how to recover mbrd_e1t1_vic_connect: setup failed on cisco 2811 routers
nyein chan tun
Dear All Experts
I have three cisco 2811 routers, Router A has both 4 FXS & 4FXO port , Router B & Router C have 4 FXS port. connect with Alcatel PABX.
Now, the problem is ph lines are down after 3 days or more. Whenever down, i try to refresh voice port , with " shut & no shut " on each routers.Now i face the problem that is whenever i make shut & no shut on Router B site, ph line is ok there. But in Router C site , ph line is down. So i refresh @ Router C site,ph line is ok but in the router B site , ph line is down again.
I try several ways for shut & no shut. i have no idea. i checked log file on Router A , here is
Aug 18 16:03:55.306 UTC: mbrd_e1t1_vic_connect: setup failed
Aug 18 16:03:55.306 UTC: flex_dsprm_tdm_xconn: voice-port(0/3/0), dsp_channel(/0
/0/0)
Aug 18 16:12:56.331 UTC: mbrd_e1t1_vic_connect: setup failed
Aug 18 16:12:56.331 UTC: flex_dsprm_tdm_xconn: voice-port(0/3/0), dsp_channel(/0
/0/0)
Aug 18 16:12:56.335 UTC: mbrd_e1t1_vic_connect: setup failed
Aug 18 16:12:56.335 UTC: flex_dsprm_tdm_xconn: voice-port(0/3/0), dsp_channel(/0
/0/0)
Aug 18 16:14:37.405 UTC: mbrd_e1t1_vic_connect: setup failed
Aug 18 16:14:37.405 UTC: flex_dsprm_tdm_xconn: voice-port(0/3/2), dsp_channel(/0
/0/0)
Aug 18 16:19:40.278 UTC: mbrd_e1t1_vic_connect: setup failed
Aug 18 16:19:40.278 UTC: flex_dsprm_tdm_xconn: voice-port(0/3/0), dsp_channel(/0
/0/0)
Aug 18 16:22:34.597 UTC: mbrd_e1t1_vic_connect: setup failed
Aug 18 16:22:34.597 UTC: flex_dsprm_tdm_xconn: voice-port(0/3/2), dsp_channel(/0
/0/0)
Aug 18 16:36:37.065 UTC: mbrd_e1t1_vic_connect: setup failed
Aug 18 16:36:37.065 UTC: flex_dsprm_tdm_xconn: voice-port(0/3/0), dsp_channel(/0
/0/0)
So give me advise & guide to recover this problem . I have really big problem now. help me!
thanks a lot
Steven Holl
Can you post a 'sh ver?'  There are some bugs associated with this.
Here it's sh ver .All three routers are same version , flash, model except RouterB & C has only 4 FXS voice interface.
RouterA#sh ver
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(8), RE
EASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Mon 15-May-06 14:54 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
RouterA uptime is 12 weeks, 1 day, 23 hours, 11 minutes
System returned to ROM by reload at 08:59:03 UTC Wed May 26 2010
System restarted at 09:01:16 UTC Wed May 26 2010
System image file is "flash:c2800nm-spservicesk9-mz.124-8.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.51) with 251904K/10240K bytes of memory.
Processor board ID FHK0949F1W9
2 FastEthernet interfaces
4 Serial(sync/async) interfaces
4 Voice FXO interfaces
4 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
RouterA#sh flash
-#- --length-- -----date/time------ path
1     26725176 Dec 2 2005 09:30:24 +06:30 c2800nm-spservicesk9-mz.123-11.T8.bin
2         1646 Dec 2 2005 09:39:00 +06:30 sdmconfig-2811.cfg
3      4052480 Dec 2 2005 09:39:22 +06:30 sdm.tar
4       812032 Dec 2 2005 09:39:38 +06:30 es.tar
5      1007616 Dec 2 2005 09:39:52 +06:30 common.tar
6         1038 Dec 2 2005 09:40:06 +06:30 home.shtml
7       113152 Dec 2 2005 09:40:18 +06:30 home.tar
8       511939 Dec 2 2005 09:40:32 +06:30 128MB.sdf
9     28532876 Jul 5 2006 05:12:32 +06:30 c2800nm-spservicesk9-mz.124-8.bin
10       10829 Aug 9 2010 14:03:44 +06:30 tftp
2228224 bytes available (61788160 bytes used)
it seems to be upgrade IOS version 123--11.T8  to 124-8 . I'm not exactly know the history of these routers.
You are hitting an old known bug:
CSCse34097
Calls through PRI / BRI show mbrd_e1t1_vic_connect: setup failed errors
Upgrade to the latest mainline release,12.4(25c).
