Delay In Call Setup
ziadk
Hi All,
I'm currently using the setup below:
Nortel PBX ------E1/R2------- Cisco 3660 (NM-HDV-1E1-30E)
The Nortel PBX has the following description:
Make: Nortel Meridian SL1 - XT
Version: 1211 Release 16 Issue 91
The Cisco 3660 has the following IOS:
Version 12.1(5)T4
I'm currently experiencing a 3 to 4 sec delay in call setup. Every time an extension on the PBX side dials an IP extension, it takes about 3 sec before we hear a ring tone.
I checked the debug on the Cisco side, and according to the time stamps, there is a difference of 3 sec between the fist digit of the called party and the last digit of the caller ID. Moreover, there is approximately a 100ms delay from the time the Cisco router send an acknowledgment and receiving the next digit from the PBX!!
Is there a way to speed up this process? What are the parameters that can be changed in order to affect this setup time?
Any idea, help will be appreciated.
I pasted a small copy of the debug:
*Apr 14 23:30:51.016: htsp_dsp_message: SEND/RESP_SIG_STATUS: state=0x0 timestam
p=25790 systime=388625128
*Apr 14 23:30:51.016: [2/0:1(2), R2_Q421_IDLE, E_DSP_SIG_0000]
*Apr 14 23:30:51.016: r2_q421_ic_seize(2/0:1(2)) Rx SEIZURE
*Apr 14 23:30:51.016: r2_reg_start_digit_collection(2/0:1(2))
*Apr 14 23:30:51.016: r2_q421_ic_seize(2/0:1(2)) Tx SEIZE ACK (with 2ms delay)[R
2 Q.421 2/0:1(2)] set signal state = 0x8[R2 Q.421 2/0:1(2)] set signal state = 0
xC
*Apr 14 23:30:51.016: r2_reg_process_event: [2/0:1(2), R2_REG_IDLE, E_R2_REG_STA
RT_COLLECTION(72)]
*Apr 14 23:30:51.016: r2_reg_start_collecting(2/0:1(2))
*Apr 14 23:30:51.016: r2_reg_timer_stop(2/0:1(2))
*Apr 14 23:30:51.016: [2/0:1(2), R2_Q421_IC_SEIZE, E_HTSP_SETUP_ACK]
*Apr 14 23:30:51.016: r2_q421_ic_setup(2/0:1(2)) E_HTSP_SETUP_ACK
*Apr 14 23:30:51.016: r2_reg_offhook(2/0:1(2))
*Apr 14 23:30:51.016: r2_reg_process_event: [2/0:1(2), R2_REG_COLLECTING, E_R2_R
EG_OFFHOOK(73)]
*Apr 14 23:30:51.016: r2_reg_ic_offhook(2/0:1(2))
*Apr 14 23:30:51.016: R2 Incoming Voice(2/0): DSX (E1 2/0:1): STATE: R2_IN_IDLE
R2 Got Event R2_START
*Apr 14 23:30:51.300: htsp_digit_ready_up(2/0:1(2)): Rx digit='4'
*Apr 14 23:30:51.300: R2 Incoming Voice(2/0): DSX (E1 2/0:1): STATE: R2_IN_PRE_C
ALLERID R2 Got Event 4
*Apr 14 23:30:51.300: r2_reg_generate_digits(2/0:1(2)): Tx digit '1'
*Apr 14 23:30:51.392: htsp_digit_ready(2/0:1(2)): Rx digit='#'
*Apr 14 23:30:51.392: R2 Incoming Voice(2/0): DSX (E1 2/0:1): STATE: R2_IN_PRE_C
ALLERID R2 Got Event R2_TONE_OFF
*Apr 14 23:30:51.392: r2_reg_generate_digits(2/0:1(2)): Tx digit '#'
*Apr 14 23:30:51.512: htsp_digit_ready_up(2/0:1(2)): Rx digit='9'
*Apr 14 23:30:51.512: R2 Incoming Voice(2/0): DSX (E1 2/0:1): STATE: R2_IN_PRE_C
ALLERID R2 Got Event 9
*Apr 14 23:30:51.512: r2_reg_generate_digits(2/0:1(2)): Tx digit '1'
*Apr 14 23:30:51.592: htsp_digit_ready(2/0:1(2)): Rx digit='#'
*Apr 14 23:30:51.592: R2 Incoming Voice(2/0): DSX (E1 2/0:1): STATE: R2_IN_PRE_C
*Apr 14 23:30:51.592: r2_reg_generate_digits(2/0:1(2)): Tx digit '#'
*Apr 14 23:30:51.700: htsp_digit_ready_up(2/0:1(2)): Rx digit='5'
*Apr 14 23:30:51.700: R2 Incoming Voice(2/0): DSX (E1 2/0:1): STATE: R2_IN_PRE_C
ALLERID R2 Got Event 5
kmcsweeg
Ziadk,
I recently had similar issues with one of my 3640's
not sure if this fix would apply to you but here it is
apply this to the voice port your currently have the delay problems on.
timeouts interdigit 3
it worked for me it cut the delay before tone from 13secs to 4secs
Kevin McSweegan
Network manager/CCNP
C&S Wholesale Grocers Inc.
