CUCM 8.5 Issue
aspen.dxb
Dear All
I downloaded the CUCM 8.5 IOS upgrade from cisco.
So how can I have My software  feature License? because it's missing.
What should I do?
Aaron Harrison
If you are upgrading a production system, you must order an upgrade from Cisco.
If you have UCSS (i.e. free entitlement to upgrades) do so via the Product Upgrade Tool : http://tools.cisco.com/gct/Upgrade/jsp/index.jsp
If not, you'll need to speak someone about ordering the upgraded software.
Either of those should result in you getting a new license PAK by mail or email which you can then register to get a license file.
If you just upgrade using a downloaded ISO, and move up a minor or major version (e.g. 8.0 - 8.5) you need a new license after the upgrade or services will stop.
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
