Community Helping Community
1078
Beginner
Dial-peer matching issue
Hi, I have 5 dial-peers with the same destination-pattern .T The only difference is preference option for VoIP dial-peer (0) compared to the others - POTS(2).
#sh dial-peer voice summary
dial-peer hunt 0
             AD                                    PRE PASS                OUT
TAG    TYPE  MIN  OPER PREFIX    DEST-PATTERN      FER THRU SESS-TARGET    STAT PORT
100    voip  up   up             .T                 0  syst sip-server
10     pots  up   up             .T                 2                      up   0/1/0
11     pots  up   up             .T                 2                      up   0/1/1
30     pots  up   up             .T                 2                      up   0/3/0
31     pots  up   up             .T                 2                      up   0/3/1
I would expect that all calls match the VoIP dial-peer as outbound. Also #sh dialplan number always shows me it in that way.
#sh dialplan number 31313131313 timeout
Macro Exp.: 31313131313
VoiceOverIpPeer100
(shortened..)
I thought there was a rule disabling to have inbound/outbound dial-peer same but even extended #sh dialplan dialpeer xxx number yyy timeout didn't prove the theory
#sh dialplan dialpeer 100 number 31313131313 timeout
VoiceOverIpPeer100
(shortened..)
Despite all I can see calls matching outbound POTS dial-peer:
#sh voice call status
CallID     CID  ccVdb      Port             DSP/Ch  Called #   Codec    Dial-peers
0xB757     666  0x480F152C 0/1/0.1          0/1:1  *1313131313 None      100/10
Can you please tell me why POTS is matched?
Thank you very much.
Martin
2 REPLIES 2
Rising star
Re: Dial-peer matching issue
Hi. For every calls there are always two call legs: an inbound call leg and an outbound call leg.
Every call leg uses a dial-peer.
You can find more details here:
Understanding Dial Peers and Call Legs on Cisco IOS Platforms
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010ae1c.shtml
Understanding Inbound and Outbound Dial Peers Matching on IOS Platforms
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
In your example you have an incoming voip call that uses the dial-peer 100 as incoming dp. So the dial-peer 100 cannot be used as an outgoing dp.
You must configure an incoming dp like this:
dial-peer voice 200 voip
description INCOMING_CALLS_from_VoIP_NET
incoming called-number .
modem passthrough nse codec g711alaw
dtmf-relay rtp-nte
codec g711alaw
fax rate disable
fax protocol pass-through g711alaw
no vad
No session target is necessary for incoming dp.
If you want establish a ip to ip call, evaluate the use of allow-connections command.
Regards.
Highlighted
Beginner
Hi Daniele,
thank you for your response. The allow-connection sip to sip command fixed my issue.
I also found (thanks to debug voip ccapi inout & signaling analyzer) that one dp can stand for both incoming dp & outgoing dp = no additional dp 200 is needed.
Martin
Content for Community-Ad
FusionCharts will render here
