Cisco Community Designated VIP Class of 2020
379
Beginner
Incoming Call robotic
Hi there,
We have intermittent problems on the incoming calls. they sound robotic for the called end. Call flows from PRI -> Nortel System->( here nortel pushes calls to Cisco, we have 4 TIE lines interconnecting Cisco gateway)- > Cisco GW. When ever a calls takes this path we have this issue and this cannot be reproduced. We checked the T1 line both on carrier end and on our end but no errors. We even upgraded flash on Cisco.. no solution..Can anyone help me out in this?
4 REPLIES 4
Re: Incoming Call robotic
which IOS version are you on?
'show voice dsp group all' as well please
-nick
Highlighted
Beginner
Hi there,
CCM Version: 4.2(3)es10
flash version: 124-4.T8
Nortel side recieved counter erros on they saw some channels getting slipped. when i checked the config on Call manager clocking was set to be internal. I have changed to external and the channel slips has been reduced on the Nortel side.
You may be hitting this bug (or one of a couple similar ones around this IOS range) CSCsd90851
I would try upgrading to 12.4(9)T7 or 12.4(15)T8 and this should go away.
-nick
Beginner
Hello Nick
if it is a bug then it should hit most of the users.but it is not..i am trying to narrow down this issue.lets see how it goes
Thanks and i will keep you posted
Much appreciated
Content for Community-Ad
FusionCharts will render here
