04-17-2013 09:13 AM
Hi Guys.
I got CME8.0. with IOS c2900-universalk9-mz.spa.151-1.XB.bin total 10 phones. is a site office.
3 extension 4177,4161,4162 with (phones 6961) ring at the same time. I want to just one phone to ring how can I disable the ring on the other 2 phones
maint ext is 4177(want to ring)
the other extensions are 4161 and 4162 (not to ring when a call coming to 4177).
I tried to just copy a new button set up from the config,but it didnt work .
I hope this maker sense
this is 4161 config
ephone-dn 61 octo-line
number 4161
label tony
description T Kenedy
name T Kenedy
call-forward busy 5999
call-forward noan 5999 timeout 20
Ephone 61
device-security-mode none
description Tony
mac-address 6400.F13A.7ED6
max-calls-per-button 1
username "tkennedy"
type 6961
buttons 1:61 2:77 3:80 4:81 (how can removed 2:77,3:80 and 3:81 and have only 1:61 only).
thanks guys
Solved! Go to Solution.
04-18-2013 12:48 PM
04-18-2013 12:48 PM
Same as removing any other command.
no button x:y
restart
04-19-2013 06:48 AM
tahnsk Paolo
04-19-2013 01:45 PM
Thank you for the nice rating and good luck!
