H.245 Tunnelling
paolo.gangi
I would like to know if there's the possibility to activate on dial-peer basis H.245 Tunneling because on global config the tunnelling is disable.
How can do that?
Best regards
Paolo
H.245 tunneling is enabled by default.  Disable it with the hidden command 'h245 tunnel disable'.  It cannot be disabled with an h323 class or dial-peer.
If I recall correctly, the gateway will never originate h245 tunneled traffic, but if it happens upstream, then we will pass it through, as long as the other side also has it enabled.  I may be wrong on that; we don't see it actually utilized much.
Also, CUCM doesn't support h.245 tunneling.
In my experience the h245 tunneling is configurable only in global mode.
If you have a recent IOS (15 or 15.1) you can check if in the "voice class h323" the subcommand h245 tunneling was added.
Regards.
Thank you Daniele.
The policy of the company is Tunnelling disable (global config). But sometimes some carriers, for new interconnections, ask to enable the Tunnelling. I thought  it could be possible to set it in the dial-peer.
I'll check the IOS specification.
regards
Paolo
