12-19-2012 01:15 PM
Hey everyone,
I am working on a solution for our office and was hoping to get some positive feedback here since I can't find much out on the web for this. We are looking at doing a T1 (MPLS) and a backup cable modem connection. There is also a requirement for a sip trunk that would hand off 6 analog phones. I am looking at the IAD 2435 since it does have the T1 controller embedded and the RJ-21 for analog phone lines. I can't find whether it supports vpn's and zone based firewall though which would be a requirement for the cable connectivity in the event of a failure. Also, can't find much on configuring the sip trunk and how to configure the voice ports. Any pointers or advice/snippets of config that may point me in the right direction would be great, thanks!
Solved! Go to Solution.
01-12-2013 01:37 AM
You will have to conf the following elements
Voice service VoIP
Codecs
Voice-port
Voip Dial-peers
Pots dial peers
Sip-ua
01-12-2013 01:37 AM
Voice service VoIP
Codecs
Voice-port
Voip Dial-peers
Pots dial peers
Sip-ua
01-14-2013 07:50 AM
Thank you Rotem. I should have updated this post stating that I had already figured everything out but what you said was dead on. Thanks again!
01-14-2013 09:37 AM
you are welcome and good luck
