03-04-2013 02:58 AM
Hello Everyone,
I am new to Cisco Voice, I want to configure a cisco router "model 1751v", for the Cisco IP phone to work. Can you provide me a procedure on how to configure this router? And what are the software that needs to be loaded on router's flash memory and software/Files that needs to be loaded on the TFTP server? If i already place this topology on the production network am I still need the TFTP server?
Tnx in advance, your response is highly appreciated.
File attached: Test Topology and Router's running config
Mark,
03-07-2013 09:22 AM
Hi - Do you have a CUCM? If not, what are you using for call control.
What you inluded will not work with sccp phone loads - it might work with SIP, if you send the calls
to a SIP provider or to the fxo port, being sure to forward the needed digits.
If its a skinny phone, you will needed a callmanager or callmanager express(runs on a router) for dial plan and call control.
Hope this helps.
03-17-2013 07:03 PM
Hello Chester,
I don't know if CUCM is already installed on the router, so I just share to you the content of router flash:
# dir flash:
Directory of flash:/
1 -rw- 17037148
2 -rw- 129196
3 -rw- 680394
4 -rw- 128792
6 -rw- 1045952
7 -rw- 331101
8 -rw- 496521
9 -rw- 1908762
10 -rw- 49169
11 -rw- 333822
12 -rw- 47904
13 -rw- 4742144
14 -rw- 1006592
15 -rw- 4308
16 -rw- 642841
17 -rw- 1602
18 -rw- 617
19 -rw- 953
20 -rw- 16344
21 -rw- 864
22 -rw- 6146
23 -rw- 4658
24 -rw- 3724
25 -rw- 77200
26 -rw- 1347
27 -rw- 843
28 -rw- 174
29 -rw- 2393
30 -rw- 870
31 -rw- 9968
32 -rw- 3311
33292284 bytes total (3775816 bytes free)
BTW: I use sccp phone, CISCO IP Phone 7960.
03-18-2013 12:57 AM
12.3(14)T would be CME 3.3:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme33spc.html
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
If your 1750 meets the system requirements, yoiu can get the files here:
Follow this for configuration info:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/srnd/design/guide/cmesrnd.html
Be aware this is old saoftware.
03-19-2013 08:58 PM
Hello Chester,
Thanks for your support. I am now able to access the web based CISCO Call Manager Express page, and CISCO IPphone is not prompting "Configuring VLAN / Configuring IP address". So what i need to do next? what needs to be configure on the IP Phone and what are the configurations needed on the CME page?
Hope you can guide me through this. Tnx..
