CME/CUE - Small problem with Extension/dial-peer
fxavier.cat
Hey Pros
System: CME Router 2811 3.3+CUE Module 2.2 + 2Cards FXO(4ports each)
I have a small question about dial-peer.
i have 2 kind of extension
1. (example:10,11,12,13...)
and
11. (example:110,111,112,113,...)
But when i dial the extension 110, actually it's dialing the ext. 11
dial-peer voice 10 voip
destination-pattern 1.
session protocol sipv2
session target ipv4:192.168.140.252
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 110 voip
destination-pattern 11.
codec g711ulaw
no vad
thanks in advance
Brandon Buffin
One option would be to create one dial peer with a destination pattern of 1T, such as:
destination-pattern 1T
codec g711ulaw
no vad
CME would wait for the interdigit timeout to complete the call and send the digits. The interdigit timeout can be changed with the following commands:
telephony-service
timeouts interdigit 3 (changes timeout to 3 seconds)
Hope this helps. If so, please rate the post.
Brandon
