IOS for Class-map
abbas.ali
I have a 2621 router with 32M of Flash and 53M of DRAM running IOS ver. 12.1 (14).
I am not able to configure the commands below as seems like that the IOS doesn't support it.
class-map match-all VOIP_Control
match ip dscp 26
class-map match-all VOIP_Media
match ip dscp 46
policy-map VOIP
class VOIP_Control
priority 8
class VOIP_Media
priority 1536
class class-default
fair-queue
Which IOS do I need to download in order to configure these commands exactly?
tepatel
For Policy-map commands as per following url, you need .T releases
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fqos_r/qrfcmd6.htm#1032964
so go for .T releases, 12.0(5)T and above.
ndoshi
Erick Bergquist
Level 6
Level 6
The commands should take without the match-all option on the class-map. That isn't needed since theres only one match anyway. The match-all / match-any are in newer versions. Try and let us know. I'm not sure offhand when match ip dscp was first supported. You may need to upgrade to a newer 12.1T or 12.2 release if you need newer QoS features, etc.
Example:
class-map voip_control
match ..
