10-05-2010 07:29 AM
Dear All
We are using PGW 2200 in Signalling mode with AS5400 as MGW to terminate call over TDM/PSTN. Can anybody let me know how we can check "why attempted call failed or reason of failed call from MGW level or PGW level.
Here one thing i want to know we are not using any RADIUS server for log or billing. Please tell me how wecan chcek why & where call faield on MGW or PGW or far end operator side with reason.i chcked few document but no comnads i found to check failed reason of attempted calls..
Please help me with this info.
Amit--. .
10-05-2010 11:35 PM
First of all you have to check C7 link state and CICs state
1. Enter to PGW host with username mgcusr
2 Run mml
3 Check active platform by command rtrv-ne
4 Check C7 link rtrv-c7lnk:all
All C7 links must be in service: IS
5 Check CIC rtrv-tc:carrier10ss7svc1
All CICs must be in Idle state
If it is so then we can go to next steps.
The best way to check reason of failed calls is to use the snooper utility.
Login as root
change directory to
/opt/CiscoMGC/bin
run utility
./snooper int bge0 ss7 itu 1-234-5 detail
Where 1-234-5 - DPC of your carrier
After that you will see a flood of ISUP messages.
In REL message you can find the reason why your call attempt was failed.
on MGW (if it is Cisco AS5xxx) you can run
debug isdn q931 command on all trunks or on selected Dchannel: debug isdn q931 interface Dchannel x/x
You will get isdn messages. In Disconnect message you can find the reason why your call attempt was failed.
Good luck!10-15-2010 10:09 AM
As for troubleshooting real time failures, you have a few options:
1) PGW MDL trace
2) Snoop (unix snoop) - Open capture in Wireshark
3) Cisco Snooper (as stated by previous poster, however this is end of life product and not everyone has access to it)
One method used for failures after the fact is the PGW CDR. Check the release CDB, CDB 1040 for reason code and release source.
CDRs are located in /opt/CiscoMGC/var/spool and can be viewed using the CDR viewer or converted to text.
Help on CDR viewer:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/pgw/9/maintenance/guide/r9_Ch3.html#wp1141887
CDR converter:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/pgw/9/maintenance/guide/r9_Ch3.html#wp1496488
10-18-2010 01:00 AM
Information you have provided is highly helpful.
11-24-2010 04:05 PM
Hi irrantz
can you tell me if i run .snooper comamnd on PGW due to flood of ISUp emssage PGW affcated? or switch-over happened? any down time?
Also if i save this ISUP log can i directly search my number form that logs or i need to sue any converter?
Amit
