168.3.1 NONSECURE
NOT 04:34:06.611377 tftpClient: request server 1 --->
NOT 04:34:06.612659 ESP: server 1 =
NOT 04:34:06.633584 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 04:34:06.638945 tftpClient: request server 0 ---> 192.168.3.1
NOT 04:34:06.654619 tftpClient: request server 1 --->
NOT 04:34:06.655617 INETD: inetdDnsRetCmd Sending : queNum=367394816
NOT 04:34:06.656587 INETD: inetdDnsRetCmd finished : rc=0
NOT 04:34:06.697116 tftpClient: request server 0 ---> 192.168.3.1
NOT 04:34:06.705256 ESP: server 0 = 192.168.3.1
NOT 04:34:06.706839 INETD: inetdDnsRetCmd Sending : queNum=367394816
NOT 04:34:06.707796 INETD: inetdDnsRetCmd finished : rc=0
NOT 04:34:06.709763 tftpClient: request server 1 --->
NOT 04:34:06.710666 ESP: server 1 =
NOT 04:34:06.713066 INETD: inetdDnsRetCmd Sending : queNum=367394816
NOT 04:34:06.716067 INETD: inetdDnsRetCmd finished : rc=0
WRN 04:34:07.511924 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventServicesTxStop
WRN 04:34:07.512966 NTP: Now using non-NTP clock reference.
WRN 16:38:40.033167 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateHandsetOffHook Event = EventSetSpeakerMode
ERR 16:38:41.509720 DSP: wcTrans*** Invalid response 5
ERR 16:38:41.510534 DSP: Tone*** Connect/disconnect fails: -1
ERR 16:38:41.629712 DSP: wcTrans*** Invalid response 5
ERR 16:38:41.630462 DSP: Tone*** Connect/disconnect fails: -1
ERR 16:38:41.849733 DSP: wcTrans*** Invalid response 5
ERR 16:38:41.850863 DSP: Tone*** Connect/disconnect fails: -1
ERR 16:38:42.339664 DSP: wcTrans*** Invalid response 5
ERR 16:38:42.340431 DSP: Tone*** Connect/disconnect fails: -1
NOT 16:38:47.053485 DSP: ====== A phone call starts ....
NOT 16:38:47.054031 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 210, 259, 20; tx = 131, 4
NOT 16:38:47.054587 DSP: MIB2- ipInDelivers= 303, udpInDG= 7, udpOutDG= 9, udpNoPort= 93, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 16:38:47.055119 DSP: STREAM- OpenEgressChan- ChanType 1, local (multicast host 0, port 0), MedType 12, Period 20, stream (102, 889) mix (1, 3)
NOT 16:38:47.055726 DSP: STREAM- OpenEgressChan --> local port x0, reserved port x0, --> Chan 0
NOT 16:38:47.057017 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:100
NOT 16:38:47.059392 DSP: TRSTREAM, isrEgressReqDiscardpreStreaming 0
NOT 16:38:47.095430 DSP: STREAM- OpenIngressChan- ChanType 1, Remote (host c0a80301, port 7d0), medType 12, Period 20, VAD 0, TOS b8, stream (102, 889) --> chan 0
NOT 16:38:47.096061 DSP: STREAM- OpenIngressChan- mix (1, 3), dtmfpayloadtype 0
NOT 16:38:47.096718 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:84
ERR 16:38:47.104730 DSP: wcTrans*** Invalid response 5
ERR 16:38:47.105427 DSP: Tone*** Connect/disconnect fails: -1
NOT 16:43:57.878610 DSP: STREAM- CloseEgressChan- ChanType 1, stream (102, 889) --> Chan 0
NOT 16:43:57.882538 DSP: Added back for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:59
NOT 16:43:57.883710 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 15905, 306, 25; tx = 15813, 4
NOT 16:43:57.884346 DSP: MIB2- ipInDelivers= 16032, udpInDG= 15500, udpOutDG= 15548, udpNoPort= 127, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 16:43:57.892624 DSP: STREAM- CloseIngressChan- ChanType 1, stream (102, 889) --> Chan 0
NOT 16:43:57.896041 DSP: Added back for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:75
WRN 16:43:58.245752 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventSetSpeakerModeOff
WRN 16:43:58.247026 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventEndcall
NOT 16:47:12.337663 DSP: ====== A phone call starts ....
NOT 16:47:12.338629 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 15955, 327, 28; tx = 15841, 4
NOT 16:47:12.339197 DSP: MIB2- ipInDelivers= 16103, udpInDG= 15500, udpOutDG= 15549, udpNoPort= 148, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 16:47:12.339753 DSP: STREAM- OpenEgressChan- ChanType 1, local (multicast host 0, port 0), MedType 12, Period 20, stream (102, 890) mix (1, 3)
NOT 16:47:12.340409 DSP: STREAM- OpenEgressChan --> local port x0, reserved port x0, --> Chan 0
NOT 16:47:12.341708 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:100
NOT 16:47:12.346769 DSP: TRSTREAM, isrEgressReqDiscardpreStreaming 0
NOT 16:47:12.365969 DSP: ***MediaTerminationStopTone ignored, nonmatched call reference- new 890, current tone 889
NOT 16:47:12.373519 DSP: STREAM- OpenIngressChan- ChanType 1, Remote (host c0a80301, port 7d0), medType 12, Period 20, VAD 0, TOS b8, stream (102, 890) --> chan 0
NOT 16:47:12.374188 DSP: STREAM- OpenIngressChan- mix (1, 3), dtmfpayloadtype 0
NOT 16:47:12.374816 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:84
WRN 16:47:12.703870 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateHandsetOffHook Event = EventSetSpeakerMode
NOT 16:49:38.652767 DSP: STREAM- CloseEgressChan- ChanType 1, stream (102, 890) --> Chan 0
NOT 16:49:38.658016 DSP: Added back for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:59
NOT 16:49:38.658815 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 23296, 348, 31; tx = 23227, 4
NOT 16:49:38.659054 DSP: MIB2- ipInDelivers= 23463, udpInDG= 22736, udpOutDG= 22863, udpNoPort= 167, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 16:49:38.666407 DSP: STREAM- CloseIngressChan- ChanType 1, stream (102, 890) --> Chan 0
NOT 16:49:38.668071 DSP: Added back for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:75
NOT 16:49:38.702531 DSP: ***MediaTerminationStopTone ignored, nonmatched call reference- new 890, current tone 889
WRN 16:49:38.993265 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventSetSpeakerModeOff
WRN 16:49:38.994169 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventEndcall
ERR 17:00:00.000248 NTP: Fri Apr 24 17:00:00 2015
ERR 18:00:00.000259 NTP: Fri Apr 24 18:00:00 2015
NOT 18:05:51.015857 PAE: SIGIPCFG received...
NOT 18:05:51.017486 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
WRN 18:05:51.052478 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:05:51.056595 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:05:51.063739 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 18:05:51.098703 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 18:05:51.103702 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:05:51.118072 tftpClient: request server 1 --->
NOT 18:05:51.129840 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:05:51.131772 ESP: server 0 = 192.168.3.1
NOT 18:05:51.143723 tftpClient: request server 1 --->
NOT 18:05:51.145620 ESP: server 1 =
WRN 18:05:51.175866 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:05:51.179808 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:05:51.189740 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:05:51.205837 tftpClient: request server 1 --->
NOT 18:05:52.013985 CDP-D: PHY 1 --> 100 MB LINK IS UP
ERR 18:05:52.014629 CDP-D: ----lldpProtoInfo[1].enableState 1
NOT 18:05:52.019059 PAE: SIGIPCFG received...
NOT 18:05:52.021058 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:05:52.022198 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 18:05:52.026662 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:05:52.030622 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:05:52.037177 PAE: SIGIPCFG received...
NOT 18:05:52.039506 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 18:05:52.041106 PAE: link-1: DOWN-->UP
NOT 18:05:52.045446 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:05:52.062052 tftpClient: request server 1 --->
NOT 18:05:52.073894 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:05:52.075803 ESP: server 0 = 192.168.3.1
NOT 18:05:52.087418 tftpClient: request server 1 --->
NOT 18:05:52.089357 ESP: server 1 =
NOT 18:05:52.091101 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:05:52.123982 tftpClient: request server 0 ---> 192.168.3.1
WRN 18:05:52.126841 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:05:52.130844 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:05:52.137042 ESP: server 0 = 192.168.3.1
NOT 18:05:52.142015 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:05:52.143710 tftpClient: request server 1 --->
NOT 18:05:52.144609 ESP: server 1 =
NOT 18:05:52.161602 tftpClient: request server 1 --->
NOT 18:05:53.024467 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 18:05:54.022642 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 18:05:55.021937 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 18:20:40.011680 CDP-D: PHY 1 --> LINK IS DOWN
NOT 18:20:40.016008 PAE: SIGIPCFG received...
NOT 18:20:40.017641 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:20:40.018742 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 18:20:40.056692 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:20:40.060700 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:20:40.067382 PAE: SIGIPCFG received...
NOT 18:20:40.100111 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 18:20:40.101167 PAE: link-1: UP-->DOWN
NOT 18:20:40.101765 PAE: paeWritePCStatus: type 0
NOT 18:20:40.106048 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:20:40.120971 tftpClient: request server 1 --->
NOT 18:20:40.132847 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:20:40.134775 ESP: server 0 = 192.168.3.1
NOT 18:20:40.148513 tftpClient: request server 1 --->
NOT 18:20:40.152560 ESP: server 1 =
NOT 18:20:40.154271 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:20:40.184068 tftpClient: request server 0 ---> 192.168.3.1
WRN 18:20:40.186896 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:20:40.190896 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:20:40.197283 ESP: server 0 = 192.168.3.1
NOT 18:20:40.201801 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:20:40.203482 tftpClient: request server 1 --->
NOT 18:20:40.204391 ESP: server 1 =
NOT 18:20:40.219333 tftpClient: request server 1 --->
NOT 18:23:53.011737 CDP-D: PHY 1 --> 100 MB LINK IS UP
ERR 18:23:53.012806 CDP-D: ----lldpProtoInfo[1].enableState 1
NOT 18:23:53.016970 PAE: SIGIPCFG received...
NOT 18:23:53.018540 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:23:53.019647 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 18:23:53.026680 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:23:53.030684 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:23:53.037647 PAE: SIGIPCFG received...
NOT 18:23:53.039995 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 18:23:53.041015 PAE: link-1: DOWN-->UP
NOT 18:23:53.045347 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:23:53.062100 tftpClient: request server 1 --->
NOT 18:23:53.074236 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:23:53.076130 ESP: server 0 = 192.168.3.1
NOT 18:23:53.087443 tftpClient: request server 1 --->
NOT 18:23:53.089357 ESP: server 1 =
NOT 18:23:53.091485 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:23:53.123849 tftpClient: request server 0 ---> 192.168.3.1
WRN 18:23:53.126643 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:23:53.130637 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:23:53.137104 ESP: server 0 = 192.168.3.1
NOT 18:23:53.141559 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:23:53.143257 tftpClient: request server 1 --->
NOT 18:23:53.144163 ESP: server 1 =
NOT 18:23:53.161138 tftpClient: request server 1 --->
NOT 18:23:54.021596 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 18:23:55.021509 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 18:23:56.021495 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 18:24:46.011333 CDP-D: PHY 1 --> LINK IS DOWN
NOT 18:24:46.015205 PAE: SIGIPCFG received...
NOT 18:24:46.016839 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:24:46.017940 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 18:24:46.056026 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:24:46.060070 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:24:46.067041 PAE: SIGIPCFG received...
NOT 18:24:46.099292 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 18:24:46.100837 PAE: link-1: UP-->DOWN
NOT 18:24:46.101450 PAE: paeWritePCStatus: type 0
NOT 18:24:46.105836 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:24:46.120662 tftpClient: request server 1 --->
NOT 18:24:46.132152 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:24:46.134116 ESP: server 0 = 192.168.3.1
NOT 18:24:46.145923 tftpClient: request server 1 --->
NOT 18:24:46.147839 ESP: server 1 =
NOT 18:24:46.149526 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:24:46.184359 tftpClient: request server 0 ---> 192.168.3.1
WRN 18:24:46.187173 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:24:46.191191 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:24:46.197312 ESP: server 0 = 192.168.3.1
NOT 18:24:46.202251 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:24:46.203945 tftpClient: request server 1 --->
NOT 18:24:46.204889 ESP: server 1 =
NOT 18:24:46.219394 tftpClient: request server 1 --->
NOT 18:26:38.011394 CDP-D: PHY 1 --> 100 MB LINK IS UP
ERR 18:26:38.012463 CDP-D: ----lldpProtoInfo[1].enableState 1
NOT 18:26:38.016647 PAE: SIGIPCFG received...
NOT 18:26:38.018210 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:26:38.019311 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 18:26:38.026653 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:26:38.030639 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:26:38.037307 PAE: SIGIPCFG received...
NOT 18:26:38.039604 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 18:26:38.041053 PAE: link-1: DOWN-->UP
NOT 18:26:38.045398 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:26:38.062240 tftpClient: request server 1 --->
NOT 18:26:38.073909 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:26:38.075841 ESP: server 0 = 192.168.3.1
NOT 18:26:38.087586 tftpClient: request server 1 --->
NOT 18:26:38.089492 ESP: server 1 =
NOT 18:26:38.091331 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:26:38.123904 tftpClient: request server 0 ---> 192.168.3.1
WRN 18:26:38.126707 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:26:38.130740 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:26:38.136891 ESP: server 0 = 192.168.3.1
NOT 18:26:38.141849 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:26:38.143525 tftpClient: request server 1 --->
NOT 18:26:38.144434 ESP: server 1 =
NOT 18:26:38.161684 tftpClient: request server 1 --->
NOT 18:26:39.011642 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 18:26:40.012378 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 18:26:41.011650 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 18:35:29.011325 CDP-D: PHY 1 --> LINK IS DOWN
NOT 18:35:29.015632 PAE: SIGIPCFG received...
NOT 18:35:29.017274 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:35:29.018374 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 18:35:29.054142 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:35:29.058089 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:35:29.065122 PAE: SIGIPCFG received...
NOT 18:35:29.099975 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 18:35:29.101394 PAE: link-1: UP-->DOWN
NOT 18:35:29.102003 PAE: paeWritePCStatus: type 0
NOT 18:35:29.106363 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:35:29.121401 tftpClient: request server 1 --->
NOT 18:35:29.132924 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:35:29.134901 ESP: server 0 = 192.168.3.1
NOT 18:35:29.146587 tftpClient: request server 1 --->
NOT 18:35:29.148493 ESP: server 1 =
NOT 18:35:29.152047 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:35:29.184773 tftpClient: request server 0 ---> 192.168.3.1
WRN 18:35:29.187598 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:35:29.191611 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:35:29.197715 ESP: server 0 = 192.168.3.1
NOT 18:35:29.202609 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:35:29.204346 tftpClient: request server 1 --->
NOT 18:35:29.205241 ESP: server 1 =
NOT 18:35:29.219737 tftpClient: request server 1 --->
NOT 18:37:31.011437 CDP-D: PHY 1 --> 100 MB LINK IS UP
ERR 18:37:31.012513 CDP-D: ----lldpProtoInfo[1].enableState 1
NOT 18:37:31.016703 PAE: SIGIPCFG received...
NOT 18:37:31.018267 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:37:31.019372 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 18:37:31.024264 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:37:31.028257 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:37:31.034915 PAE: SIGIPCFG received...
NOT 18:37:31.037184 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 18:37:31.038246 PAE: link-1: DOWN-->UP
NOT 18:37:31.042971 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:37:31.059246 tftpClient: request server 1 --->
NOT 18:37:31.073902 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:37:31.075828 ESP: server 0 = 192.168.3.1
NOT 18:37:31.087507 tftpClient: request server 1 --->
NOT 18:37:31.089427 ESP: server 1 =
NOT 18:37:31.091184 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 18:37:31.137149 tftpClient: request server 0 ---> 192.168.3.1
WRN 18:37:31.139931 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 18:37:31.144211 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 18:37:31.151897 ESP: server 0 = 192.168.3.1
NOT 18:37:31.156316 tftpClient: request server 0 ---> 192.168.3.1
NOT 18:37:31.158004 tftpClient: request server 1 --->
NOT 18:37:31.158963 ESP: server 1 =
NOT 18:37:31.176496 tftpClient: request server 1 --->
NOT 18:37:32.011650 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 18:37:33.012372 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 18:37:34.011696 CDP-D: Set timer to 1 sec to send a Trigger Response.
ERR 19:00:00.000262 NTP: Fri Apr 24 19:00:00 2015
NOT 19:40:36.011326 CDP-D: PHY 1 --> LINK IS DOWN
NOT 19:40:36.015615 PAE: SIGIPCFG received...
NOT 19:40:36.017263 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 19:40:36.018406 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 19:40:36.056428 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 19:40:36.060404 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 19:40:36.067251 PAE: SIGIPCFG received...
NOT 19:40:36.098524 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 19:40:36.099592 PAE: link-1: UP-->DOWN
NOT 19:40:36.100651 PAE: paeWritePCStatus: type 0
NOT 19:40:36.105057 tftpClient: request server 0 ---> 192.168.3.1
NOT 19:40:36.119116 tftpClient: request server 1 --->
NOT 19:40:36.133721 tftpClient: request server 0 ---> 192.168.3.1
NOT 19:40:36.135610 ESP: server 0 = 192.168.3.1
NOT 19:40:36.147038 tftpClient: request server 1 --->
NOT 19:40:36.148939 ESP: server 1 =
NOT 19:40:36.152806 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
|=== Syslogd === Fri Apr 24 19:40:36 2015
NOT 19:40:36.183491 tftpClient: request server 0 ---> 192.168.3.1
WRN 19:40:36.186308 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 19:40:36.190315 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 19:40:36.196380 ESP: server 0 = 192.168.3.1
NOT 19:40:36.201283 tftpClient: request server 0 ---> 192.168.3.1
NOT 19:40:36.202962 tftpClient: request server 1 --->
NOT 19:40:36.203862 ESP: server 1 =
NOT 19:40:36.217965 tftpClient: request server 1 --->
ERR 20:00:00.000618 NTP: Fri Apr 24 20:00:00 2015
ERR 21:00:00.003098 NTP: Fri Apr 24 21:00:00 2015
ERR 22:00:00.000553 NTP: Fri Apr 24 22:00:00 2015
ERR 23:00:00.000302 NTP: Fri Apr 24 23:00:00 2015
ERR 00:00:00.000261 NTP: Sat Apr 25 00:00:00 2015
ERR 01:00:00.000255 NTP: Sat Apr 25 01:00:00 2015
ERR 02:00:00.000303 NTP: Sat Apr 25 02:00:00 2015
ERR 03:00:00.000253 NTP: Sat Apr 25 03:00:00 2015
ERR 04:00:00.000607 NTP: Sat Apr 25 04:00:00 2015
ERR 05:00:00.000559 NTP: Sat Apr 25 05:00:00 2015
ERR 06:00:00.002748 NTP: Sat Apr 25 06:00:00 2015
ERR 07:00:00.000258 NTP: Sat Apr 25 07:00:00 2015
ERR 08:00:00.000262 NTP: Sat Apr 25 08:00:00 2015
ERR 09:00:00.000300 NTP: Sat Apr 25 09:00:00 2015
ERR 10:00:00.000257 NTP: Sat Apr 25 10:00:00 2015
ERR 11:00:00.000559 NTP: Sat Apr 25 11:00:00 2015
ERR 12:00:00.000299 NTP: Sat Apr 25 12:00:00 2015
ERR 13:00:00.000257 NTP: Sat Apr 25 13:00:00 2015
ERR 14:00:00.000300 NTP: Sat Apr 25 14:00:00 2015
ERR 15:00:00.000306 NTP: Sat Apr 25 15:00:00 2015
ERR 16:00:00.000564 NTP: Sat Apr 25 16:00:00 2015
ERR 17:00:00.000265 NTP: Sat Apr 25 17:00:00 2015
ERR 18:00:00.000550 NTP: Sat Apr 25 18:00:00 2015
ERR 19:00:00.000564 NTP: Sat Apr 25 19:00:00 2015
ERR 20:00:00.002789 NTP: Sat Apr 25 20:00:00 2015
ERR 21:00:00.000255 NTP: Sat Apr 25 21:00:00 2015
ERR 22:00:00.000591 NTP: Sat Apr 25 22:00:00 2015
ERR 23:00:00.000555 NTP: Sat Apr 25 23:00:00 2015
ERR 00:00:00.000556 NTP: Sun Apr 26 00:00:00 2015
ERR 01:00:00.003074 NTP: Sun Apr 26 01:00:00 2015
ERR 02:00:00.000553 NTP: Sun Apr 26 02:00:00 2015
ERR 03:00:00.003050 NTP: Sun Apr 26 03:00:00 2015
ERR 04:00:00.000305 NTP: Sun Apr 26 04:00:00 2015
ERR 05:00:00.000247 NTP: Sun Apr 26 05:00:00 2015
ERR 06:00:00.000381 NTP: Sun Apr 26 06:00:00 2015
ERR 07:00:00.000299 NTP: Sun Apr 26 07:00:00 2015
ERR 08:00:00.000255 NTP: Sun Apr 26 08:00:00 2015
ERR 09:00:00.000551 NTP: Sun Apr 26 09:00:00 2015
ERR 10:00:00.000304 NTP: Sun Apr 26 10:00:00 2015
ERR 11:00:00.000604 NTP: Sun Apr 26 11:00:00 2015
ERR 12:00:00.000298 NTP: Sun Apr 26 12:00:00 2015
ERR 13:00:00.000265 NTP: Sun Apr 26 13:00:00 2015
ERR 14:00:00.000631 NTP: Sun Apr 26 14:00:00 2015
ERR 15:00:00.000554 NTP: Sun Apr 26 15:00:00 2015
ERR 16:00:00.000268 NTP: Sun Apr 26 16:00:00 2015
ERR 17:00:00.000262 NTP: Sun Apr 26 17:00:00 2015
ERR 18:00:00.000561 NTP: Sun Apr 26 18:00:00 2015
ERR 19:00:00.000542 NTP: Sun Apr 26 19:00:00 2015
ERR 20:00:00.000610 NTP: Sun Apr 26 20:00:00 2015
ERR 21:00:00.000259 NTP: Sun Apr 26 21:00:00 2015
ERR 22:00:00.000310 NTP: Sun Apr 26 22:00:00 2015
ERR 23:00:00.000549 NTP: Sun Apr 26 23:00:00 2015
ERR 00:00:00.000296 NTP: Mon Apr 27 00:00:00 2015
ERR 01:00:00.000254 NTP: Mon Apr 27 01:00:00 2015
ERR 02:00:00.003044 NTP: Mon Apr 27 02:00:00 2015
ERR 03:00:00.000550 NTP: Mon Apr 27 03:00:00 2015
ERR 04:00:00.000252 NTP: Mon Apr 27 04:00:00 2015
ERR 05:00:00.000547 NTP: Mon Apr 27 05:00:00 2015
ERR 06:00:00.000558 NTP: Mon Apr 27 06:00:00 2015
ERR 07:00:00.000562 NTP: Mon Apr 27 07:00:00 2015
WRN 07:01:24.880461 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateSpeakerOffHook Event = EventSetSpeakerMode
ERR 07:01:27.075754 DSP: wcTrans*** Invalid response 5
ERR 07:01:27.076535 DSP: Tone*** Connect/disconnect fails: -1
WRN 07:01:27.304039 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventSetSpeakerModeOff
WRN 07:01:27.305343 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventEndcall
NOT 07:02:34.011721 CDP-D: PHY 1 --> 100 MB LINK IS UP
ERR 07:02:34.012787 CDP-D: ----lldpProtoInfo[1].enableState 1
NOT 07:02:34.017093 PAE: SIGIPCFG received...
NOT 07:02:34.018657 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 07:02:34.019753 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 07:02:34.024268 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 07:02:34.028193 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 07:02:34.035154 PAE: SIGIPCFG received...
NOT 07:02:34.037455 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 07:02:34.038505 PAE: link-1: DOWN-->UP
NOT 07:02:34.042912 tftpClient: request server 0 ---> 192.168.3.1
NOT 07:02:34.059635 tftpClient: request server 1 --->
NOT 07:02:34.071814 tftpClient: request server 0 ---> 192.168.3.1
NOT 07:02:34.073802 ESP: server 0 = 192.168.3.1
NOT 07:02:34.087692 tftpClient: request server 1 --->
NOT 07:02:34.089608 ESP: server 1 =
NOT 07:02:34.091693 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 07:02:34.121500 tftpClient: request server 0 ---> 192.168.3.1
WRN 07:02:34.124319 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 07:02:34.128304 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 07:02:34.134901 ESP: server 0 = 192.168.3.1
NOT 07:02:34.139326 tftpClient: request server 0 ---> 192.168.3.1
NOT 07:02:34.141116 tftpClient: request server 1 --->
NOT 07:02:34.142033 ESP: server 1 =
NOT 07:02:34.159080 tftpClient: request server 1 --->
NOT 07:02:35.021563 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 07:02:36.021519 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 07:02:37.021496 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 07:04:36.897784 DSP: ====== A phone call starts ....
NOT 07:04:36.898742 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 60773, 32442, 3759; tx = 46258, 4
NOT 07:04:36.899352 DSP: MIB2- ipInDelivers= 85446, udpInDG= 22736, udpOutDG= 22863, udpNoPort= 24687, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 07:04:36.899897 DSP: STREAM- OpenEgressChan- ChanType 1, local (multicast host 0, port 0), MedType 12, Period 20, stream (102, 954) mix (1, 3)
NOT 07:04:36.900505 DSP: STREAM- OpenEgressChan --> local port x0, reserved port x0, --> Chan 0
NOT 07:04:36.901787 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:100
NOT 07:04:36.906200 DSP: TRSTREAM, isrEgressReqDiscardpreStreaming 0
NOT 07:04:36.913640 DSP: ***MediaTerminationStopTone ignored, nonmatched call reference- new 954, current tone 952
NOT 07:04:36.920422 DSP: STREAM- OpenIngressChan- ChanType 1, Remote (host c0a80301, port 7d0), medType 12, Period 20, VAD 0, TOS b8, stream (102, 954) --> chan 0
NOT 07:04:36.921536 DSP: STREAM- OpenIngressChan- mix (1, 3), dtmfpayloadtype 0
NOT 07:04:36.922206 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:84
WRN 07:04:37.249223 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateHandsetOffHook Event = EventSetSpeakerMode
NOT 07:46:51.747422 DSP: STREAM- CloseEgressChan- ChanType 1, stream (102, 954) --> Chan 0
NOT 07:46:51.754521 DSP: Added back for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:59
NOT 07:46:51.755688 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 188905, 32792, 3802; tx = 174003, 4
NOT 07:46:51.756312 DSP: MIB2- ipInDelivers= 213856, udpInDG= 149416, udpOutDG= 149607, udpNoPort= 24965, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 07:46:51.765178 DSP: STREAM- CloseIngressChan- ChanType 1, stream (102, 954) --> Chan 0
NOT 07:46:51.769037 DSP: Added back for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:75
NOT 07:46:51.836183 DSP: ***MediaTerminationStopTone ignored, nonmatched call reference- new 954, current tone 952
NOT 07:51:22.849354 DSP: ====== A phone call starts ....
NOT 07:51:22.849883 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 188969, 32826, 3806; tx = 174038, 4
NOT 07:51:22.850333 DSP: MIB2- ipInDelivers= 213948, udpInDG= 149416, udpOutDG= 149608, udpNoPort= 24993, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 07:51:22.850541 DSP: STREAM- OpenEgressChan- ChanType 1, local (multicast host 0, port 0), MedType 12, Period 20, stream (102, 981) mix (1, 3)
NOT 07:51:22.850726 DSP: STREAM- OpenEgressChan --> local port x0, reserved port x0, --> Chan 0
NOT 07:51:22.851644 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:100
NOT 07:51:22.854347 DSP: TRSTREAM, isrEgressReqDiscardpreStreaming 0
NOT 07:51:22.861525 DSP: ***MediaTerminationStopTone ignored, nonmatched call reference- new 981, current tone 952
NOT 07:51:22.867677 DSP: STREAM- OpenIngressChan- ChanType 1, Remote (host c0a80301, port 7d0), medType 12, Period 20, VAD 0, TOS b8, stream (102, 981) --> chan 0
NOT 07:51:22.867954 DSP: STREAM- OpenIngressChan- mix (1, 3), dtmfpayloadtype 0
NOT 07:51:22.868188 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:84
WRN 07:51:23.134597 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateHandsetOffHook Event = EventSetSpeakerMode
NOT 07:57:16.021218 DSP: STREAM- CloseEgressChan- ChanType 1, stream (102, 981) --> Chan 0
NOT 07:57:16.025786 DSP: Added back for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:59
NOT 07:57:16.026601 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 206763, 32885, 3812; tx = 191819, 4
NOT 07:57:16.026848 DSP: MIB2- ipInDelivers= 231784, udpInDG= 166992, udpOutDG= 167266, udpNoPort= 25035, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 07:57:16.033397 DSP: STREAM- CloseIngressChan- ChanType 1, stream (102, 981) --> Chan 0
NOT 07:57:16.035196 DSP: Added back for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:75
NOT 07:57:16.079280 DSP: ***MediaTerminationStopTone ignored, nonmatched call reference- new 981, current tone 952
WRN 07:57:16.348662 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateHandsetOffHook Event = EventSetSpeakerModeOff
ERR 08:00:00.000551 NTP: Mon Apr 27 08:00:00 2015
NOT 08:08:29.088320 DSP: ====== A phone call starts ....
NOT 08:08:29.088852 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 206900, 32981, 3823; tx = 191897, 4
NOT 08:08:29.089108 DSP: MIB2- ipInDelivers= 231992, udpInDG= 166992, udpOutDG= 167266, udpNoPort= 25106, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 08:08:29.089288 DSP: STREAM- OpenEgressChan- ChanType 1, local (multicast host 0, port 0), MedType 12, Period 20, stream (102, 1002) mix (1, 3)
NOT 08:08:29.089479 DSP: STREAM- OpenEgressChan --> local port x0, reserved port x0, --> Chan 0
NOT 08:08:29.090461 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:100
NOT 08:08:29.092180 DSP: TRSTREAM, isrEgressReqDiscardpreStreaming 0
NOT 08:08:29.119488 DSP: ***MediaTerminationStopTone ignored, nonmatched call reference- new 1002, current tone 952
NOT 08:08:29.125614 DSP: STREAM- OpenIngressChan- ChanType 1, Remote (host c0a80301, port 7d0), medType 12, Period 20, VAD 0, TOS b8, stream (102, 1002) --> chan 0
NOT 08:08:29.125894 DSP: STREAM- OpenIngressChan- mix (1, 3), dtmfpayloadtype 0
NOT 08:08:29.126128 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:84
WRN 08:08:29.385421 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateSpeakerOffHook Event = EventSetSpeakerMode
ERR 08:11:13.357583 DSP: wcTrans*** Invalid response 5
ERR 08:11:13.359053 DSP: Tone*** Connect/disconnect fails: -1
ERR 08:11:14.528223 DSP: wcTrans*** Invalid response 5
ERR 08:11:14.528996 DSP: Tone*** Connect/disconnect fails: -1
NOT 08:17:26.863577 DSP: STREAM- CloseEgressChan- ChanType 1, stream (102, 1002) --> Chan 0
NOT 08:17:26.866951 DSP: Added back for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:59
NOT 08:17:26.867761 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 234026, 33094, 3832; tx = 218994, 4
NOT 08:17:26.868007 DSP: MIB2- ipInDelivers= 259180, udpInDG= 193796, udpOutDG= 194153, udpNoPort= 25168, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 08:17:26.877760 DSP: STREAM- CloseIngressChan- ChanType 1, stream (102, 1002) --> Chan 0
NOT 08:17:26.880875 DSP: Added back for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:75
NOT 08:17:26.916874 DSP: ***MediaTerminationStopTone ignored, nonmatched call reference- new 1002, current tone 952
WRN 08:17:27.182874 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventSetSpeakerModeOff
WRN 08:17:27.183765 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventEndcall
WRN 08:17:30.694439 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateSpeakerOffHook Event = EventSetSpeakerMode
ERR 08:17:30.810327 DSP: wcTrans*** Invalid response 5
ERR 08:17:30.811148 DSP: Tone*** Connect/disconnect fails: -1
ERR 08:17:30.835311 DSP: wcTrans*** Invalid response 5
ERR 08:17:30.836087 DSP: Tone*** Connect/disconnect fails: -1
ERR 08:17:30.981952 DSP: wcTrans*** Invalid response 5
ERR 08:17:30.982735 DSP: Tone*** Connect/disconnect fails: -1
ERR 08:17:31.145062 DSP: wcTrans*** Invalid response 5
ERR 08:17:31.145840 DSP: Tone*** Connect/disconnect fails: -1
NOT 08:17:36.505616 DSP: ====== A phone call starts ....
NOT 08:17:36.506201 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 234057, 33094, 3832; tx = 219011, 4
NOT 08:17:36.506763 DSP: MIB2- ipInDelivers= 259211, udpInDG= 193796, udpOutDG= 194154, udpNoPort= 25168, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 08:17:36.507311 DSP: STREAM- OpenEgressChan- ChanType 1, local (multicast host 0, port 0), MedType 12, Period 20, stream (102, 1008) mix (1, 3)
NOT 08:17:36.507874 DSP: STREAM- OpenEgressChan --> local port x0, reserved port x0, --> Chan 0
NOT 08:17:36.509186 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:100
NOT 08:17:36.511911 DSP: TRSTREAM, isrEgressReqDiscardpreStreaming 0
NOT 08:17:36.543174 DSP: STREAM- OpenIngressChan- ChanType 1, Remote (host c0a80301, port 7d0), medType 12, Period 20, VAD 0, TOS b8, stream (102, 1008) --> chan 0
NOT 08:17:36.543808 DSP: STREAM- OpenIngressChan- mix (1, 3), dtmfpayloadtype 0
WRN 08:17:36.544395 DSP: bad ARP Add, -126
NOT 08:17:36.544890 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:84
ERR 08:17:36.555225 DSP: wcTrans*** Invalid response 5
ERR 08:17:36.556001 DSP: Tone*** Connect/disconnect fails: -1
NOT 08:36:57.274255 DSP: STREAM- CloseEgressChan- ChanType 1, stream (102, 1008) --> Chan 0
NOT 08:36:57.277425 DSP: Added back for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:59
NOT 08:36:57.278601 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 290597, 33268, 3852; tx = 277522, 4
NOT 08:36:57.279194 DSP: MIB2- ipInDelivers= 315876, udpInDG= 249649, udpOutDG= 252192, udpNoPort= 25294, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 08:36:57.287244 DSP: STREAM- CloseIngressChan- ChanType 1, stream (102, 1008) --> Chan 0
NOT 08:36:57.291079 DSP: Added back for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:75
WRN 08:36:57.615840 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventSetSpeakerModeOff
WRN 08:36:57.617087 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventEndcall
WRN 08:37:02.996608 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateSpeakerOffHook Event = EventSetSpeakerMode
ERR 08:37:03.110379 DSP: wcTrans*** Invalid response 5
ERR 08:37:03.111160 DSP: Tone*** Connect/disconnect fails: -1
ERR 08:37:03.135915 DSP: wcTrans*** Invalid response 5
ERR 08:37:03.136690 DSP: Tone*** Connect/disconnect fails: -1
ERR 08:37:03.275895 DSP: wcTrans*** Invalid response 5
ERR 08:37:03.276964 DSP: Tone*** Connect/disconnect fails: -1
ERR 08:37:03.445888 DSP: wcTrans*** Invalid response 5
ERR 08:37:03.446667 DSP: Tone*** Connect/disconnect fails: -1
NOT 08:37:06.042789 DSP: ====== A phone call starts ....
NOT 08:37:06.043334 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 290635, 33268, 3852; tx = 277539, 5
NOT 08:37:06.043896 DSP: MIB2- ipInDelivers= 315913, udpInDG= 249649, udpOutDG= 252192, udpNoPort= 25294, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 08:37:06.044476 DSP: STREAM- OpenEgressChan- ChanType 1, local (multicast host 0, port 0), MedType 12, Period 20, stream (102, 1041) mix (1, 3)
NOT 08:37:06.045032 DSP: STREAM- OpenEgressChan --> local port x0, reserved port x0, --> Chan 0
NOT 08:37:06.046320 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:100
NOT 08:37:06.048788 DSP: TRSTREAM, isrEgressReqDiscardpreStreaming 0
ERR 08:37:06.090597 DSP: wcTrans*** Invalid response 5
ERR 08:37:06.091376 DSP: Tone*** Connect/disconnect fails: -1
NOT 08:37:06.123405 DSP: STREAM- OpenIngressChan- ChanType 1, Remote (host c0a80301, port 7d0), medType 12, Period 20, VAD 0, TOS b8, stream (102, 1041) --> chan 0
NOT 08:37:06.124043 DSP: STREAM- OpenIngressChan- mix (1, 3), dtmfpayloadtype 0
NOT 08:37:06.124661 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:84
NOT 08:37:20.448882 DSP: STREAM- CloseEgressChan- ChanType 1, stream (102, 1041) --> Chan 0
NOT 08:37:20.451780 DSP: Added back for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:59
NOT 08:37:20.452983 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 290663, 33271, 3852; tx = 278266, 5
NOT 08:37:20.453579 DSP: MIB2- ipInDelivers= 315943, udpInDG= 249658, udpOutDG= 252908, udpNoPort= 25296, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 08:37:20.460855 DSP: STREAM- CloseIngressChan- ChanType 1, stream (102, 1041) --> Chan 0
NOT 08:37:20.464166 DSP: Added back for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:75
NOT 08:37:22.301417 DSP: ====== A phone call starts ....
NOT 08:37:22.301967 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 290677, 33271, 3852; tx = 278270, 6
NOT 08:37:22.302544 DSP: MIB2- ipInDelivers= 315956, udpInDG= 249658, udpOutDG= 252908, udpNoPort= 25296, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 08:37:22.303109 DSP: STREAM- OpenEgressChan- ChanType 1, local (multicast host 0, port 0), MedType 12, Period 20, stream (102, 1041) mix (1, 3)
NOT 08:37:22.303683 DSP: STREAM- OpenEgressChan --> local port x0, reserved port x0, --> Chan 0
NOT 08:37:22.305008 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:100
NOT 08:37:22.308162 DSP: TRSTREAM, isrEgressReqDiscardpreStreaming 0
NOT 08:37:22.343300 DSP: STREAM- OpenIngressChan- ChanType 1, Remote (host c0a80301, port 7d0), medType 12, Period 20, VAD 0, TOS b8, stream (102, 1041) --> chan 0
NOT 08:37:22.343938 DSP: STREAM- OpenIngressChan- mix (1, 3), dtmfpayloadtype 0
NOT 08:37:22.344551 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:84
NOT 08:37:28.815420 DSP: STREAM- CloseEgressChan- ChanType 1, stream (102, 1041) --> Chan 0
NOT 08:37:28.820765 DSP: Added back for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:59
NOT 08:37:28.821927 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 290819, 33273, 3852; tx = 278600, 6
NOT 08:37:28.822529 DSP: MIB2- ipInDelivers= 316100, udpInDG= 249774, udpOutDG= 253231, udpNoPort= 25298, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 08:37:28.829360 DSP: STREAM- CloseIngressChan- ChanType 1, stream (102, 1041) --> Chan 0
NOT 08:37:28.831867 DSP: Added back for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:75
WRN 08:37:29.157389 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventEndcall
NOT 08:37:33.137068 DSP: ====== A phone call starts ....
NOT 08:37:33.137611 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 290839, 33275, 3852; tx = 278607, 7
NOT 08:37:33.138140 DSP: MIB2- ipInDelivers= 316121, udpInDG= 249774, udpOutDG= 253232, udpNoPort= 25300, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 08:37:33.138378 DSP: STREAM- OpenEgressChan- ChanType 1, local (multicast host 0, port 0), MedType 12, Period 20, stream (102, 1046) mix (1, 3)
|=== Syslogd === Mon Apr 27 08:37:33 2015
NOT 08:37:33.138561 DSP: STREAM- OpenEgressChan --> local port x0, reserved port x0, --> Chan 0
NOT 08:37:33.139461 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:100
NOT 08:37:33.141764 DSP: TRSTREAM, isrEgressReqDiscardpreStreaming 0
NOT 08:37:33.148954 DSP: ***MediaTerminationStopTone ignored, nonmatched call reference- new 1046, current tone 1041
NOT 08:37:33.160644 DSP: STREAM- OpenIngressChan- ChanType 1, Remote (host c0a80301, port 7d0), medType 12, Period 20, VAD 0, TOS b8, stream (102, 1046) --> chan 0
NOT 08:37:33.160922 DSP: STREAM- OpenIngressChan- mix (1, 3), dtmfpayloadtype 0
NOT 08:37:33.161155 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:84
WRN 08:37:33.454878 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateSpeakerOffHook Event = EventSetSpeakerMode
NOT 08:46:27.123883 DSP: STREAM- CloseEgressChan- ChanType 1, stream (102, 1046) --> Chan 0
NOT 08:46:27.130529 DSP: Added back for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:59
NOT 08:46:27.132341 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 315755, 33352, 3861; tx = 305521, 7
NOT 08:46:27.132922 DSP: MIB2- ipInDelivers= 341094, udpInDG= 274364, udpOutDG= 279931, udpNoPort= 25357, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 08:46:27.140943 DSP: STREAM- CloseIngressChan- ChanType 1, stream (102, 1046) --> Chan 0
NOT 08:46:27.143912 DSP: Added back for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:75
NOT 08:46:27.180658 DSP: ***MediaTerminationStopTone ignored, nonmatched call reference- new 1046, current tone 1041
WRN 08:46:27.464344 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventSetSpeakerModeOff
WRN 08:46:27.465205 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventEndcall
NOT 08:49:54.266180 DSP: ***MediaTerminationStopTone ignored, nonmatched call reference- new 1068, current tone 1041
ERR 09:00:00.000305 NTP: Mon Apr 27 09:00:00 2015
WRN 09:08:25.781762 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateSpeakerOffHook Event = EventSetSpeakerMode
ERR 09:08:25.897964 DSP: wcTrans*** Invalid response 5
ERR 09:08:25.898746 DSP: Tone*** Connect/disconnect fails: -1
ERR 09:08:25.921343 DSP: wcTrans*** Invalid response 5
ERR 09:08:25.922366 DSP: Tone*** Connect/disconnect fails: -1
ERR 09:08:26.051021 DSP: wcTrans*** Invalid response 5
ERR 09:08:26.051799 DSP: Tone*** Connect/disconnect fails: -1
ERR 09:08:26.225545 DSP: wcTrans*** Invalid response 5
ERR 09:08:26.226323 DSP: Tone*** Connect/disconnect fails: -1
ERR 09:09:03.794868 DSP: wcTrans*** Invalid response 5
ERR 09:09:03.795688 DSP: Tone*** Connect/disconnect fails: -1
WRN 09:09:04.045064 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventSetSpeakerModeOff
WRN 09:09:04.046341 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventEndcall
NOT 09:41:15.011332 CDP-D: PHY 1 --> LINK IS DOWN
NOT 09:41:15.015638 PAE: SIGIPCFG received...
NOT 09:41:15.017271 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 09:41:15.018422 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 09:41:15.053583 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 09:41:15.057665 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 09:41:15.065978 PAE: SIGIPCFG received...
NOT 09:41:15.100496 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 09:41:15.101556 PAE: link-1: UP-->DOWN
NOT 09:41:15.102156 PAE: paeWritePCStatus: type 0
NOT 09:41:15.106495 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:41:15.121581 tftpClient: request server 1 --->
NOT 09:41:15.133223 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:41:15.135127 ESP: server 0 = 192.168.3.1
NOT 09:41:15.146979 tftpClient: request server 1 --->
NOT 09:41:15.148922 ESP: server 1 =
NOT 09:41:15.150909 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 09:41:15.185258 tftpClient: request server 0 ---> 192.168.3.1
WRN 09:41:15.188071 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 09:41:15.192062 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 09:41:15.198293 ESP: server 0 = 192.168.3.1
NOT 09:41:15.203144 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:41:15.204823 tftpClient: request server 1 --->
NOT 09:41:15.205734 ESP: server 1 =
NOT 09:41:15.220605 tftpClient: request server 1 --->
NOT 09:41:18.011377 CDP-D: PHY 1 --> 100 MB LINK IS UP
ERR 09:41:18.012028 CDP-D: ----lldpProtoInfo[1].enableState 1
NOT 09:41:18.015885 PAE: SIGIPCFG received...
NOT 09:41:18.017001 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 09:41:18.018142 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 09:41:18.026697 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 09:41:18.030665 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 09:41:18.037187 PAE: SIGIPCFG received...
NOT 09:41:18.038370 PAE: link-1: DOWN-->UP
NOT 09:41:18.040644 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 09:41:18.045352 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:41:18.059555 tftpClient: request server 1 --->
NOT 09:41:18.072006 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:41:18.073938 ESP: server 0 = 192.168.3.1
NOT 09:41:18.084453 tftpClient: request server 1 --->
NOT 09:41:18.087429 ESP: server 1 =
NOT 09:41:18.089122 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 09:41:18.118758 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:41:18.123824 ESP: server 0 = 192.168.3.1
WRN 09:41:18.127251 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 09:41:18.131261 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 09:41:18.138161 tftpClient: request server 1 --->
NOT 09:41:18.139070 ESP: server 1 =
NOT 09:41:18.144665 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:41:18.158227 tftpClient: request server 1 --->
NOT 09:48:35.011629 CDP-D: PHY 1 --> LINK IS DOWN
NOT 09:48:35.015875 PAE: SIGIPCFG received...
NOT 09:48:35.016992 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 09:48:35.018107 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 09:48:35.056269 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 09:48:35.061316 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 09:48:35.067886 PAE: SIGIPCFG received...
NOT 09:48:35.069152 PAE: link-1: UP-->DOWN
NOT 09:48:35.069764 PAE: paeWritePCStatus: type 0
NOT 09:48:35.101194 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 09:48:35.105960 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:48:35.120824 tftpClient: request server 1 --->
NOT 09:48:35.131281 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:48:35.133204 ESP: server 0 = 192.168.3.1
NOT 09:48:35.145929 tftpClient: request server 1 --->
NOT 09:48:35.148915 ESP: server 1 =
NOT 09:48:35.151052 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 09:48:35.182573 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:48:35.184671 ESP: server 0 = 192.168.3.1
WRN 09:48:35.188059 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 09:48:35.192413 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 09:48:35.199267 tftpClient: request server 1 --->
NOT 09:48:35.200248 ESP: server 1 =
NOT 09:48:35.205407 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:48:35.219424 tftpClient: request server 1 --->
NOT 09:48:42.014240 CDP-D: PHY 1 --> 100 MB LINK IS UP
ERR 09:48:42.014898 CDP-D: ----lldpProtoInfo[1].enableState 1
NOT 09:48:42.019313 PAE: SIGIPCFG received...
NOT 09:48:42.020973 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 09:48:42.022071 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 09:48:42.026564 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 09:48:42.030586 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 09:48:42.037489 PAE: SIGIPCFG received...
NOT 09:48:42.039806 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 09:48:42.040903 PAE: link-1: DOWN-->UP
NOT 09:48:42.045213 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:48:42.061832 tftpClient: request server 1 --->
NOT 09:48:42.073856 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:48:42.075787 ESP: server 0 = 192.168.3.1
NOT 09:48:42.087103 tftpClient: request server 1 --->
NOT 09:48:42.089208 ESP: server 1 =
NOT 09:48:42.091348 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 09:48:42.123738 tftpClient: request server 0 ---> 192.168.3.1
WRN 09:48:42.126573 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 09:48:42.130570 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 09:48:42.136984 ESP: server 0 = 192.168.3.1
NOT 09:48:42.141552 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:48:42.143276 tftpClient: request server 1 --->
NOT 09:48:42.144186 ESP: server 1 =
NOT 09:48:42.159034 tftpClient: request server 1 --->
NOT 09:48:43.024181 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 09:48:44.022364 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 09:48:45.021666 CDP-D: Set timer to 1 sec to send a Trigger Response.
NOT 09:49:21.011342 CDP-D: PHY 1 --> LINK IS DOWN
NOT 09:49:21.015263 PAE: SIGIPCFG received...
NOT 09:49:21.016906 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 09:49:21.018017 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 09:49:21.052724 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 09:49:21.056707 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 09:49:21.064924 PAE: SIGIPCFG received...
NOT 09:49:21.099015 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 09:49:21.099964 PAE: link-1: UP-->DOWN
NOT 09:49:21.101006 PAE: paeWritePCStatus: type 0
NOT 09:49:21.105522 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:49:21.119953 tftpClient: request server 1 --->
NOT 09:49:21.131747 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:49:21.133726 ESP: server 0 = 192.168.3.1
NOT 09:49:21.145460 tftpClient: request server 1 --->
NOT 09:49:21.147383 ESP: server 1 =
NOT 09:49:21.149057 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 09:49:21.183325 tftpClient: request server 0 ---> 192.168.3.1
WRN 09:49:21.186123 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 09:49:21.190122 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 09:49:21.196247 ESP: server 0 = 192.168.3.1
NOT 09:49:21.201085 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:49:21.202825 tftpClient: request server 1 --->
NOT 09:49:21.203734 ESP: server 1 =
NOT 09:49:21.218285 tftpClient: request server 1 --->
NOT 09:49:24.013915 CDP-D: PHY 1 --> 100 MB LINK IS UP
ERR 09:49:24.014574 CDP-D: ----lldpProtoInfo[1].enableState 1
NOT 09:49:24.018425 PAE: SIGIPCFG received...
NOT 09:49:24.019555 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 09:49:24.021079 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
WRN 09:49:24.026792 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 09:49:24.030827 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 09:49:24.037330 PAE: SIGIPCFG received...
NOT 09:49:24.038514 PAE: link-1: DOWN-->UP
NOT 09:49:24.040850 CDP-D: catchipcfg getdhcpinfo IP: c0a8033d Chng:1
NOT 09:49:24.045516 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:49:24.059742 tftpClient: request server 1 --->
NOT 09:49:24.072136 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:49:24.074040 ESP: server 0 = 192.168.3.1
NOT 09:49:24.084565 tftpClient: request server 1 --->
NOT 09:49:24.087535 ESP: server 1 =
NOT 09:49:24.089207 ESP: send ADMIN, logging = 1, shell = 0, ipconfig = 1
NOT 09:49:24.122102 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:49:24.124213 ESP: server 0 = 192.168.3.1
WRN 09:49:24.127633 SECD: WARN:getCTLInfo: ** phone has no CTL
WRN 09:49:24.131636 SECD: WARN:getCTLInfo: ** phone has no CTL
NOT 09:49:24.138519 tftpClient: request server 1 --->
NOT 09:49:24.139434 ESP: server 1 =
NOT 09:49:24.145096 tftpClient: request server 0 ---> 192.168.3.1
NOT 09:49:24.158555 tftpClient: request server 1 --->
ERR 10:00:00.000616 NTP: Mon Apr 27 10:00:00 2015
ERR 11:00:00.000614 NTP: Mon Apr 27 11:00:00 2015
ERR 12:00:00.000548 NTP: Mon Apr 27 12:00:00 2015
ERR 13:00:00.000552 NTP: Mon Apr 27 13:00:00 2015
WRN 13:44:57.872720 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateHandsetOffHook Event = EventSetSpeakerMode
ERR 13:44:57.959165 DSP: wcTrans*** Invalid response 5
ERR 13:44:57.959992 DSP: Tone*** Connect/disconnect fails: -1
ERR 13:44:57.984145 DSP: wcTrans*** Invalid response 5
ERR 13:44:57.984938 DSP: Tone*** Connect/disconnect fails: -1
ERR 13:44:58.134231 DSP: wcTrans*** Invalid response 5
ERR 13:44:58.135022 DSP: Tone*** Connect/disconnect fails: -1
ERR 13:44:58.289918 DSP: wcTrans*** Invalid response 5
ERR 13:44:58.290737 DSP: Tone*** Connect/disconnect fails: -1
NOT 13:45:01.406877 DSP: ====== A phone call starts ....
NOT 13:45:01.407419 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 318838, 37087, 4159; tx = 307418, 15
NOT 13:45:01.408009 DSP: MIB2- ipInDelivers= 346129, udpInDG= 274364, udpOutDG= 279931, udpNoPort= 27317, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 13:45:01.408556 DSP: STREAM- OpenEgressChan- ChanType 1, local (multicast host 0, port 0), MedType 12, Period 20, stream (102, 1260) mix (1, 3)
NOT 13:45:01.409102 DSP: STREAM- OpenEgressChan --> local port x0, reserved port x0, --> Chan 0
NOT 13:45:01.410458 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:100
NOT 13:45:01.413883 DSP: TRSTREAM, isrEgressReqDiscardpreStreaming 0
NOT 13:45:01.429275 DSP: STREAM- OpenIngressChan- ChanType 1, Remote (host c0a80301, port 7d0), medType 12, Period 20, VAD 0, TOS b8, stream (102, 1260) --> chan 0
NOT 13:45:01.429917 DSP: STREAM- OpenIngressChan- mix (1, 3), dtmfpayloadtype 0
NOT 13:45:01.430577 DSP: Subtracted for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:84
ERR 13:45:01.438458 DSP: wcTrans*** Invalid response 5
ERR 13:45:01.439235 DSP: Tone*** Connect/disconnect fails: -1
NOT 13:45:40.321863 DSP: STREAM- CloseEgressChan- ChanType 1, stream (102, 1260) --> Chan 0
NOT 13:45:40.327200 DSP: Added back for CODEC[2] G.729 or G.729B direction:0 cost:16 old budget:59
NOT 13:45:40.328351 DSP: ETHSTAT- (unicast, broadcast, multicast) rx = 320545, 37095, 4160; tx = 309389, 15
NOT 13:45:40.328941 DSP: MIB2- ipInDelivers= 347838, udpInDG= 276019, udpOutDG= 281875, udpNoPort= 27319, udpInErr= 0, icmpInDestUnreach = 0, icmpOutDestUnreach = 0
NOT 13:45:40.338746 DSP: STREAM- CloseIngressChan- ChanType 1, stream (102, 1260) --> Chan 0
NOT 13:45:40.344004 DSP: Added back for CODEC[2] G.729 or G.729B direction:1 cost:25 old budget:75
WRN 13:45:40.668977 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventSetSpeakerModeOff
WRN 13:45:40.670746 JVM: Startup Module Loader|cip.mmgr.ds:? - [MediaMgrSM]: Unhandled Event, State = StateOnHook Event = EventEndcall
ERR 14:00:00.000612 NTP: Mon Apr 27 14:00:00 2015
I will check the time-zone, but i don't know which it will be used for Africa.
Thanks you for your support
