dial peer
anitachoi3
I setup the voip gateway to handle the voice calls.
The TW voice calls will come from first two T1 circuits (dial peer 88601 and 88602), the gateway will pass the TW calls to TW gateway (dial peer 88603).
the last two T1 will send HK calls to provider for termination (dial peer 85201, 85202).
Following is the config. is it correct? any missing? what is different between "incoming called-number" and "destination-pattern"?
rgds
R1
dial-peer voice 88601 pots
descr receive 886 call
incoming called-number 886
port 0:D
dial-peer voice 88602 pots
port 1:D
dial-peer voice 88603 voip
description tw gateway
destination-pattern 886
session target ipv4:192.168.x.x
dial-peer voice 85201 pots
descr hk local call
destination-pattern 852
direct-inward-dial
port 2:D
dial-peer voice 85202 pots
descr hk local call
direct-inward-dial
port 3:D
5 Replies 5
Brandon Buffin
Is the provider only sending you 3 digits (886 for example)? You will need the direct-inward-dial command on your 2 inbound dial peers (88601 and 88602), but not on your outbound dial peers (85201 and 85202)
Take a look at the difference between incoming called-number and destination-patter in the link below. Incoming called-number matches DNIS and is used for inbound dial peers. Destination-pattern matches ANI on inbound dial peers and DNIS on outbound dial peers and is generally used for outbound dial peers.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a008010fed1.shtml
Hope this helps. If so, please rate the post.
Brandon
Hi Brandon,
So, the config should be below. I put the "." after the 886 and 852.
any missing?
incoming called-number 886.
direct-inward-dial
port 0:D
descr hk local call
destination-pattern 852.
port 3:D
886. would indicate a 4 digit number starting with 886. If you want to include any number starting with 886, you can use 886T. If you want to include any incoming number, you can use "incoming called-number ." Also, you will still need an outbound dial peer to match for this pattern.
Brandon
your peers should look something like this
destination-pattern 886....
forward-digits all
port 0:D
incoming called-number .T
port 1:D
descr hk local call
destination-pattern 852....
direct-inward-dial
forward-digits all
port 2:D
descr hk local call
direct-inward-dial
port 3:D
For the "dial-peer voice 88602 pots"
The voice call is coming from "port 1:d" and the destination number they call is 886.
I do not understand "dial-peer voice 88603 voip"
why
are configured?
does it send voice traffic to 192.168.x.x gateway? (not receive voice traffic)
for the "dial-peer voice 85201 pots ", it sends traffic to "port 2:d"
for the "dial-peer voice 85202 pots", it receives traffic from "port 3:d"
is it correct?
rgds
