CUCM (SIP Trunk) without VG or CUBE
kokojatnika
Is there anyone configured cisco communication manager (CUCM) for direct calls to SIP Trunk provided by the Service Provider (Without Voice Gateway or CUBE)?
I am looking for configuration steps
jari.suosilta
Trunk is trunk..
We use Direct SIP trunk to service provider as standart on our installations. We might use CUBE need split for trunk recording .
Ask Service provider their settings.
Some points, trunk specific..
-System/Security/sip trunk security profile (TCP or UDP signaling )
-System/region/Audio codec preference list, copy for editable list for correct order  ( + system/service parameters/cumc. some codecs too)
-Device/device settings/Sip Profile ( for trunk) .  IF allowed, Enable SIP options PING, It  is nice option to see if trunk alive...
-Device/trunk ... dependent on operator. Here i put only one iP for trunk, but depends on operator how many IPs they use.
