So I've read the entire VOIP configuration site 3x at least and can't figure out why or if this will even work.
We have a 2821 running voice code (12.4) with the following:
NAME: "2821 chassis", DESCR: "2821 chassis, Hw Serial#: FHK0847F06P, Hw Revision: 53.49"
PID: CISCO2821 , VID: NA, SN: FHK0847F06P
NAME: "Two port T1 voice interface daughtercard", DESCR: "Two port T1 voice interface daughtercard"
PID: VWIC-2MFT-T1= , VID: 1.0, SN: 32225300
NAME: "High Density Voice", DESCR: "High Density Voice"
PID: NM-HDV= , VID: 1.0, SN: JAB032907G9
NAME: "T1 (2 Port) Multi-Flex Trunk WAN Daughter Card", DESCR: "T1 (2 Port) Multi-Flex Trunk WAN Daughter Card"
PID: VWIC-2MFT-T1= , VID: 1.0, SN: 22104794
NAME: "PVDM 3-C549 Simm", DESCR: "PVDM 3-C549 Simm"
PID: PVDM-12= , VID: 1.0, SN:
My question is this:
Can I create a DSPFARM with all 48 DSPs and configure the 4 T1 ports to have
pri-group timeslots 1-24? If so how? I understand i only have 48 DSPs, but i want to share those across 4 t1-s and so far it isnt working. When i configure the DSPFARM, the controllers can't see the DSPFARM (complains that there are no DSP resources available); when I keep the DSPs out of the farm, I can only configure the T1 ports that are directly on the card with the DSPs. HELP :)
