CUBE / SBC with VRF & Multi-VRF
I have recently purchased a Cisco ASR1001 with CUBE. Its primary role in life is to servce as an SBC. I have configured a working scenario where i can send and receive phone calls without an issue. However, now that I have nailed down the simplest (and least secure) configuration possible, I would like to begin "tightening up" the SBC and making it more secure. In the documenation I found online it mentions VRF and mult-VRF configuration for CUBE but it's like reading Greek to me at points! I have a good understanding of VRF in general (the whole logical router, seperate routing tables, etc.). Here is the example configuation from the Cisco's documentation that i found online:
vrf definition cust100side // Create a VRF instance
address-family ipv4
exit-address-family
interface SBC100 // Create an interface in the VRF space
vrf forwarding cust100side
ip address 12.0.0.30 255.255.255.0 secondary // This contains the IP address for the
// media, if different to the signaling
// address. The line is not entered, but
// appears automatically after the DBE
// configuration is entered (see
// ‘media-address’ CLI later.)
ip address 12.0.0.20 255.255.255.0 // This is the SIP adjacency address
interface GigabitEthernet0/1/0
no ip address
media-type sfp
negotiation auto
interface GigabitEthernet0/1/0.100 // VLAN identifier 100 defined here
encapsulation dot1Q 100
ip address 100.0.0.1 255.255.255.0 // This IP is where the remote side or external
// router can send traffic to, in order to get
// to the internal 12.0.0.0/24 network
interface GigabitEthernet0/1/0.200 // Other VLANS that are being trunked.
vrf forwarding cust200side
encapsulation dot1Q 200
ip address 200.0.0.1 255.255.255.0
sbc ted
sbe
adjacency sip adj_cust100
vrf cust100side
signaling-address 12.0.0.20 // This is the local address where call traffic
// will get routed to/from
remote-address ipv4 100.0.0.14 // This is an address for the remote side, where
// traffic will be routed
attach
media-address ipv4 12.0.0.30 vrf cust100side // The media address is also on the
// internal network. When the line
// is entered, the interface SBC
// will show a secondary address
// containing this IP address.
activate
Using this configuration as a boiler plate for discussion:
1.) what does the command "interface SBC100" actually do?
2.) should the other party set their device (SBC/PBX/Voip Phone/etc) to 12.0.0.20 or to 100.0.0.1 as my signaling address?
3.) In general, I'm unclear on what this whole configuration actually accomplishes. I mean, what is the advantage of doing something like this over just adding two adjacencies to the same VRF and creating static routes to any relevant subnets?
Thank you for taking the time to assist.
0 Replies 0
