smvasagam
Beginner
IPIPGW
Hi, I'm looking for a basic config for a 3725 with NM-HDV + PVDM to do SIP transcoding from g711 to g729. Anyone with some pointer where to look to start?
My setup is:
IPIVR<--SIP,G711-->3725<--SIP,G729-->Carrier
I have IOS image:
c3725-adventerprisek9_ivs-mz.124-16.bin
Most of the config I found is for Cisco CallMgr and SCCP. Is there config just for plain generic transcoding with SIP?
Any pointer appreciated.
Thanks in advance.
Here is my current config:
! No configuration change since last restart
version 12.4
service password-encryption
hostname A-37-01
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login local-auth local
aaa session-id common
clock timezone GMT 8
no network-clock-participate slot 1
no network-clock-participate slot 2
voice-card 1
dspfarm
dsp services dspfarm
voice-card 2
dspfarm
ip cef
ip name-server 192.168.1.1
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
voice class codec 2
codec preference 1 g729br8
voice class codec 3
codec preference 1 g729r8
codec preference 2 g723r53
codec preference 3 g723r63
codec preference 4 g723ar53
codec preference 5 g723ar63
ip ssh authentication-retries 2
ip ssh version 2
interface FastEthernet0/0
ip address 192.168.1.101 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
speed 100
full-duplex
interface FastEthernet0/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
shutdown
speed 100
full-duplex
router rip
network 192.168.1.0
ip route 0.0.0.0 0.0.0.0 192.168.1.1
ip http server
no ip http secure-server
no cdp run
control-plane
dspfarm transcoder maximum sessions 120
dspfarm rtp timeout 60
dspfarm connection interval 60
dspfarm
dial-peer voice 100 voip
tone ringback alert-no-PI
description Incoming
voice-class codec 1
session protocol sipv2
incoming called-number .T
dtmf-relay rtp-nte h245-alphanumeric
dial-peer voice 200 voip
description Outgoing
destination-pattern .T
voice-class codec 2
session target ipv4:192.168.1.111
dtmf-relay rtp-nte h245-signal h245-alphanumeric
gateway
timer receive-rtcp 5
timer receive-rtp 180
sip-ua
retry invite 2
retry response 2
retry bye 2
retry cancel 2
gatekeeper
shutdown
line con 0
transport preferred none
line aux 0
exec-timeout 5 0
login authentication local-auth
line vty 0 5
access-class 1 in
exec-timeout 5 0
transport input ssh
end
7 REPLIES 7
jposada_us
Beginner
Transcoding doesn't care about the VoIP protocol, it's only for codec negotiation.
Did you ensure your incoming call is using the right dial-peer (show call active/history voice brief)?
Did you hear ring back on phone A, did the phone B ring out?
The call is dropped after you answer the call on phones B?
This documentation can help you...
http://www.cisco.com/en/US/products/ps6441/products_configuration_guide_chapter09186a0080541bf3.html
Yes, the call dropped with SIP error 480 (TIMEOUT) after I answered it. The codec I try to use is:
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=yes
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
vmalhi
Beginner
A transcoder will need to register to something- it uses SCCP and this is Master/Slave.
You should define start the telephony-service on the router and register the transcoder locally to the telephony-service on the router (you are not really going to setup the router to become a CME- this is just for the transcoder).
I think the bit of config you are missing is:
sccp
sccp local Vlanxxx
sccp ccm 1.1.1.1 priority 1
telephony-service
max-ephones 1
max-dn 1
ip source-address 1.1.1.1
sdspfarm units 1
sdspfarm transcode sessions x
sdspfarm tag 1 mtp
In your dial-peers do not use the voice class codec command otherwise you will not be able to use the transcoder- hardcode the codec to g729r8/g711ulaw...
One more thing- unless its a new feature, transcoding is not supported SIP-SIP. So you may have to use H323 on one leg of the call. Thats how it is in earlier 12.4 releases.
That is good advice by vmalhi. However in latest code it should be possible to use transcoding for everything without configuring sccp. See:
http://cisco.com/en/US/products/ps6706/products_feature_guide09186a008076161a.html
Remember to use an Ip-to-ip gw image which filename ends with _isv.
The transcoder needs to register to something- it can't invoke itself. You always need to associate it to you SCCP application that you define on the router and register it to one of CME/SRST/CCM. The document also states this, so I am not sure what you are saying?
Point taken and I stand corrected. Thanks!
No probs! You had me questioning myself there...
