cube as a registrar
WilfredB
Good day,
I know you can register a cube to a sip provider. I've done that before.
I also know you can register a ip phone (both sip and sccp) to a cube. I've also done that before.
The question is if you can register a cube to another cube?
And if so how?
Yes you can do this. Here is a simple config. You can add username/password
under the pool authenticate clients.
SERVER (160.160.160.160)=====
voice service voip
redirect ip2ip
sip
bind all source-interface Loopback0
registrar server
no call service stop
voice register global
max-pool 10
!!......Create register pool to define allowed IPs to register and define
parameters for dynamically created dial-peers.
voice register pool 1
id ip 150.150.150.0 mask 255.255.255.0
Client (150.150.150.150)=====
sip-ua
registrar ipv4:160.160.160.160 expires 3600
**** please remember to rate useful posts
Thanks Mohammed,
will test this out
