How to configuration for setting up a SIP trunk between CUCM 11 .0 and a SIP-VoIP provider ?
sreeharikt
Hi all,
I'm looking for a solution / howto configuration for setting up a SIP trunk between CUCM 11.0 and a SIP-VoIP provider.
Got SIP username, password and SIP-proxy IP from the provider.
I am not sure how to do it, can I do it without CUBE ( directly between CUCM and Provider? )
Also Saw something called SIP Realm. How does it trigger when there is no option to select it in SIP Trunk ?
0 Replies 0
