06-18-2004 06:29 AM
As it written in h.323 call redirection enhancments for cisco ios 12.2T, as5300 should understand call forwarding. I tried to implement call forwarding on my as 5300, but calls are simply dropped with Cause recovery on timer expiry. Did anyone has succesfull experience with call forward feature?
06-21-2004 02:01 AM
Can you give me some more info about Call Forwarding feature and what are you trying to achieve?
Dragos
06-21-2004 04:23 AM
Hi Dragos
I'm trying to implement exactly which is written in H.323 Call Redirection Enhancements
Mikheil
06-21-2004 08:06 AM
Hi Mikheil,
Could u please inform if the call to the originating endpoint is released, before you get the "recovery on timer expiry message"??
Also, the restrictions on Call Redirection Web page requires IVR to be setup for this feature to work. Is this setup?? Could u give more explanation regarding the problem.
thanks and regards,
Amit.
