Inbound Calls fail with cause code 34
gnanavel.ns
Dear all,
I have a setup in which inbound calls from a service provider PRI coming into the Cisco 2800 voice gateway needs to be routed to a AVAYA CM - the outbound call leg is VoIP. Calls made to the PRI land in the router with a DNIS (Called number) of 8130. The outbound dial peer is selected by the destination pattern 8130 command configured in the voip dial peer 888. The session target is the Avaya CM 172.25.16.8.
Direct inward dial is configured in the POTS dial peer mapped to the PRI interface (E1 1/0/0).
Inbound calls, after getting routed via the outbound voip dial peer seem to fail with a cause code of 34. It should be noted that outbound calls work fine in the opposite direction, i.e, made from Avaya CM and go out through the service provider PRI terminated in the gateway.
I have attached the debug of 'voip dial peer', ccapi inout and h225.Any clue what is making the call fail?
Thanks for your time and inputs.
Gnanavel.
paolo bevilacqua
Wrong forum, post in "IP Telephony". You can move your post using the actions panel on the right.
