force device out dial-peer
zorric.sia
Hello All,
We have (2) SIP trunks, one for long-distance and one for local calls. Our LD provider does not support faxing so i must force fax traffic to our local SIP trunk. I tried using answer-address and preference but it didn't work. Fax machines are connected to ATA boxes. Relevant config is below, please advise.
ephone-dn  32  dual-line
number 2032
description FAX 2032
name FAX 2032
ephone  32
device-security-mode none
mac-address 0019.E8AE.8702
max-calls-per-button 2
type ata
button  1:32
dial-peer voice 1000 voip
description LD_OUTBOUND
translation-profile incoming 2
translation-profile outgoing 1
destination-pattern ..........
session protocol sipv2
session target ipv4:LD_SIP
  incoming called-number .T
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 995 voip
description LOCAL_OUTBOUND
translation-profile outgoing 4
answer-address 2032
session target dns:LOCAL_SIP
voice-class codec 1
dtmf-relay rtp-nte
no vad
Thanks in advance.
Add the output of the command
debug voip dialpeer all.
Try to remove destination-pattern to dial-peer 1000.
Regards.
etamminga
You van use cor-lists to prevent the fax dn to see the LD dial peer.
So, have a look at cor-lists on CCO.
Erik
