01-23-2008 01:48 AM
hi,
what commands should use at NAS to limit carrier's calls or let say Voice traffic?
can give example please?
thank you...
01-23-2008 02:13 AM
in addition my IOS for As5400 is Version 12.3(10f)
01-23-2008 02:31 PM
The cleanest solution is to do this at the PGW. Must be on at least version 9.6(1). See here...
http://www.cisco.com/en/US/docs/voice_ip_comm/pgw/9/feature/module/9.6_1_/FMCallLm.html
Alternatives if for dial-peers or trunk-grps if using:
max-calls
max-conn on dial-peer
http://cco/en/US/docs/routers/access/as5850/software/operations/guide/prov.html
