06-27-2011 12:53 AM
Dear All,
I have same network scenario as below:
Mobile phone (Originate PSTN) -------------------> AS5400XM( H323)-------------------> (H323) Gateway ( Terminate GW )---------> client Mobile phone.
I have problem as below
1. how to check Post dial delay between Originate PSTN to AS5400XM?
2. I have sent call to terminate gatway with H323 protocol and is there any command to check PDD in AS5400 to
Terminate GW? How to solve long PDD in such case in each segment?
Best Regards
Dan
07-07-2011 06:19 AM
With a correct configuration, there is zero PDD.
07-07-2011 09:34 AM
'debug voip ccapi inout' will show u realtime events and can point to where the delay is coming from.
07-12-2011 06:04 AM
Hi Dan
If the call is originated from PSTN, just check with your PSTN provider and identify the Interdigit PDD timer and try to reduce it. Also when the Dial-pattern is configured correctly at the PSTN then the PDD is minimal. Make sure your provider has configured it properly.
PDD will be longer as a call that is completely dialed has to wait several seconds for additional digits to be sure it has all the digits.
Thanks.
