Does Cisco 2911 voice routers work with cisco SPA 514G phones
botshabot
We want to deploy a Cisco 2911 voice router but looking for cheap phones with two Giga bit ethernet ports (one to the switch and the other to computer)  that has a display and user friendly. I want to know if the cisco SPA 514G will work with it?
Adrian Saavedra
Level 7
Level 7
SPA500 phones are supported in UC500.
Hope to help, please remember to rate the post if it does.
Kind regards,
- Adrian.
alig.norbert
Level 4
Level 4
On CME, SPA5xx are only supported as 3party phones. So several services (local directory e.g.) are not supported without some workaround.
Norbert
I am having "Error: spcp register token rejected 514G"
I am trying to provision 3 spa514G phones to Cisco UC540 with CME. However I am unable to have them registered.
I have a spa508G that works fine, as there seems to be loads for spa50X versions, not for spa51x.
Please advice, I downloaded the .bin file for spa51x, however, when I run the telephony service > load 514G firmware, it does not work, if I use load ? >> it lists a bunch of devices but it does not list the 514G
